 Posted: 10:39 - 16 Aug 2021 Post subject: |
There are places that will fit them for you. It's an easy job if the head is off.
At the end of the day, you'd then have a known good head with known good cams and followers that go with it. I'd go so far as to say a head with plug inserts is better than one without in many ways.
I've seen me fit inserts to brand new parts for my Enfield, pre-empting the alloy stripping out (they have oddball fine threads which aren't well suited to alloy).
While the head is off, worth measuring the camchain to check it's within spec. Have a good look at the coolant hoses while you have the bodywork off and access to them. Likewise fuel lines and control cables. Make sure the exhaust studs are all in good order.
Maybe do the valve stem oil seals? The seals themselves are cheap. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
JackDG |
 JackDG Renault 5 Driver
Nobby the Bastard |
JackDG |
 Posted: 10:23 - 20 Aug 2021 Post subject: |
Perfect, thanks for the confirmation. Gonna be an expert at shimming
oh and I dont need to worry about anything with putting the cam shafts onto a new head? ____________________ 1992 GPZ 500 |
Nobby the Bastard |
JackDG |
 Posted: 19:18 - 09 Sep 2021 Post subject: |
I've heard of people hammering the end of a piece of copper pipe flat and using that as a scraper but I always land up going back to a stanley knife blade with a bit of tape along the back to protect my fingers.
Th etip is if you feel like you are rushing, take a break and do something else for a bit before you gouge lumps out of the alloy. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
A100man |
 A100man World Chat Champion
JackDG |
A100man |
 Posted: 17:26 - 28 Sep 2021 Post subject: |
Good result  ____________________ Now: A100, GT250A, XJ598, FZ750
sickpup |
 sickpup Old Timer
JackDG |
Pete. |
 Pete. Super Spammer
 Posted: 15:37 - 04 Oct 2021 Post subject: |
Helicoils should not let combustion gases past because it's not the helicoil or plug thread that does the sealing, it's the sealing washer on the plug. ____________________ a.k.a 'Geri'
sickpup |
 sickpup Old Timer
Jim Mc |
 Jim Mc Nearly there...
c_dug |
 c_dug Super Spammer
 Posted: 10:17 - 01 Nov 2021 Post subject: |
Pete. wrote: | I'd stick a helicoil in there, and I'd do it in the bike too. Actually I have the kit to do it all in the bike if it's a 10mm thread plug.
There's loads of things you can do to mitigate getting debris in the cylinder ranging from 'don't worry about it' to cramming the hole with greased paper or even using a hoover and thin pipe. Personally I tend to not worry about it, aluminium melts at about 600degC whereas combustion chambers run at 900. Any bits of swarf will melt away into nothing. In fact, anyone who has removed a plug without first blowing the crap out of the plug well has probably done much worse than drop swarf in the hole. |
Bit late to the party, but for those in doubt, Pete. did this to my bike at the side of the road (well, work car park) a few years back and it ran absolutely fine for a good many miles until it was stolen and burned by scumbags. I reckon a solid 10,000 miles post-helicoil with no issues at all. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
The last post was made 3 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
