How to corner
Mr Pants!
I Karma
PostPosted: 17:34 - 25 Jul 2004    Post subject: How to corner Reply with quote
I was reading Bike this afternoon and there is an interesting article in there on cornering.
You have the racing line, not advisable on the road, then the safe line to come in wide to give yourself maximum view round the corner, once you see your exit you can then adjust your line to exit it nicely.
However, on left hand corners, where you would move out to the white line, there is another risk. Idiot car drivers cutting the corner and actually crossing the line. So where should you position yourself?
They monitored a corner, notorious for people cutting it and they said it seemed that the bigger the vehicle, the more they cut the bend.
There is a road near me with a nasty corner, called Yately Road, which then becomes Sandhurst road. Everyone cuts it in there cars, lorries, vans etc.
My line is tight into the kerb and very slow to get round it safely, if I took the text book road riding line, I would not live much longer!
The magazine said that cornering is about taking all the aspects into account. This is one area I had not really considered. Worth noting!
Has anyone come across this issue on corners before?
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
Sparks!
Sir Tart-a-lot
PostPosted: 17:38 - 25 Jul 2004    Post subject: Reply with quote
I can't say I've thought of that, but have now Thumbs Up
Me and a mate took some very very tight twisty country lanes on the way back from a supermoto race last weekend, he's a copper and I assume he's done advanced riding, following his line taught me a LOT... my tyres are relatively new and I've only done motorway stuff on them so big chicken strips Confused But after following his lines, maximising vision etc out of corners and lining up nicely for the next ones.. the right side chicken strip is gone and left has halved in size Cool OK that's not exactly difficult but goes to show that IMO the "police" style lines through bends is the better lines for road riding.
He was very quick through them, despite barely speeding over the limit.. he just "flowed" and made it look easy. Respect Mr. Green
So yeah, I think the police style is better and take every corner for what it is, not based on a text book style Thumbs Up
skyline
PostPosted: 17:45 - 25 Jul 2004    Post subject: Reply with quote
the probeblem with keeping a tight line round a left hand bend is the fact if there is a parked car round then, then you are just as fooked :/ i just take every corner like there is a parked car and a car will also cut the corner so i'm always prepared for more or less whats coming
Spiral
PostPosted: 17:51 - 25 Jul 2004    Post subject: Reply with quote
I see the points made do make a lot of sense, It doesn't really matter on the road how good a rider you are, in some situations its better to be safe than sorry.
I have been looking out for any articles on rear wheel steering and was just wondering if anyone has seen any recently?
Though this month in bike magazine there is an article on brakes/pads and one called operation overtake heres a quote,
"While overtaking on the roads is about accelerating,on the track it's more often about braking" Thumbs Up
****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.***
PostPosted: 17:57 - 25 Jul 2004    Post subject: Re: How to corner Reply with quote
Out in the middle of the road, just like they said. The car may cross the line, but your positioning and the fact that you are watching the vanishing point means you can see it earlier and take evasive action (you have the whole width of your lane to play with).
Anything else could see you entering a tightening corner next to the verge and being forced wide as it tightens...right into the path of the corner cutting vehicle. Shocked
Mr C
PostPosted: 22:35 - 25 Jul 2004    Post subject: Reply with quote
it all depends on the corner
whatever, the racing line is not usually the best line to take, unless you have totally clear visibility which is not often as using the racing line leaves you with no margin for error
on a left you should aim to approach with as much visibility as is safe and practical for that corner, on a wide open sweeper, you can be at the line as long as there is no traffic coming, then tip in later than you would on the racing line and follow the line of the nearside of the road
on lefts, you should be aiming to always exit on the left of your lane as this is the tightest line and gives you the freedom then to use the whole rest of the lane as necessary, depending on what you find when you get round it
as bends tighten up then you need to really approach them away from the centre line- going further away as bends get tighter, precisely because cars, other bikes and especially large vehicles will cross the centre line and you don't want to have to take avoiding action, it's better just not to be there in the first place
for rights you should approach from the left of your lane and follow the same procedure, get a good view - tip in and aim to exit on the white line
again, if there is oncoming traffic this gives you the opportunity to use more of the lane and exit further left away from the hazard as it is the tightest line, moving left away from the line is actually making the corner easier - if you are aiming to exit left you are already on the maximum radius for the corner and trying to avoid a hazard from this position requires that you tip in even more
the other advantage that this system gives you over the racing line is that it sets you up 90% of the time for the next corner - most lefts on the road will be followed by a right and vice versa so exiting a left on the left puts you in the correct position for entering the next right etc. - not always but more often than not
also of course, you shouldn't be carrying so much corner speed into blind corners that you can't stop in the distance you can see regardless
vanishing point is fine in theory but it just tells you how fast you CAN negotiate a corner - not how fast you SHOULD do it
none of this is described like this in "Roadcraft" by the way, but it is how the Police are taught as far as I know
sound about right T.C.?
