Why are speedos inaccurate?
tokarev
PostPosted: 22:35 - 09 Sep 2005    Post subject: Why are speedos inaccurate? Reply with quote
I was just wondering.
How is it possible for NASA to land men on the moon in the SIXTIES (1969 to be exact), but it is so hard for large manufacturers such as Honda, Yamaha etc... in this day and age to create a mechanism to read the speed accurately? I hear lot's about a 10% or maybe even more inaccuracy in the speedos of recently made bikes.
I'm not talking about GPS sytems, just the normal speedos that come with the bikes.
Rookie
PostPosted: 22:38 - 09 Sep 2005    Post subject: Reply with quote
It only happens to that extent with 50ccs - bikes which aren't aupposed to go over 32mph anyway, and they only get inaccurate above a certain speed.
Yamaha and Honda don't have the technology that NASA do? And rockets don't require speedos? Wink
freestyler_onli
PostPosted: 22:39 - 09 Sep 2005    Post subject: Reply with quote
It's funny you should say this:
Im on my gixxer earlier and im only doing 32, but it seems more like 55/60 Confused
Paracaine
Fuck knows, let's slap them.
Bike: Suzuki Bandit 600, 2002, Blue
Type: Unfaired
Extras: Datatool Alarm & Immobiliser, Airblade Tinted Fly Screen, Motrax Crash Protectors
McGee
O RLY?
PostPosted: 22:40 - 09 Sep 2005    Post subject: Reply with quote
I find like -1 on the back and +2 on the front mess things up with speed summit bad. Going 70 but it reads 100.
Its pronounced Jixxer!
Rookie
PostPosted: 22:41 - 09 Sep 2005    Post subject: Reply with quote
What do you mean McGee?
tokarev
PostPosted: 22:43 - 09 Sep 2005    Post subject: Reply with quote
I was just trying to highlight a complex problem that has been solved (in the sixties) to a what seems a more simple problem (the speedo innaccuracy prob) still about to this day.
I wasn't saying that rockets have speedos. Laughing
Paracaine
I think he means he has changed the sprockets.
Type: Unfaired
Bendy
Mrs Sensible
So people can brag more.
Rookie
PostPosted: 22:48 - 09 Sep 2005    Post subject: Reply with quote
Laughing And swell the already oversized heads of ped bois!
'My ped hit 79mph last night!'
edit: Raises a good point actually, if people think they are going faster on a bike than they really are, the bike gets more praise and the manufacturer makes more sales.
McGee
O RLY?
PostPosted: 22:49 - 09 Sep 2005    Post subject: Reply with quote
Yeah the sprokets also makes the mileage climb and climb. And i done it for about a week for more ummph from pull off didnt make a big difference that was on my first 600, my cbr.
*Let me correct my self in no way does it increase bhp it makes acceleration quicker.*
Paracaine
Yeah, and "I got 120 out of my RS25 on the flat!!"
Type: Unfaired
muddycoffee
PostPosted: 23:37 - 09 Sep 2005    Post subject: Reply with quote
I think that Bike Speedos alway read over because it's not a very accurate method. The old fashioned mechanical speedo with a square rod connecting a flywheel inside the speedo dial to a gear in the wheel, rely on a spinning flywheel, and it tends to overspin by a few percent at 70mph with the momentum, but they are usually farely accurate at 30mph.
Newer bikes tend to have an electonic pickup and cable instead of a mechanical method. I would expect these to be more accurate, but it seems they also read over a tiny bit too..
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
mattfuzzy
PostPosted: 00:17 - 10 Sep 2005    Post subject: Reply with quote
first off, they never landed on the moon, that was just a stunt to try and make the americans win the space race between the russians and americans. (not that you need speedos on the moon Mr. Green)
second, speedos over read if say you got a bike thats not capable of doing 120 but modified it to do 150 without upgrading the speedo, trying to make the bike go over the speed it wasent designed for will make it over read and inacurate, atleast thats wat i was told.
PostPosted: 00:22 - 10 Sep 2005    Post subject: Reply with quote
Speedos are allowed to read up to 10% high but are not allowed to read low.
Most work based on how quickly the wheel is turning. Different makes of tyres, differently worn tyres, different loads, tyre deformation with speed, etc, all affect how far the wheel travels in one rotation so they are never going to be that accurate. And there is not much need for them to be that accurate.
