Motorcycle Physics
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
PostPosted: 13:20 - 28 Apr 2020    Post subject: Motorcycle Physics Reply with quote
On a whim I thought I'd have a little play with Unity. All the scripting is C# and it plays nicely with Visual Studio so I thought "well I'm half way there, how hard can it be?" Very Happy
A good chunk of physics - gravity, drag, etc. - is built in. So I thought I'd have a go at simulating a motorcycle Shocked
I'm starting to glaze over a little reading this:
https://en.wikipedia.org/wiki/Bicycle_and_motorcycle_dynamics
I'm thinking there could be two approaches:
1) Treat the vehicle as a single body and simulate things like suspension, wheelies & stoppies.
2) Create representations of the components - wheels, suspension, frame, etc. - which individually have relatively simple physics, bolt them all together and see what the physics engine does with it all.
PostPosted: 13:55 - 28 Apr 2020    Post subject: Re: Motorcycle Physics Reply with quote
QWOP for motorcycles.
Lord Percy
PostPosted: 14:23 - 28 Apr 2020    Post subject: Reply with quote
It would definitely be quicker to simulate all the bits on a single motorcycle shaped block, and is possible to do it with a sense of realism too.
A motorcycle has the following main forces acting on it:
1. Driving force (happening at the point where the wheel and ground are in contact)
2. Weight
3. Normal/"Reaction" force
3. Friction (happening in the opposite direction to force 1)
4. Wind Resistance (happening in the opposite direction to force 1)
You simply ("simply") need to calculate the resultant direction of motion based on each of those things (and lots of other things if you want to add realism, but best to start with as spherical a cow as possible Very Happy).
The motorbike can be a solid block, for all it cares. Everything happens in the maths.
PostPosted: 14:24 - 28 Apr 2020    Post subject: Reply with quote
Maybe. A wheel is quite straightforward in itself (with regards to physical forces) but then you have the contact patch, the wheel bearing, the interaction with the forks... and that's just the front wheel!
Hmmm.... Thinking
Rather than "run before you can walk" I'll start with something a bit simpler: a unicycle simulation. Left controller stick can shift your balance (centre of gravity) and right for movement. The whole "upside down pendulum" thing.
weasley
PostPosted: 14:36 - 28 Apr 2020    Post subject: Reply with quote
You can probably break it down to a smaller number of simplified parts and forces:
- wheels; driving (rear) and braking (both) torque, inertia/momentum, tyre-to-surface friction
- chassis/engine & rider: centre-of-mass, inertia/momentum, aero drag
- suspension; spring rates, damping rates, wheel movement direction, unsprung inertia/momentum?
- engine/transmission; torque curve at rear wheel.
S'funny, the more you think about it the more complicated it gets. Maybe start simple and then try to sub-divide each component further to refine the model.
- This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Lord Percy
PostPosted: 14:56 - 28 Apr 2020    Post subject: Reply with quote
- wrote:
By "Weight" you mean gravity, (weight is not a force),
What about the gyroscopic force keeping it upright?
No, weight is a force. Gravity is the acceleration caused by a gravitational field, and the resultant force felt by objects in the field is called weight.
F = ma
W = mg
Gyroscopic forces are the "lots of other things" I mentioned which aren't strictly necessary in the first instance. To start with you can just program something that simply goes forward and turns depending on the lean you give it.
Lord Percy
PostPosted: 15:04 - 28 Apr 2020    Post subject: Reply with quote
Yep and you could include all that in the code without adding any finicky moving parts to Unity.
Something like:
Code:
double GetForce()
    return force - contactFriction - bearingFriction - forksInteraction; //..etc etc... subtract anything that removes energy from the system
But that's needless complexity for now.
Sounds like a really interesting project anyway. I started a physics thing over the weekend using SFML, having a go at simulating orbital mechanics. It's an easy one really but I've done cooler stuff in the past. My favourite was a fluid dynamics sim I made Very Happy
- This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Lord Percy
PostPosted: 15:09 - 28 Apr 2020    Post subject: Reply with quote
Laughing mpd gave me a downvote for correcting him Laughing
Don't even bother you thick cunt, you've ruined enough threads and you are absolutely categorically wrong here. Don't even try Laughing
PostPosted: 15:21 - 28 Apr 2020    Post subject: Reply with quote
I started with a squashed sphere (bit like a wheel) added a stick and another sphere on top (vague unicycle shape) and swapped the X/Y directional translation for a propulsion/rotation sort of thing and the thing "drives" around and eventually topples over! Now I'm going to try add add a "balancing force" from the other controller stick... fascinating stuff Smile
bhinso
PostPosted: 16:09 - 28 Apr 2020    Post subject: Reply with quote
This is my sort of thread.
Lord Percy is correct about Weight being a force so I'm not sure why the Donking.
It comes down to Vectors and Scalars. Scalars have magnitude only, Vectors have magnitude and direction.
Mass is a Scalar, it has only magnitude, eg. 100kg. It is a measure of the amount of molecules (matter) in the body.
Weight is a Vector, it is the force resulting from the application of gravity on said mass.
When astronauts go into space they become weightless but not massless. The amount of matter in their body is still the same, and they would still be injured if they crashed into things.
kolu
PostPosted: 17:03 - 28 Apr 2020    Post subject: Reply with quote
- wrote:
Oh fuck me, here we go again... Laughing
The weight of an object is the force of gravity on the object
Do not confuse weight with mass.
