Suzuki RG125UN wolf project MK2.
GSTEEL32
PostPosted: 20:25 - 20 Sep 2014    Post subject: Reply with quote
Engine in the kitchen....... Frame in the Lounge....
Its a shame we can only give Karma, rather than Man Points.....
BenR
PostPosted: 18:16 - 22 Sep 2014    Post subject: Reply with quote
So some more progress today as I'm off work I thought I'd get some more bits painted. I started with the front mudguard mounting plate. Originally I had this powder coated satin black but When I stripped the bike I ended up having to grind the original bolts off & when I got it back from the coaters you could see grinding marks/indents on it. So I rubbed it down filled it up & spayed it chrome as I think the bike will have enough black on it.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1753.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1754.jpg
I also did the radiator caps at the same time as these were damaged with some nasty gouges in. I didn't get a before shot.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1755.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1756.jpg
I fitted the foot pegs & brake/gear levers. Also fitted the inner splash shield & CDI & fitted the coil, reg/rec & PV servo.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1757.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1758.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1759.jpg
A friend of mine owns his own shot blasting & powder coating business & very kindly allowed me to use one of his booths today so I could paint the wheels.
A coat of etching primer followed by 4 coats of proper 2k high build primer.
https://i59.photobucket.com/albums/g308/bennyboy73/IMG_0044.jpg
A good flat down then paint.
https://i59.photobucket.com/albums/g308/bennyboy73/IMG_0045.jpg
Finally a couple of coats of proper 2k lacquer.
https://i59.photobucket.com/albums/g308/bennyboy73/IMG_0046.jpg
Just_James
PostPosted: 20:40 - 22 Sep 2014    Post subject: Reply with quote
This is coming on really nicely! Thumbs Up
The painted bits look great. What colour have you gone for on the wheels? A little hard to tell on the pics if it's just black or is it more of an anthracite colour?
.... I take it you have checked it will fit through the doorways etc to get out of your front room when you're done? Laughing Laughing
BenR
PostPosted: 21:47 - 22 Sep 2014    Post subject: Reply with quote
The wheels are graphite/anthracite the colour is called grigio lothar or lothar grey it's an alfa romeo colour that we used to do the roofs of the SZ coupes in. No problems with getting the bike out the door & down the stairs I did the last one in my lounge as well.
BenR
PostPosted: 20:40 - 05 Oct 2014    Post subject: Reply with quote
Hi all quite a major update. The bodywork is all repaired & primed & as it was such a lovely day today it was too good not to get some painting done. The colour is VW atlas grey (code LY7Q). Although it's quite an old colour I think it'll make the bike look quite modern. I didn't paint the side panels as I'm still waiting for the decals to be made.
First hit of filler primer.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1760.jpg
For some reason all the shots of the repairs/filler got wiped. Brick Wall But a second hit of filler primer.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1761.jpg
Then flatted down & paint.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1762.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1763.jpg
Decals applied.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1764.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1765.jpg
Then the masking up, you can probably work out where this is going.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1766.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1767.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1770.jpg
Then second colour.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1768.jpg
De-masked.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1769.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1771.jpg
& finally a couple of coats of lacquer.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1772.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1773.jpg
Also painted the brake calipers. The camera flash makes them look very bright but they're actually quite a dull satin red.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1774.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1775.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1776.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1777.jpg
Just got to get the piston & seals out so I can fit the new ones & get some new bleed nipples & covers.
CG Sam
PostPosted: 20:51 - 05 Oct 2014    Post subject: Reply with quote
Wow. That paint job is awesome! Are you using a spray gun and compressor or just spray can?
CG125, SV650S, CBR600F, GSXR600 SRAD
cormac83
PostPosted: 20:52 - 05 Oct 2014    Post subject: Reply with quote
Good job, coming along nicely Very Happy
Suzuki GSX750 Inazuma
BenR
PostPosted: 21:00 - 05 Oct 2014    Post subject: Reply with quote
Hi thanks the brake calipers were out of an aerosol, Halfords do some good rattle can paints. The body work is all proper HS paint & lacquer from out of a gun I wouldn't even try it with aerosols (it's what I do for a living). Smile
stevo as b4
PostPosted: 01:03 - 06 Oct 2014    Post subject: Reply with quote
Dude you need to keep this one! RG125FUN's and Wolfs are too rare to let go now, and they will be by their scarcity one of the expensive 125's when the 125 2stroke price explosion occurs in the nest few years! Original Mito's and TZR125R 4HW's etc will also be rare and priced accordingly.
Don't sell it, or I might have to buy it if you do! Laughing
BenR
PostPosted: 17:30 - 06 Oct 2014    Post subject: Reply with quote
It might be just as well I've got 2 then. Whistle Very Happy
PostPosted: 17:35 - 06 Oct 2014    Post subject: Reply with quote
Either put your camera in Macro mode, or take a step back from what you are shooting. Laughing
CG Sam
PostPosted: 17:40 - 06 Oct 2014    Post subject: Reply with quote
That makes sense then. What's the company? I may be looking to have some paintwork done.
