Torque wrench calibration
ThunderSteve
PostPosted: 18:07 - 16 Oct 2024    Post subject: Reply with quote
I've done that with a digital scale, and it worked fine for rough checks. Just pull at 90 degrees. For better accuracy or if you use it often, pro calibration might be worth it.
blurredman
PostPosted: 18:16 - 16 Oct 2024    Post subject: Reply with quote
ThunderGuts wrote:
I get the theory (and I'm well aware of the issues with old tyres), but I think I'd rather just stick new rubber on it every 8 years or so than go through the faff of having odd wheels, plus the spare is steel and the main wheels are alloys - I'm fairly sure in my case the carrier will only take the steel wheel due to the shape of it
Depends. I am cheap. Laughing
Currently one of my cars have the low profile 17" alloy wheels at the rear, as I fitted smaller 15" wheels but with taller tyres to the front. The taller tyres are more comfortable and better behaved.
But, on the rear it doesn't matter too much about road tracking and comfort isn't an issue. So why waste good tyres. It looks silly but I don't care - And in March they did, so put the alloy wheels that were on the front to replace the illegal ones on the rear. They'll eventually run to the minimum bars. Laughing Laughing
ThunderGuts
PostPosted: 20:26 - 21 Oct 2024    Post subject: Reply with quote
Finally got around to doing some testing. The big Draper wrench “clicks” on a torque about 20% lower than the number dialled into it. My mid-range wrench which is a Halfords Advanced one was within 5%. What I find disconcerting is that implies the 180Nm I was striving for is probably closer to about 145Nm in reality but that felt ‘king tight so I think I’ll leave them as they are!
TG.
PostPosted: 11:43 - 22 Oct 2024    Post subject: Reply with quote
Learn to trust your 'elbow calibrator' Wink
Ducked
PostPosted: 08:11 - 29 Dec 2024    Post subject: Reply with quote
If you are really cheap you can calibrate a bungee for stretch and use it with any standard spanner. I did this using bicycle inner tube when I didn't have clearance for my torque wrench and it worked very well, so much so that I doubt I would buy a torque wrench now if I didn't already have one.
Described toward the sad end of this very long thread
https://tw.forumosa.com/t/damaged-spark-plug-hole-thread-chaser/228793/340
This would allow one to make a range of pull-O-meters accurate at different force levels, but I seldom use a torque wrench anyway so havn't bothered with that.trick
As a follow-up I got some really cheap (dressmakers?) tape measures which could be used to measure the stretch of the inner tube. Some are ratchetting so would record the maximum force applied, but since the cops got my car I havnt had reason to use them.
The last post was made 1 year, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 46.54 Kb
