Ayrton |
Ayrton World Chat Champion
steve the grease |
Ayrton |
Posted: 20:57 - 28 Nov 2019 Post subject: |
I've taken the cover off and decided to take the camshaft holder out for a better look as it's too tight in there.
The faces dont exactly look flat but they have this discolored/ worn section, is that normal?
https://i.imgur.com/Mzml2hM.jpg
heres some other images of it:
https://imgur.com/a/IZyZg3K
Also took the opportunity to take the camshaft out for a closer look. I cant hear any noise in the bearings unless I hold it right up against my ear then I can hear a faint metal rubbing, but I suppose that's normal? Also the smaller bearing doesnt seem to spin much (but it's smooth) is that normal?
Ran out of time to check the strainer, so I'll try and do that tommorow. |
MCN |
MCN Super Spammer
Ayrton |
Polarbear |
Polarbear Super Spammer
bikenut |
bikenut World Chat Champion
Polarbear |
Ayrton |
Posted: 16:03 - 02 Dec 2019 Post subject: |
Which black specs are you talking about bikenut?
anyway I just took the oil strainer out and it bad news, I found all this metal in there. There are quiet big pieces and theres a lot of them (that's a electrical tape tub for reference)
https://i.imgur.com/aBiOBWh.jpg
Doesnt seem to be any play in the crank movement that I can see either.
Here's the best shot I can get of the piston
https://i.imgur.com/n8wrFOH.jpg
Is there any point removing the engine and stripping it down or is it new engine time? Unfortunately finding an engine for these that isn't tons of money on ebay seems difficult. |
Riejufixing |
Ayrton |
Easy-X |
Easy-X Super Spammer
Posted: 18:23 - 02 Dec 2019 Post subject: |
Something has some play in it and a cog is now flapping about and grinding chucks from the inside of the crankcase?
If you're about to junk the engine you may as well dismantle it, that's the easy bit. Putting it back together is the hard work ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Riejufixing |
Posted: 23:13 - 02 Dec 2019 Post subject: |
Ayrton wrote: | Yep none of it's magnetic. |
I don't like the look of those rocker arms at all, the hardening's gone through, but they aren't the cause of the tapping if you have adjusted the valve clearances.
What does an engine stethescope tell you? You can use a long screwdriver (habdle end to ear!) or bit of bamboo cane or something, make sure the end you hold against the little flappy bit in front of your ear hole is comfy, press the end against the flappy bit to close your ear's hole (yes, *ear* hole), and hold the other end against the cylinder head (each side), and bottom end, or other likely places, to pin down where the tapping is coming from. N.B. make sure the ear end is comfy and won't hurt your ear. You will hear all sorts of whirring clanking scraping noises, but the tapping you're hearing should be obvious.
The bits of light alloy in nthe strainer could have been there for ages, or recently. Hard to know. Can you get a better pic of them clean? |
Ayrton |
Riejufixing |
Ayrton |
Ayrton |
Riejufixing |
Ayrton |
Sister Sledge |
Easy-X |
Pete. |
Pete. Super Spammer
Posted: 23:10 - 04 Dec 2019 Post subject: |
Those bits of metal are just casting flashing IMO. Shouldn't be there but not a mechanical issue. It's certainly not white metal big end bearings because they use roller bearings in the conrod. ____________________ a.k.a 'Geri'
- Super Spammer
Pete. |
Pete. Super Spammer
Ayrton |
The last post was made 4 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
