Kawasaki Zephyr 550 will only start with choke
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3, 4  Next
garacs
PostPosted: 09:56 - 18 Aug 2024    Post subject: Reply with quote
Sparkplug cylinder 3
Working on it: Kawasaki Zephyr 550B 1991
garacs
PostPosted: 09:57 - 18 Aug 2024    Post subject: Reply with quote
Spark plug cylinder 4
garacs
PostPosted: 10:02 - 18 Aug 2024    Post subject: Reply with quote
A picture with all the spark plugs together, left to right 1-2-3-4
garacs
PostPosted: 10:18 - 18 Aug 2024    Post subject: Reply with quote
Short videos of the sparks on each spark plug.
Cylinder 1:
https://www.youtube.com/shorts/OOXj97Bo4jQ
Cylinder 2:
https://www.youtube.com/shorts/mjYDHAfyGMM
Cylinder 3:
https://youtube.com/shorts/03Mp2TCKjI8
Cylinder 4:
https://youtube.com/shorts/RyG66Jt7IxY
jaffa90
PostPosted: 10:47 - 18 Aug 2024    Post subject: Reply with quote
I expected to see some slight light brownish carbon, 2/3/4 are running with a very weak mixture. If you have no unwanted air going in then i suggest low fuel levels.
https://www.bikechatforums.com/google.php?q=setting+floats+on+a+550+kawasaki+zephyr
garacs
PostPosted: 11:06 - 18 Aug 2024    Post subject: Reply with quote
The link gets to an empty page, but google is my friend and found the thread anyway.
So according to Haynes manual:
garacs
PostPosted: 11:07 - 18 Aug 2024    Post subject: Reply with quote
I checked the floaters with a caliper for the float height directly, and they are all set to 16mm
garacs
PostPosted: 11:10 - 18 Aug 2024    Post subject: Reply with quote
I will then try to check with the transparent tube method instead, since that's actally the only way to see if the carbs are full of gas or not.... never did this before, since when unscrewing the drains screw I always noticed gas coming out, so never really bothered to check the level inside the bowls
PostPosted: 11:15 - 18 Aug 2024    Post subject: Reply with quote
I disagree, The 3 look fine (a light tan colour) but no.1 looks like it's overfueled.
Triumph Sprint ST 1050
garacs
PostPosted: 12:45 - 18 Aug 2024    Post subject: Reply with quote
What would be then the soluton?
jaffa90
PostPosted: 13:05 - 18 Aug 2024    Post subject: Reply with quote
On an air cooled engine you cannot afford to run it on a lean mixture.
If i set float heights on sprung loaded needle valves ( single carb) i attached a pipe to the fuel inlet and blow then raise the float until it stops me blowing.
Or your method with the clear pipe.
jaffa90
PostPosted: 14:51 - 18 Aug 2024    Post subject: Reply with quote
A long shot, does the fuel tap have a PRI position?
garacs
PostPosted: 16:40 - 18 Aug 2024    Post subject: Reply with quote
Yes the fuel valve was also rebuilt, and works flawlessly
struan80
PostPosted: 18:42 - 18 Aug 2024    Post subject: Reply with quote
Just out of ineterst from someone with no clue or real interest motorcycle mechanics.
Does the fuel system not need to be vented from a high point?
And to show my ignorance does the bike have a fuel pump or gravity fed. From the sketches I assume gravity fed.
I'm trying to learn.
garacs
PostPosted: 18:55 - 18 Aug 2024    Post subject: Reply with quote
We are all here to learn...
The carbs are gravity fed. and the vent is in the tank I guess?
jaffa90
PostPosted: 19:13 - 18 Aug 2024    Post subject: Reply with quote
Are you testing with the fuel tap in PRI position????
What happens if you leave it in PRI position for a bit
garacs
PostPosted: 19:37 - 18 Aug 2024    Post subject: Reply with quote
I did test it in ON, RES and also in PRI position, no change at all.
If I leave it in PRI, nothing really happens actually... I mean, when the carbs are full of gas, it just stops flowing.
PostPosted: 20:48 - 18 Aug 2024    Post subject: Reply with quote
PRI works when you have a vacuum controlled tap, where the tap doesn't open unless there is a vacuum on the vacuum pipe to the tap.
It stands for PRIme.
If it's that sort of tap then ON only allows fuel to flow to the carbs when the engine is running (so there is a vacuum caused by the intake.)
garacs
PostPosted: 23:47 - 18 Aug 2024    Post subject: Reply with quote
Probably I was not clear enough. I know how the fuel tap works. With "nothing" I meant to say that nothing out of the ordinary flow of gas happens. Gas keeps flowing until the carbs are full, even with the engine not running (no vacuum needed, as you said).
I use it to empty the tank easily and fast.
jaffa90
PostPosted: 18:15 - 19 Aug 2024    Post subject: Reply with quote
"""" I use it to empty the tank easily and fast. """
A fuel tap does not empty a tank but if you have a clear inline fuel filter fitted you should see if any crap is coming out of the tank.
( you may have fitted one ?)
garacs
PostPosted: 18:20 - 19 Aug 2024    Post subject: Reply with quote
Yes I did put a clear fuel filter between the petcock and the carbs. Some debris did show up, but not as much as I was expecting.
garacs
PostPosted: 14:23 - 20 Aug 2024    Post subject: Reply with quote
Investigating.... I removed the carbs once again. They are SPOTLESS! Though I did find something strange. I had bought months ago in preparation of the rebuild a new carb kit off ebay.
Well apparently one of the pilot jets was shorter.
So.... they are 28.66mm / 28.70mm / 28.64mm for carbs 4/2/1 respectively in length.... carb 3 is 28.14mm. Even the spring on that one is shorter.
They got probably mixed up. I still have the old ones, which were a bit oxidised and "worn", but at least all the same length, which range from 28.54mm to 28.56mm.
So I reinstalled the old ones, at least with them the difference in lenght is less than 0,02mm. I installed them with new o-rings, of course.
garacs
PostPosted: 14:25 - 20 Aug 2024    Post subject: Reply with quote
Now was the time with the floaters. Sinc the plungers came in the same kit of the idle screws, I wondered if there was a difference also with them, which luckily there was none.
Yet, the floaters were all, again, at different hights. So I set them up again, and now even if everything seems to be set properly, carb 3 leaks fuel.
Have to check the floaters again, I suppose...
garacs
PostPosted: 14:27 - 20 Aug 2024    Post subject: Reply with quote
So I am remounting the carbs, upside down, and rechecking also the jets. Wish me luck...
garacs
PostPosted: 21:45 - 20 Aug 2024    Post subject: Reply with quote
So after a lot of fiddling, carb 2 is leaking from the 2 holes on the air intake port. Carb 4 is barely leaking from the same spot as well...
Ideas?
The last post was made 2 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 124.62 Kb