BenR
PostPosted: 17:58 - 06 Oct 2014    Post subject: Reply with quote
Aston Martin, Mclaren, any number of rail companies & a few aerospace ones as well. Wink
CG Sam
PostPosted: 20:44 - 06 Oct 2014    Post subject: Reply with quote
Hmm, I'm sure you'll do for a quick re-spray on my FZR... Laughing
May just ask the place about 120m from my house
BenR
PostPosted: 16:23 - 10 Oct 2014    Post subject: Reply with quote
Final update for a while as I start a new job on Monday 183miles from home, besides I don't have any money left so can't afford the rest of the bits the bike needs at the moment. Things left to buy are brake lines, front brake disc, tyres & a new petrol tank.
I had the tank shotblasted & began trying to remove/pull the dents.
https://i59.photobucket.com/albums/g308/bennyboy73/IMG_0047.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMG_0048.jpg
Unfortunately there wasn't much metal left as the bloody thing has rusted from the inside out so I scrapped it.
This morning it was lovely again & the wind had dropped so I painted the rear panels
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1778.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1781.jpg
Applied the decals.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1780.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1782.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1783.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1784.jpg
Once the money starts coming in again over the next couple of months I'll get everything I need to finish it off.
BenR
PostPosted: 15:45 - 18 Feb 2015    Post subject: Reply with quote
Not much of an update but since the weather has taken a turn for the better I thought I'd make a start on the bike again. Still require quite a few bits but as I still don't have a reliable income I'm not able to purchase the parts I need. The next things will be a front brake disc so I can finish the front wheel & a set of tyres so I can get the bike back onto it's wheels.
Anyway I've painted the blanking ring which goes around the left hand side of the front wheel.
Flatted down:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1814.jpg
Primer:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1816.jpg
Then filler:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1817.jpg
Primed again:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1821.jpg
Flatted down then paint, went for a textured finish:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1825.jpg
Primed the tank:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1819.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1820.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1823.jpg
There were a couple of small dents so a bit of filler & guide coat:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1822.jpg
Flatted it all down then masked the outside up & painted/lacquered the underneath. If it's nice again tomorrow I'll do the top.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1832.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1833.jpg
I've had to buy a new loom, headlight & left hand switch gear. Ended up having to get these parts from the French eBay.
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1835.jpg
I stripped the headlight & had the outer ring shot blasted & powder coated gloss black:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1836.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1837.jpg
That's it for now. I'm aiming to get it done for the summer.
BenR
PostPosted: 18:08 - 21 Feb 2015    Post subject: Reply with quote
Today I painted the tank. It's alright not perfect there are a couple of small bleed throughs as it was a bit cold which lifted the fine line tape.
First coat of paint:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1839.jpg
After another three coats & a final drop coat:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1840.jpg
Applied the decals:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1841.jpg
Masked it up:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1842.jpg
Applied the black:
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1843.jpg
De-masked & a couple of coats of lacquer (between rain showers):
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1844.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1845.jpg
https://i59.photobucket.com/albums/g308/bennyboy73/IMGP1846.jpg
There is a gap of 3 years, 212 days between these two posts...
BenR
PostPosted: 20:32 - 20 Sep 2018    Post subject: Reply with quote
Didn't keep on top of this thread but the bike is on the road but not finished. I still need to make a new bellypan, could do with a UK spec Speedo, buy a new PV servo & get the matching front wheel machined so the disc sits properly.
https://i.postimg.cc/5yBM3rCj/20180624_120506.jpg
https://i.postimg.cc/MpMSTt6c/20180624_120408.jpg
https://i.postimg.cc/zBRbFTF3/20180624_120445.jpg
https://i.postimg.cc/0jdCZG29/20180902_135624.jpg
stevo as b4
PostPosted: 23:20 - 20 Sep 2018    Post subject: Reply with quote
Awesome looking bike! And it's brilliant to get an update after all this time, but much more so that you still own it!
There can't be a nicer Wolf with such a stunning paint job out there! Thumbs Up
Will you get the exhaust high temperature coated eventually like you did on the white one all those years ago?
BenR
PostPosted: 23:51 - 20 Sep 2018    Post subject: Reply with quote
Thanks the exhaust has been coated there's still a little bit to do but I'll probably leave it until the new year now I've got another project to do. Thumbs Up
Kris
PostPosted: 10:48 - 21 Sep 2018    Post subject: Reply with quote
Beautiful Wolf there mate. I loved those bikes as a kid - my first pillion experience was on the back of one getting a ride from my mate's brother. His was black / green.
Ahh nostalgia... Mr. Green
www.prisonplanet.com
Holdawayt
PostPosted: 11:21 - 21 Sep 2018    Post subject: Reply with quote
Bike looks great, what a transformation!
Guessing by your earlier comments a few years ago that you used to work for Akzo Nobel? Suppliers to Aston, McLaren etc. My Mrs works there, apologies if I'm barking up the wrong tree!
BenR
PostPosted: 11:49 - 21 Sep 2018    Post subject: Reply with quote
No I was a paint technician/sub contractor.
bladerunner
PostPosted: 23:47 - 21 Sep 2018    Post subject: Reply with quote
I used to have the 250 wolf..great fun if only 20mph faster than the 125!!
GSTEEL32
PostPosted: 21:26 - 23 Sep 2018    Post subject: Reply with quote
Looks great in that colour.. great effort....
The last post was made 7 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 140.27 Kb