Speedos are all over the place. I know that the Bandit at an accurate 166.2 was indicating around where 180mph would have been on the speedo. Silvers GSXR750 at the same event was (from memory) pegged at 186mph for quite a while but still accelerating and eventually getting to a real 171.x .
Bendy
Mrs Sensible
PostPosted: 00:33 - 10 Sep 2005    Post subject: Reply with quote
The sprocket thing is a lot more simple than you lot are making out. Smile
A lot of bikes have a speedo that reads from the front sprocket. The speedo is programmed to think the sprockets on the bike are the size they were when it left the factory. If you change these sizes, it throws your speedo out of whack, over-reading if you downgeared it, under-reading if you upgeared it.
So what you do is fit a gadget like a speedohealer or a yellow box, which lets you program in what gearing ratio you are using and should bring everything back into line. Equally, you can use one of these devices even if you haven't changed the gearing, just to tweak the accuracy of your speedo and eliminate the over-reading.
Of course, if your speedo reads from the front wheel, you can mess with the sprockets all you like, it'll have no effect.
gavin
PostPosted: 00:36 - 10 Sep 2005    Post subject: Reply with quote
.......for the same reason that rev counters over read and manufacturers BHP figures are always very optimistic.
all by the same percentage, i might add. its marketing hype.
i recently saw a standard 8,000 mile yamaha rd350ypvs on a dyno thats not known for being stingy. everyone "knows" they make 55-60bhp and do about 120mph.
well this one, ( and four others we tried on the same day! ) made 35rwhp. just for a laugh we wound it up in top on the dyno, it went off past the redline and was showing about 135mph on the dyno's speedo. in the real world that would probably be around about 120 on the clock on the road, which is probably about 108mph in reality. Laughing
same as 190 odd on your R1's speedo is more like 170........
Mr noOdles
PostPosted: 01:16 - 10 Sep 2005    Post subject: Re: Why are speedos inaccurate? Reply with quote
actually people said that was a consipricy theory, that landing on the moon will be impossible......just to let you know Rolling Eyes
i wouldn't believe in what the yankie say, after all the brit discovered the speed of sound but the american nicked the idea if you like Mr. Green
Rookie
PostPosted: 01:23 - 10 Sep 2005    Post subject: Reply with quote
Oh God, we're on to moon landing conspiracy theories?! Rolling Eyes
I don't care whether they did or not, it's all in the past. Smile
tokarev
PostPosted: 01:25 - 10 Sep 2005    Post subject: Reply with quote
I see, so there are many variables affecting the the wheel travel and hence the speedometer is also affected.
OT;
I am aware of this. It is still a theory though. I believe the Japs are sending a Satellite to take images of the moons surface soon. We shall have to wait and see.
Mr noOdles
PostPosted: 03:00 - 10 Sep 2005    Post subject: Reply with quote
well i think that speedo arent accurate because every living soul on this planet will break the speed limit.
i think the manufacturer play a little mind game by making speedo read higher,
e.g you are doing 50mph (speedo reading) where infact you r doing 48mph
so who no, that 2mph might save some one live Wink
well that what i think anyway Mr. Green Thumbs Up
Mr C
PostPosted: 03:24 - 10 Sep 2005    Post subject: Reply with quote
I've said this before mine under reads
it only goes up to 190mph and I've had tickets for loads more than that Rolling Eyes
187.3bhp = 201mph
kawashima
PostPosted: 03:27 - 10 Sep 2005    Post subject: Reply with quote
My ex bike was made in thailand(LS125) and had a terribly happy meter. I received a response from LS owner in thailand in this thread who had believed that LS speedo is accurate speed.
Then I felt Honda does this for giving dream to young people in thailand.
Dotzler
PostPosted: 10:00 - 10 Sep 2005    Post subject: Reply with quote
I would say that the 10% innacuracy in the speedo is down to one thing only! Cost. There is no need for a manufacturer to make a speedo that is accurate to within +/- 0.1Mph as this would make it far too expensive to manufacture, test, calibrate regularly.
The bike companies probably buy the speedos from a sub contractor and put very aggresive cost targets on the parts, but they will also probably specify the accuracy of the part too.
Make the part as cheap as possible, with a tolerable accuracy, and that will be enough. Over engineering adds cost.
sickpup
Old Timer
PostPosted: 10:39 - 10 Sep 2005    Post subject: Reply with quote
Do you by anychance have a copy of the construction and use regs that state this?
The last post was made 20 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 130.7 Kb
