Kayak23 |
Kayak23 Two Stroke Sniffer
Tracer1234 |
Tracer1234 World Chat Champion
Posted: 12:29 - 03 Aug 2017 Post subject: |
Good work!! Look forward to seeing how this turns out ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
CBT 04/14. A: Mod 1 & 2 13/04/15 |
Hong Kong Phooey |
ThatDippyTwat |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Fin |
Fin World Chat Champion
Posted: 21:45 - 03 Aug 2017 Post subject: |
Removed the exhausts, drained oil, removed the sump, went to put on new gasket and saw this
https://i.imgur.com/VYroFhN.png
Have put it on anyway, but didn't get round to putting the exhaust on and checking if the sump leaks, will find out tomorrow
https://i.imgur.com/bgehWMS.png |
Tracer1234 |
Posted: 22:58 - 03 Aug 2017 Post subject: |
Very nice, very nice indeed. How was the ride home? ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Hong Kong Phooey |
Posted: 09:07 - 04 Aug 2017 Post subject: |
Prolly be ok as it's on the outer. ____________________
pompousporcup... |
Posted: 10:41 - 04 Aug 2017 Post subject: |
bought a dynojet kit for the gpz900 as ive not been having much luck with rejetting with keihin jets.. its still epicly lean.
Looked inside the dynojet box and compared the contents to some parts i have as spares.. turns out i already have a spare set of drilled slides and a 4 matching shortened slide springs.. bugger.
Put more cable ties on the thundercat fairing |
kramdra |
kramdra World Chat Champion
Posted: 17:19 - 04 Aug 2017 Post subject: |
Was going to get the 250rr mot'd tomorrow. Turns over but wouldnt fire, couple months since I started her, Im guessing the carbs are full of shit
Instead got the front off the CBR6 to fit new fairing bracket. The original is rusty and probably bent. |
Wheezybiker |
Wheezybiker Nitrous Nuisance
Posted: 11:28 - 05 Aug 2017 Post subject: |
Not on the bike but for the bike
Installed my ground anchor dug the hole a smidge on the large side took 40kg of concrete to fill it
Don't think it's coming out |
Kawasaki Jimbo |
pompousporcup... |
Posted: 08:38 - 10 Aug 2017 Post subject: |
gpz900: started rebuilding carb set #2 in case the play in the linkage on set #1 was causing shite.. whilst everything was off i ran a compression test (with some oil down the bores)
1:120
2:170
3:180
4:180
So it was cylinder 1 after all causing the low speed running and popping issues following that i tested the piston heights against each other and piston 1 is 3mm or so lower than the others. I'm guessing a bit of hydro lock was involved under previous ownership ultimately one or more of the rods are bent
Thundercat: Put the fairing on properly and removed the cable ties that were holding it all together. It looks half decent now.. from a distance |
chickenstrip |
chickenstrip Super Spammer
Posted: 18:28 - 10 Aug 2017 Post subject: |
Replaced front pads, as one stupid pad was near to the metal, the others still had a fair bit left No seized pistons Now have "throw you over the handlebars" brakes again
Bought rears today too, will get around to them soon.
Test ride c/o, satis. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
UnspeedySam |
UnspeedySam World Chat Champion
Posted: 19:20 - 10 Aug 2017 Post subject: |
On Monday I got some nearly new Michelin PR4s fitted for £100 at Russ Tyres in Portsmouth.
On Tuesday I serviced the front brake caliper and changed the pads, then failed to dismantle the leaky forks for a rebuild and ordered some new long reach allen head sockets off amazon that aren't made of cheese.
Yesterday I started myself off easy changing the oil and filter then attempted a job that I've always avoided; checking and adjusting valve clearances.
First of all doing this on the Honda Bros 400 involves removing the tank, carbs and partially removing the radiator. Then it's still a mission to remove the front rocker cover. But aside from all of that I somehow managed to monumentally screw it up and now my bike sounds like a tractor.
After some research I think it's because I only used the marks on the flywheel to get the engine in the right position. I should have also checked where the piston was in its stroke. Hopefully I haven't completely buggered my engine; I should have to some time to try again tomorrow.
https://www.bikechatforums.com/download.php?id=100066 ____________________ Riding: Does an Audi estate count?
Fixing: Honda VFR750 RC36 '94 and MZ ETZ 251 '90
Gone: ZZR600 '00, TRX850 '97, RXS100 '93, JS125-6B '07, BMW R1100RS '93, Kawasaki ZX-6R-J2 '01,Honda Bros NT400 NC25 '88 |
M.C |
M.C Super Spammer
UnspeedySam |
Beehive Bedlam |
Posted: 12:16 - 11 Aug 2017 Post subject: |
Got these two replaced before they kill me or cost me 6 points and a fine.
https://i.imgur.com/Z9wZeDm.jpg
PR3's 16K out of the front and 13K out of the rear generally hard riding Monday - Friday.
Decided to try Avon storm 3D's this time.
https://i.imgur.com/BRpPcfG.jpg
I started antagonising them on the way back and they didn't let go. So far so good. |
groovylee |
groovylee World Chat Champion
Posted: 13:43 - 11 Aug 2017 Post subject: |
started to clean the chain on the ninja in readiness for changing the sprocket carrier. spotted a couple of missing rollers. stopped cleaning
new C&S ordered.
I'll get this thing done at some point...... ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 13:52 - 11 Aug 2017 Post subject: |
Tracer1234 wrote: |
Very nice, very nice indeed. How was the ride home? |
The AA van was nice, A/C, comfy seats... ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The Shaggy D.A. |
Posted: 18:27 - 11 Aug 2017 Post subject: |
Sold the 350, will be dropping to off to the new owner tomorrow. Now back down to one bike. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Suntan Sid |
Posted: 10:47 - 12 Aug 2017 Post subject: |
Fitted a new front brake light switch, yesterday.
Today got a fresh MOT, with no advisories, for my 35 year old, built from a box of bits, Honda XL125.
I am NOT disappoint! ____________________ "Everybody needs money, that's why they call it money!" |
UnspeedySam |
Posted: 13:36 - 12 Aug 2017 Post subject: |
Suntan Sid wrote: | Fitted a new front brake light switch, yesterday.
I am NOT disappoint! |
Good job! Not sure I'd be brave enough to try that...
The Honda Bros 400 now has valve clearances that are correct. I'm quite pleased with myself.
Although now I've ridden it, I might have to get some more Brembo sintered pads for it. The EBC normal ones are a bit rubbish. Maybe they just need wearing in though.
Also ordered myself some nasty chinese pod filters. The rubbers that connect the airbox to the carbs have completely had it, and I can't seem to source new ones. ____________________ Riding: Does an Audi estate count?
haroman666 |
haroman666 World Chat Champion
chickenstrip |
Posted: 15:13 - 12 Aug 2017 Post subject: |
pompousporcupine wrote: | gpz900: started rebuilding carb set #2 in case the play in the linkage on set #1 was causing shite.. whilst everything was off i ran a compression test (with some oil down the bores)
1:120
2:170
3:180
4:180
Oh dear.
But otoh, perfect opportunity to fit a ZZR1100 lump? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
The last post was made 6 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
