NEED HELP calling all experts!! 4stroke not running right
ThatDippyTwat
PostPosted: 06:38 - 02 May 2018    Post subject: Reply with quote
Sam12345 wrote:
Iv had a quick look at loom tonight looks ok but would have thought the bike wouldnt run at all if it was experiencing loom problems,
Take a long look. Electrical problems can do/cause weird shit. It took me a while to track mine down, same line of thinking as you had to be fair, that it wouldn't run at all. It may not be, but you're describing exactly what mine had, it was shorting out when it got hot. Your's is doing something silly when wet. If you're sure you've eliminated manifold leaks, valve clearances are set etc, it's going to be electrical.
Sam12345 wrote:
im seriously considering taking my losses and selling it for spares and repairs, not putting any more money into it hence im trying so hard to self diagnose
If you can't be bothered, where are you, how much?
mentalboy
PostPosted: 12:33 - 02 May 2018    Post subject: Reply with quote
Agreed, something as simple as a failing HT lead can give the appearance of a good spark but play havoc with the way your lump runs, or doesn't.
Healthy engines, for all the gizmos attached to them, are fairly simple beasts - too much air, too much fuel (goes without saying lack of one will affect other) or something affecting spark.
If you really have an uncompromised air/fuel delivery system with a good air cleaner and a carb that is set up correctly you are left with electrics. My gut says that if it can handle a load but only if you sneak up on it then something is on it's way out.
Start with LT and HT connections and make sure there isn't any damp in them, if necessary remove HT lead and stick it in the airing cupboard overnight/ through the work day to make sure there is no damp in it,...
Make mine a Corona.
Sam12345
PostPosted: 10:12 - 30 May 2018    Post subject: Reply with quote
Sorry lads forgot to mention i fixed the issue a few weeks back, was the coil breaking down under load thanks for the help!
Sa
jameswilson This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 8 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.5 - MySQL Queries: 15 - Page Size: 40.55 Kb