187.3bhp = 201mph
billy whizz
PostPosted: 22:55 - 25 Jul 2004    Post subject: Reply with quote
Some advanced riders use a system called "offsiding" on left handers, i do sometimes but only on roads i know well. For more details on this manouvre speak to your local advanced motorcycle group. But best advice take your advanced test first, you get quicker without riding faster and your insurance drops! Wink
Here comes the summer! Smile
Mr C
PostPosted: 23:21 - 25 Jul 2004    Post subject: Reply with quote
Afaik they don't teach offsiding anymore
average riders just aren't smart enough to know when it's safe to use it
again afaik it's a Rospa fail and probably IAM too
although I have been encouraged by Police riders to do it you really do need to be absolutely sure
187.3bhp = 201mph
billy whizz
PostPosted: 23:23 - 25 Jul 2004    Post subject: Reply with quote
How come i passed IAM last year and they taught me offsiding!??
Mr C
PostPosted: 23:24 - 25 Jul 2004    Post subject: Reply with quote
ah ok
it must just be Rospa then
187.3bhp = 201mph
AcIdBuRnZ
PostPosted: 23:27 - 25 Jul 2004    Post subject: Reply with quote
Well, if you ride thinking that there *might* be a car parked around the corner (ok - in a town you should expect this, but not on country roads) then you'll never enjoy riding - you'll be too worried about what *might* be there.
As good a rider as you could be - you will NEVER account for every hazard/situation. Sorry. You just won't - if you could then no one would ever have an accident.
So, if you don't ride a racing line and you don't take a tight line - where the hell do you position yourself??? Rolling Eyes
Just enjoy riding and stop worrying too much - you can only react to a situation as/when it arises - hopefully good road sense and positioning will see you through it Thumbs Up
Mark
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
Inglesina94
Billy Whizz ... obviously you are much better than average Wink
Dance! Dance! Dance! Passed my DAS - Third time lucky!!!!
Naked Bandit 600 ... Beautiful!!!
billy whizz
PostPosted: 23:30 - 25 Jul 2004    Post subject: Reply with quote
Yeah i hear Rospa is quite tricky, incidentaly my IAM test examiner was a Police motorcycle instructor. He turned up on an old clapped out BMW and i could not lose him no matter what i did! Thought he was reading my mind Shocked Spooky Laughing
billy whizz
PostPosted: 23:33 - 25 Jul 2004    Post subject: Reply with quote
Dunno what do you think? you've been on the back once or twice Laughing
Inglesina94
PostPosted: 23:38 - 25 Jul 2004    Post subject: Reply with quote
mmm ... the best riders I have been pillion to lately ... now don;'t blush too much for the compliment!!
billy whizz
PostPosted: 23:47 - 25 Jul 2004    Post subject: Reply with quote
A classic case of a good bike making up for a crap rider! Laughing
Mr C
PostPosted: 23:49 - 25 Jul 2004    Post subject: Reply with quote
you tried to lose your examiner Shocked
did you still pass?
you also have to requalify with Rospa every two years although the re-test is free
187.3bhp = 201mph
Inglesina94
PostPosted: 23:50 - 25 Jul 2004    Post subject: Reply with quote
Of course it is all in the bike ... when compered to a racing one where my head is way above the rider!! With your bike I can simple relax and enjoy the landscape without getting blown away!!
Davo
Davo To The Rescue!
