2 STROKE ENGINE OIL CONTEST
Jaguar This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
uberkron
PostPosted: 01:27 - 28 Sep 2018    Post subject: Reply with quote
I pre mix 50:1 penrite green keepers oil.
In a 50cc that gets high rpm use.
Who cares?
i ride a zip 50 2smoke. It overtakes a hundred times a day.
redeem ouzzer
PostPosted: 04:15 - 28 Sep 2018    Post subject: Reply with quote
More over complex bullshit.
Run everything 30:1 on modern fully synth. Worry about other things.
Be a REAL MAN!
thx1138
PostPosted: 09:20 - 28 Sep 2018    Post subject: Reply with quote
I dont understand techno gubbins i just pour putoline mx 2t oil into the oil tank
Monkeywrenche...
PostPosted: 09:41 - 28 Sep 2018    Post subject: Reply with quote
Jaguar wrote:
Examples of my calculators trueness:
fully synthetic oil:
Motul recommends their 800 Off Road be used at 50:1 and my calculator shows its ratio to be 51:1 for a water cooled engine reving to 12,000 RPM.
I choose 12,000 for extreme use because that is what a modern 125cc revs to. And the oil manufacturers usually recommend a racing oil at a ratio that will protect an extreme motocross engine such as a 125cc.
synthetic/mineral blends:
Golden SX2 is recommended at 32:1 and my calculator shows that same ratio for a water cooled engine up to 12000 RPM.
Golden Spectro is recommended at 42:1 and my calculator shows exactly that for a water cooled engine up to 12000 RPM.
mineral oil:
Spectro 2T is not advertised as a racing oil but something that can be used in oil injector systems so we can say it is for up to 10,000 RPM at the recommended ratio of 32:1 which is exactly what my calculator shows for it at 10,000 RPM.
Soooo what you're saying is......just use the manufacturers recommendations, they are right anyway Rolling Eyes
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
blurredman
PostPosted: 14:57 - 28 Sep 2018    Post subject: Reply with quote
I use the cheapest bulk buying mineral oil at 30:1 or whatever it ends up being. I don't measure anything. I just chuck a pint in per tank.
Been fine for 15,000 miles.
PostPosted: 17:29 - 28 Sep 2018    Post subject: Reply with quote
You will provide a BCF discount?
PostPosted: 18:30 - 28 Sep 2018    Post subject: Reply with quote
And the BCF discount?
weasley
Jaguar wrote:
I'm going to contact Castrol and ask them up to what RPM it's good for.
I’ve never seen an oil rated to a specific engine speed, it’ll be interesting to see what they say. Mr. Green
weasley
PostPosted: 18:38 - 28 Sep 2018    Post subject: Re: 2 STROKE ENGINE OIL CONTEST Reply with quote
Jaguar wrote:
How does my oil ratio calculator work? It uses the oils viscosity in combination with the change on it that the estimated upper cylinder temp (estimated by max RPM and type of cylinder cooling) causes and figures out a ratio that results in a target diluted viscosity (diluted by gasoline). This ratio is usually very close to what oil manufacturers recommend.
What diluted viscosity are you using? What level of fuel flash-off do you anticipate? What about the volatility of the oil, where do you get this from and how does this factor in?
PostPosted: 21:12 - 28 Sep 2018    Post subject: Reply with quote
Are you going to provide a BCF discount or do you want to get smacked with many spam ratings?
PostPosted: 21:17 - 28 Sep 2018    Post subject: Reply with quote
So what happens when someone follows your recommendation rather than the manufacturers and the engine goes kablueee?
Are you going to pay for the rebuikd?
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 22:09 - 28 Sep 2018    Post subject: Reply with quote
Just run 1:10 diesel with petrol pre-mix. Thumbs Up
Riejufixing
PostPosted: 23:08 - 28 Sep 2018    Post subject: Reply with quote
Try tractor vaporising oil (TVO).
weasley
PostPosted: 23:33 - 28 Sep 2018    Post subject: Reply with quote
Jaguar wrote:
oils other than group 1 oil have a high flash point so when an oil contains group 1 oil then I factor in to increase the amount of oil a bit. the total volatility of the engine oil is of no concern because a low volatility just indicates presence of solvent. It flashes off and leaves the oil which has good resistance to heat.
Flash point has nothing to do with it. I’m talking about volatility, not flammability. Oils from all groups exhibit volatility when heated, not just group 1.
Besides, oil:fuel ratios are about having the right quantity of oil present. Once the fuel and any solvent and light ends have flashed off, the viscosity is the viscosity - the fuel was just a carrier to get it in there.
struan80
PostPosted: 23:34 - 28 Sep 2018    Post subject: Reply with quote
I want it all I want it now, get given it to me.
Get a cruiser and all will be fine.
stevo as b4
PostPosted: 00:03 - 29 Sep 2018    Post subject: Reply with quote
I don't think many road or track riders especially of classic two strokes are really willing to change or experiment with different oils and ratios to what has worked for them for a long time.
Remember a race bike with a ton of spares and a big budget or a team looking for an advantage over the almost identical next team might be willing to try these things or experiment further than most. A piston or engine failure and or a race win are closely related at the extreme end of racing.
As for the pipe software you have got/developed and proven. Well I've never looked at it or used it to try and design a very good pipe for one of my bikes. I'd love to have the ideal pipe for my needs for every bike I own but it's not that simple.
Im not a two stroke tuner or profess to know anything about the subject so I'm not confident or convinced that I know what to key into a programme with no experience to get a pipe design spat out that I know will work well.
I've recently paid over £300 to have a custom 125 pipe designed and simulated and expertly cut out, shaped, joined and welded up for me and done to a very high aesthetic standard too. It was worth every penny of that when you think of what's involved in doing it and the knowledge and know how that goes into it.
Ive heard that my tuner uses a very expensive full engine simulation package and I believe that my pipe is going to get everything usable and worth having out of my engine. None of this software or programs are worth having without someone who knows what to do with them, and has experience and dyno proven knowledge of how to use them and get results. That's why I went to a highly regarded tuner and pipe builder.
struan80
PostPosted: 00:47 - 29 Sep 2018    Post subject: Reply with quote
Is Stevo Tef in disguise?
The last post was made 7 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 132.44 Kb
