Washing machine not spinning
Bike Chat Forums Index -> Dear Auntie BCF... Goto page Previous  1, 2
PostPosted: 23:39 - 07 Aug 2023    Post subject: Reply with quote
Nobby the Bastard wrote:
You mean the one which isn't at the front near the bottom and absolutely doesn't have have a flap without a rotary cover behind it?
Well, it's been suggested several times and he seems adamant his doesn't have one.
PostPosted: 04:47 - 08 Aug 2023    Post subject: Reply with quote
stinkwheel wrote:
Their wizard wheeze of not putting in an inspection cover to allow foreign bodies to be removed from the pump worked then.
The machines without pump doors probably work on a filtration theory of:
If its not big enough to be stopped by the filter, then it's not going to cause any significant problem passing through.
The inner drum is a type of screen. It stops your soiled panties and stuff being sucked into oblivion.
Oil filters do not stop everything, they only need to stop stuff manufacturer believes can cause damage.
Nothing lasts for ever.
PostPosted: 06:48 - 08 Aug 2023    Post subject: Reply with quote
Well, I can say for a certainty washing machine drums don't stop bobby pins. So where does the bobby pin go after it's through the drum on a machine with no removable filter?
PostPosted: 10:22 - 08 Aug 2023    Post subject: Reply with quote
According to Zanussi stuff gets trapped in a fold of the door seal:
NEWER ZANUSSI WASHING MACHINES NO LONGER HAVE FILTERS ON THE FRONT OF THE MACHINE
There is no longer a filter that needs cleaning in the Zanussi washing machines.
This appliance is designed with a self-cleaning draining system, allowing light fluff fibres that fall off the clothes to be drained out with the water, so there is no need to access this area for regular maintenance and cleaning.
This is thanks to a specific door gasket that has been designed to catch all objects like coins, buttons, hairpins, etc. before they have a chance of getting out of the drum itself and finding their way to the drain area.
https://elxa2blbprd001.blob.core.windows.net/content/1212769/a909e272f9724650a620e3ac4de9eb2b.png
https://www.zanussi.co.uk/support/support-articles/laundry/washing-machines/how-do-i-access-the-filter-on-my-zanussi-washing-machine/
There was fuck all in that pocket when I looked which makes me wonder how effective it is.
Anyhoo, the new washer has a child lock - useful given my youngest granddaughter is 15 months old and running around touching everything - and really, really quiet. Small consolations but it's something. Oh, and there seems to be a little square panel in the bottom right Smile
blurredman
PostPosted: 16:11 - 09 Aug 2023    Post subject: Reply with quote
Is this the situation on driers too? How does that affect people that don't have water drain access? Does the water collection depository just full of a soggy mess of cloth dust?
PostPosted: 18:52 - 09 Aug 2023    Post subject: Reply with quote
Driers usually have a lint trap inside the door. Hot, damp air exits through it and any clothes fibres get trapped.
Vented driers just vent out into the atmosphere so you'd run a big hose from the back to a specific airbrick or even just out the window. Condenser dryers attempt to trap the moisture and you have to empty them out from time to time. I say "attempt" 'cos in my experience they don't always do a great job.
Regardless of the type I'd always try and place a dryer in a garage or shed due to the amount of damp they generate where they're situated.
PostPosted: 19:16 - 09 Aug 2023    Post subject: Reply with quote
My dryer is attached to the fence and is held up with a pole in the middle.
Triumph Sprint ST 1050
to v or not to v
PostPosted: 19:23 - 09 Aug 2023    Post subject: Reply with quote
thats no way to treat the mrs Nobby Mr. Green
Moto Guzzi V7.
Kawasaki Jimbo
PostPosted: 19:38 - 09 Aug 2023    Post subject: Reply with quote
A (DeLonghi) dehumidifier in the spare room does a surprisingly good job drying clothes and even towels. It takes about 6 hours but uses much less electricity than a thermal drier. It also produces about a Litre of deionised water.
PostPosted: 20:42 - 09 Aug 2023    Post subject: Reply with quote
Heat pump driers do what condensing driers claim to do, can be plumbed into the washer drain and do it with a fraction of the energy use.
grr666
PostPosted: 20:58 - 09 Aug 2023    Post subject: Reply with quote
My machine is making a bit of a banging noise on spin. Hope it catches fire. Sad
PostPosted: 10:34 - 10 Aug 2023    Post subject: Reply with quote
Dammit, I knew I missed one Rolling Eyes
PostPosted: 10:37 - 10 Aug 2023    Post subject: Reply with quote
Are you washing and drying bricks again? Laughing
Might be the drum bearing worn out.
PostPosted: 10:55 - 10 Aug 2023    Post subject: Reply with quote
Awaits inevitable reference to Nobby's organic man pole..
grr666
PostPosted: 11:04 - 10 Aug 2023    Post subject: Reply with quote
Probably. Just another expense I could do without.
PostPosted: 11:27 - 10 Aug 2023    Post subject: Reply with quote
Nah, thats for my tent.
PostPosted: 16:04 - 10 Aug 2023    Post subject: Reply with quote
Washing machines are slightly harder to fix IMO down to the mix of electrics and plumbing but if you're talking about a dryer there's fuck all in them and very easy to fix. Even saying that there's a gazillion YouTube videos of people taking about washers and dryers so a little patience (and space) and you'd be fine. Parts are usually pretty cheap - the price of an engineer's all in the callout + labour.
AlexArcvarden This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 17:41 - 09 Oct 2023    Post subject: Reply with quote
https://youtu.be/VsRot0p7ObY?si=tHgkWpjwp-6aunbw
doggone
PostPosted: 18:21 - 09 Oct 2023    Post subject: Reply with quote
A true X files incident which remains unexplained.
https://www.gazetteherald.co.uk/news/16685526.burning-clothes-fell-burning-washing-machine/
PostPosted: 07:53 - 11 Oct 2023    Post subject: Reply with quote
doggone wrote:
I would normally have expected some or all of the answers to 'come out in the wash'.
There is a gap of 267 days between these two posts...
Merdemerey
PostPosted: 05:30 - 05 Jul 2024    Post subject: Reply with quote
Another thing to check is the lid latch. If it's not working, the machine won't spin. Also, make sure the load is balanced. An unbalanced load can cause spinning problems. If you’re not comfortable doing these checks yourself, you can also check out this Refrigerator Repair service in Nashville. They work with washing machines too, and their service is very affordable. Hope this helps!
The last post was made 2 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 126.2 Kb