PostPosted: 17:12 - 28 Apr 2020    Post subject: Reply with quote
Can it do gyroscopic precession and camber thrust?
weasley
PostPosted: 17:18 - 28 Apr 2020    Post subject: Reply with quote
Can it do wheelies and burnouts?
PostPosted: 17:25 - 28 Apr 2020    Post subject: Reply with quote
Oooh! Wheel colliders Smile They have suspension (with damping) forward and sideways friction.
I stuck two under a box and if you turn the wheel left the "bike" tips right. Countersteering!
bhinso
PostPosted: 15:28 - 29 Apr 2020    Post subject: Reply with quote
I've been Donked Sad
Which part of what I wrote do you disagree with? It's Newton's second law of motion, F=ma
xX-Alex-Xx
PostPosted: 15:47 - 29 Apr 2020    Post subject: Reply with quote
Fuck that, will it blend?
DILLIGAF
PostPosted: 15:50 - 29 Apr 2020    Post subject: Reply with quote
Had a good play with the physics. You can apply forces, rotational torque, change centre of mass, all sorts! TBH I think I've gone completely through the looking glass when terms like "Quaternion" and "Euler Angles" are casual parlance on the Unity forums - I can just about handle Vectors Smile
Found a nice GitHub example:
https://github.com/Kright/MotorcyclePhysics
It's not a true representation but the bike does lean as it turns. You can turn too sharp and lowside it. You can come to a stop and it wobbles and falls over. Quite satisfying how the bike dives when you brake.
Long term I'm thinking of one of those apocalyptic "endless road" type games but with bikes.
PostPosted: 13:34 - 30 Apr 2020    Post subject: Reply with quote
Here's a bike that zooms about:
https://send.firefox.com/download/fee24170e02b5baa/#vVoqTV-16FWK7rKhWct05A
You'll need an XBox style controller.
Left Trigger: linked braking - 80% front, 30% back, proportional
Left Button: instant 90% front brake
Right Button: instant 50% back brake
Right Trigger: throttle, proportional
Left Stick: steering
Keyboard Backspace: reset bike (sometimes)
Keyboard C: camera change
What I'm happy with: front forks dive in quite a satisfying way Smile
What I'm not happy with: swing arm is fake. The rear wheel is actually attached to the main frame (via invisible shocks) in the same way the front wheel is. It therefore moves up and down in a straight line rather than rotating around the swing arm bearing Sad
Still working on it: the bike turns and leans and lowsides quite well <30mph. Over 30mph it starts to get tank-slap and go a bit mad. There's still lots of things to tweak though, almost anything you could think of that's in real world is here; barely scratched the surface!
PostPosted: 00:40 - 01 May 2020    Post subject: Reply with quote
Fixed the swing arm. I did try and make a "real" swing arm but it was starting to get fiendishly complicated with hinges and springs. Instead I did the decent thing and cheated. I adjusted the angle of the rear (virtual) shock so the angular effect is barely noticeable. The swing arm just rotates to "look" at the rear hub. So that mean's the bike's going to be a twin-shock Smile
Might upload a new version tomorrow, depends if it's sunny out Very Happy
Lord Percy
PostPosted: 09:25 - 01 May 2020    Post subject: Reply with quote
That's way better than I'd have expected in such a short time, cool!
Which bits did you have to do entirely yourself, and which bits were set up for you?
PostPosted: 12:26 - 01 May 2020    Post subject: Reply with quote
Basically: user input + maths goes into the wheel colliders. The collider reactions go into more maths to feed back into the model (e.g. rotate the front wheel in two axis but the wheel hub in only one...)
So I have to provide the maths "glue" and the models. Unity provides the physics: "Oh, you want to apply 100Nm of torque to this motor? Let's see how that turns out..." and it weighs up drag, friction, gravity, interaction of materials, etc.
The Wheel Colliders are a "black box" convenience item which a purist would replace with hinges and springs for something like single wishbone suspension (i.e. a swing arm.)
PostPosted: 16:11 - 02 May 2020    Post subject: Reply with quote
Version 2:
https://send.firefox.com/download/011bf7bd923f6a05/#JlQprkNiI1jNRf6XTMOiWQ
Quick video if you don't have a gamepad:
https://img.youtube.com/vi/QzdsUaaO_us/0.jpg
Changes:
Swing arm + rear suspension working. Admittedly the suspension is a bit exaggerated but it looks kewl Smile
Pick Up Bike is now Fire1 (XBox A)
Cam Switch is Fire2 (XBox B)
Mouse moves the camera in View 1
Right stick throws some simple torque in the mix to get a bit of lean on (or shift your weight over the front wheel)
Travelling at walking pace drops the centre of mass below the ground to simulate "foot down" but this is a cheap trick / shortcut just for now
Added a jump. Air stability is zero so you'll be lucky to land it even with some appropriate lean - you have been warned Smile
PostPosted: 20:31 - 03 May 2020    Post subject: Reply with quote
The handling might be a bit shit but I'm happy with the mechanics: swing arm, suspension, steering.
Knocked this up this afternoon in Blender:
https://i.imgur.com/iIpdSOy.png?1
The last post was made 6 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 135.41 Kb
