Riejufixing |
Riejufixing |
Riejufixing |
Posted: 14:35 - 20 Sep 2018 Post subject: |
sickpup wrote: | That is one of the most irresponsible and dangerous video I have ever seen of how to fit motorcyle tyres. It would make a really good video of how to fit tyres of you want to die.
If that tyre had blown off the rim and keep in mind it is not just the tyre you have to worry about, you can't see a crack in the rim under the paint the 2nd fitter would have lost his hand if not his whole arm and his life and the first fitter his head. |
I agree with this. If you want to see how dangerous tyre fitting can be if people get it wrong, there are lots and lots of videos out there, from fitting big lorry tyres in (or without) cages, to "blowing up", literally, tyres using butane, ether etc., what happens when tyre plies start letting go when inflated and the sidewall bursts, split rims coming apart in or not in cages, etc., sidewalls bursting when the tyre's fitted using gas explosions.
Is it just a problem with big tyres? Nope. My mum had an ordinary mobility scooter with 8x2 tyres. She gave it to someone who later wanted to change the tyres. He undid the four obvious nuts on the wheel disk, like the ones you see on car wheels. It was a split rim, and after it blew apart he was unable to use three of his fingers for a while 'cos they were bandaged, and had to have new patio door glass fitted where part of the wheel smashed into it.
Not that this is likely to be a problem for the OP, of course. I hope! |
G |
G The Voice of Reason
Posted: 15:07 - 20 Sep 2018 Post subject: |
I don't believe it's dangerous, as you claim it is.
I think you have misunderstood the physics of air movement in this situation and there's not the danger you claim.
However, if there is evidence to prove your assertion, then I'd be interested to see it.
With tyres that have a reasonable seal, flow is less of an issue in my experience.
With a tyre that's had a heavy box sitting on it in a courier van, deforming it a bit; flow rate even for tanked air compressors does make a difference.
Quote: |
If you've managed to fit tyres using a 12v compressor, I'd say you're Billericay Dickie! Well done. |
I have seated beads with fairly wimpy 12v compressors, but my current one is a T-Maxx Adventuruer, which is about 0.75hp, designed for 4x4s, so decent flow. Sometimes it does require a bit of a bounce, but normally fairly quick. Can just about manage to do both tyres between sessions at a trackday (around 40 minutes.) |
TigerWax |
TigerWax Derestricted Danger
Riejufixing |
sickpup |
sickpup Old Timer
Posted: 18:24 - 20 Sep 2018 Post subject: |
So just because it can't be proved it is dangerous you have decided it is safe.
Its very simple and easy to fit a tyre where the bead doesn't want to seat, you just use a bead seating ring on one side and in extreme cases both sides. This video shows how they work but I would never stand on the wheel while doing it, I would use a cage or at the very least a very long airline so I was no where near it.
Clicky for video. |
G |
sickpup |
sickpup Old Timer
MCN |
MCN Super Spammer
G |
Posted: 22:40 - 20 Sep 2018 Post subject: |
I don't plan on measuring every tyre and wheel combination. Though if really bothered, once the equations were understood, it'd be pretty easy to produce a model that considered the reasonable bounds of the ranges available.
However; I think it's a moot point for all combinations due to how I believe the fluid mechanics work in this situation.
Being pedantic, I didn't explicitly recommend it as a solution. I stated that a bead blaster device was available. However, I appreciate people may take that as a recommendation.
I did however suggest a small explosion had worked for me in the past. A solution that I did not claim nor prove was safe and would hope was self-evident is not entirely safe, yet still offered it as a solution I myself had successfully used to solve the problem at hand.
It turns out I don't need to prove something is safe before "recommending it" and can indeed mention things that are not safe.
This 12 litre version explicitly states it can be used on motorcycles:
https://www.tyre-equipment.co.uk/acatalog/Gaither-Bead-BAZOOKA-9-litre--BB09L-GTC_BB09L.html
(The reason I got a 40 litre one is I also wished to use it as a portable air tank to top up bikes away from a compressor.)
This bigger one doesn't mention motorcycles, but does say it will work with 'small lawn mowers'.
https://www.hawktools.co.uk/10-gallon-bead-blaster.html
I'm not bothered by the safety of your solution; but you have not offered proof of this and the only link you've provided shows the device being used on a different sort of vehicle's wheel in a manner you state you would not use it. Having not seen them before, I did try and find more information about their use on motorcycles, but couldn't find any.
Riejufixing |
TigerWax |
Riejufixing |
Posted: 11:24 - 21 Sep 2018 Post subject: |
Never seen them. I just use an ordinary small 25l compressor like those than can be had off eBay for less than £50. First, I thought the "bead blaster" (an USAian term?) was for cleaning metal, etc., & thort "Whut?". |
bikenut |
bikenut World Chat Champion
Posted: 15:25 - 21 Sep 2018 Post subject: tyre |
Yep there are all sorts of tricks to make the tyre bead rise the safety bead of the wheel, but over pressure is not really one of them as tyres have been known to "explode" or jump over the beads KILLING the fitter in the proccess, which is why a safety cage is used.
If you have fitted a tyre and then hear a sort of "tearing" sort of noise, RETREAT immediately as the cords in the tyre are breaking !!!
Most people would go closer to the tyre to try and see/find the noise, which is of course completely the wrong thing to do.
To seat a soaped bead the bouncing method may work for you, along with a compressor of sorts to try and force the beads to seat even slightly, so more air goes in than escapes, using a rachet strap or similar, and even seating one side of the tyres bead to the wheel by human force, hands gripping the tyre and a well placed foot on the wheel.
If this works then all you have to deal with is the unseated/sealed side. Setting up the wheel so a slight push to seat the unseated side, along with a good supply of compressed air. Valve core removal helps with good air flow.
Once the tyre has seated on both beads then "normal pressure " and the soaped beads should be enough for the tyres bead to slide over the safety bead and seal properly and completely, but sometimes this does not happen, with an area of bead not rising/riding/slipping over the safety bead.
This is a dangerous condition, walking into casualty with a wheel hanging off your hand with you screaming the house down must be quite a sight, one i have never seen mind.
My alloy kawasaki wheels can sometimes be problematic with the tyres bead not completely rising over the safety bead of the wheel. I tend to inflate to the max pressure stated on the tyre and leave the wheel well out of the way in the sunshine, or have even placed the wheel/tyre relatively close to a heat source, and it eventually "pops" into place all by its self.
Then check that the tyre has seated evenly on the wheel using the tyres guide "lip" edge.
Tyres stored in a stack can be problematic. ____________________ nuts about bikes |
bikenut |
TigerWax |
MCN |
MCN Super Spammer
Riejufixing |
doggone |
doggone World Chat Champion
MCN |
MCN Super Spammer
The last post was made 5 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
