| Author |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Back to top |
| stinkwheel |
| Back to top |
| jeffyjeff |
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 09:44 - 02 Feb 2023 Post subject: |
| jeffyjeff wrote: |
It seems to me that a discharged capacitor would be a more likely current path than a flat battery. |
Yes far lower internal resistance/impedance.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Back to top |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:24 - 02 Feb 2023 Post subject: |
Voltage Sensitive Relay.
It only triggers after detecting a charging voltage for a few seconds, ie: when it's running. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Back to top |
| stinkwheel |
 Posted: 18:31 - 05 Feb 2023 Post subject: |
Well, I did it again, left the ignition on on my other bullet while I was sat chatting and drinking tea with a mate. It had just enough juice left in it to start and idle but if I increased the revs above idle, it would die. I had a very slow ride home at under 10mph and coasting down hills (thankful for trials gearing which will pull at idle or I'd have had to call for a lift).
Good opportunity to try the capacitor with a flat battery though. Measured 8.5V on the battery, dropping to 4.5V when the points closed which was only just enough to get an idle but immediately died if you increased the revs (presumably the flat battery taking any alternator output leaving nothing for the coil). Fitted a capacitor and after a couple of stutters, it fired up properly and revved normally showing 12.8v in the loom.
Seems like I can safely leave the capacitor in there all the time and it should start on a flat battery. If it doesn't, disconnecting the battery will get me home. The lights will work on this bike too because they are AC on a different phase. It probably doesn't really need a battery at all. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
The last post was made 3 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
