Unable to remove exhaust header nuts.
Pigeon
PostPosted: 23:09 - 09 Sep 2021    Post subject: Reply with quote
Just out of interest, the pics seem to show the nuts were rusted but still accepting of a socket.
So given the studs ends are corroded, why not just use the locked nut to wind out the exhaust studs?
Were the studs also seized?
sapstar
PostPosted: 12:17 - 11 Sep 2021    Post subject: Reply with quote
The picture was taken as a reference before trying to remove the nuts. I did spray WD40 and wipe out some of the excess rust from the nuts and the bolt. Anyways I ended up getting the work done at a garage now as I didn't want to risk damaging anything.
First/Current Bike - Kawasaki ER-6N
sapstar
PostPosted: 17:50 - 16 Sep 2021    Post subject: Reply with quote
This doesn't seem to be going well at all for me Sad.
I went to the garage today with exhaust gaskets and new nuts (The garage fitted the rusted nuts back last week). They changed the gaskets and were only able to replace 1 nut. For the remaining three, the nuts weren't moving and the whole studs came out... Sad
They finished the job now. No exhaust leak with the gaskets in, and all seems to be working well. But the rusted nuts are still there... Is there any point replacing the studs now?
PostPosted: 21:14 - 16 Sep 2021    Post subject: Reply with quote
Sound like it's bothering you as it would me. Since everything is now 'moving' I'd fit new studs. Make your own from some M8 studding for pennies. Loctite the head end and copperslip the f*ck out of the nut end would be my tactic.
sapstar
PostPosted: 21:29 - 16 Sep 2021    Post subject: Reply with quote
Anyone knows if these are the right studs?
https://www.ebay.co.uk/itm/144136741789?hash=item218f38239d:g:amwAAOSw0S1fQDEA
Would I need to replace the gaskets again to do this job?
PostPosted: 21:41 - 16 Sep 2021    Post subject: Reply with quote
Looks good. It's one of those parts that doesn't change much over the years.
Shouldn't need to do the gaskets if you do them one at a time. Don't over-tighten them!
sapstar
PostPosted: 22:00 - 16 Sep 2021    Post subject: Reply with quote
I found another one on ebay. This one is stainless steel. Cheaper... and probably better...
https://www.ebay.co.uk/itm/372897528675?hash=item56d26cbb63:g:ZMMAAOSwEeFVSyhO
PostPosted: 23:57 - 16 Sep 2021    Post subject: Reply with quote
Nope, stainless undergoes galvanaic corrosion in contact with aluminium alloy and galls the alloy thread. Stick with mild steel and use an anti-seize compound on it.
*awaits shitstorm*
Pete.
PostPosted: 00:27 - 17 Sep 2021    Post subject: Reply with quote
Stainless bolts in Ally head on a Bandit. Snap like twigs if the bike has seen several winters of riding. I once had all eight snap and had to drill them all out.
A4 stainless should stand up better than A2.
a.k.a 'Geri'
Kris
PostPosted: 08:42 - 17 Sep 2021    Post subject: Reply with quote
What about titanium bolts in an ally head? Are they better than OE steel?
www.prisonplanet.com
PostPosted: 18:31 - 17 Sep 2021    Post subject: Reply with quote
Not as strong as (good quality) steel size-for-size, much lighter though. A quick google shows it's also prone to galling threads.
davebike
PostPosted: 07:34 - 18 Sep 2021    Post subject: Reply with quote
NOTHING is better than OEM steel for head to exhaust studs
mild steel is least inclined to stick to the alloy head but fit them with antisize like copper or better alloy slip
Brass nuts are great as an upgrade
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Pete.
PostPosted: 17:16 - 18 Sep 2021    Post subject: Reply with quote
I don't thnk the exhaust would stay on if you just used nothing.
a.k.a 'Geri'
The last post was made 2 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.12 - MySQL Queries: 13 - Page Size: 80.29 Kb