PostPosted: 01:05 - 26 Jul 2004    Post subject: Reply with quote
One of the guys i work with is a Rospa gold observer (also a police motorcyclist), he rides a cg125, i've seen him on several occasions turn up before people on 1 litre class bikes after a good rideout down the country roads.
I've been out with him a couple of times and it's very helpful watching him riding around, one day i might get that good Thumbs Up
T.C
PostPosted: 09:27 - 26 Jul 2004    Post subject: Reply with quote
Mr C wrote:
ah ok
The official line from all advanced training and testing bodies (including the Police) is that offsiding should be no longer taught for a whole number of reasons not least of which is due to the fact that there have been a number of fatalities as a result of offsiding, and it is only really of benefit when travelling at extreme high speed, mainly because the rider(s) failed to anticipitate the approach of an oncoming vehicle as yet unseen and was unable to regain the nearside in good time.
If someone is interested, I will explain it and if appropriate demonstrate it, but I will not encourage it, centre white line is the maximum width to be used except in exceptional circumstances, and this policy is adopted by 99% although there are still one or two who feel it is OK to do.
If examining, I will not fail someone for offsiding if it is safe and appropriate to the conditions, but generally as I said the centre white line is as far over to the right as most instructors and examiners will want to see.
Mr C, it is a three yearly re-test for RoSPA diploma, gold and silver riders 12 monthly for bronze and unclassified riders.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Mr C
PostPosted: 09:49 - 26 Jul 2004    Post subject: Reply with quote
thanks T.C.
it's always good to have the correct version of stuff Wink Cool
I just wish I could find the time to go and actually finish the bloody training and get the test done Evil or Very Mad
187.3bhp = 201mph
Mr C
PostPosted: 12:00 - 26 Jul 2004    Post subject: Reply with quote
just found this on my desk
from the Roada (Rospa Advanced Drivers Association) Motorcycle Test Guidelines
section on positioning
"When you are riding round bends and corners, and not overtaking, you should not cross marked centre lines and you should not cut corners when entering marked junctions. Roada believes that to do so is potentially dangerous. Such actions may be the result of entering the hazard too fast and may confuse omcoming and following traffic. This view is supported by the Highway Code. If anything untoward happened during such a manouvre the rider may be seen to be at fault and might then blame the RoADA for teaching or condoning this action. If there are no centre markings then some movement over the centre of the road may be acceptable"
187.3bhp = 201mph
map
Mr Calendar
PostPosted: 12:29 - 26 Jul 2004    Post subject: Reply with quote
I found discussion interesting so had a look on the rospa website. Downloaded the motorcycle test guidelines and IMO they read like a 1940/50s government information film (think Harry Enfield - Chumley Warner).
Apologies if OT as regards cornering topic but this bit caught my eye...
While overtaking manoeuvres are inherently dangerous they are a necessary element of
the concept of good progress. However, they must be conducted safely and within
the speed limit.
So if behind a cage doing say 56mph with a clear road in front I shouldn't overtake as that'll take me over the national speed limit?
Seems strange as think Roadcraft encourages making rapid progress when safe to do so. Can others clarify?
Mr C
PostPosted: 13:31 - 26 Jul 2004    Post subject: Reply with quote
nothing
but nothing
anywhere official will condone exceeding the speed limit
this is not what "making good progress" means
it's a common misconception about advanced riding that it is all dayglo vests and pottering about
well learning may be and the test may be but what it allows you to do is systematically assess hazards in a way that allows you to deal with them so that on the odd occasion where you may find yourself exceeding the speed limit Wink Very Happy you are in a bigger bubble of safety because you are (subconsciously if you are really good) applying a system which has been proven to work and developed over many years
of course no official document or training will encourage you to break the law Rolling Eyes
187.3bhp = 201mph
map
Mr Calendar
PostPosted: 13:52 - 26 Jul 2004    Post subject: Reply with quote
Mr C wrote:
...it's a common misconception about advanced riding that it is all dayglo vests and pottering about
well learning may be and the test may be...
So it is about dayglo vests then! Confused Rolling Eyes Wink
The last post was made 20 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 140.65 Kb
