| Author |
| Easy-X |
 Easy-X Super Spammer
 Posted: 21:43 - 20 Sep 2026 Post subject: |
| stinkwheel wrote: | My suggestion would be to do without a rev counter. You don't need one. Fit a nice clock in its place. |
Quite happy to do that but Royal Enfield have made the speedo/tacho combo as a single unit with a propriety connector that drives both gauges. From what I've read, I'd have to partially recreate the circuit board that acts as base between the two.
In happier news, I've had a long conversation with Gemini and rifled through my spares boxes. I've managed to conjure up a signal generator that outputs roughly 3V peak-to-peak AC from an RP2040. The test program spits out a simulated 1000, 2000, 3000, 4000 & 5000 RPM (with the onboard RGB LED changing colour in sync, nice!) all verified with my oscilloscope. It can run from a USB power bank for testing so hopefully jabbing a couple of wires into the tacho will coax some reaction. I've also found a 12V to USB 5V converter - essentially the guts of a cigarette lighter adapter.
So that's power and output covered. For input I've got an optocoupler and some transient voltage protection components on order. Gemini assure me it's all piss easy, fingers crossed! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 22:32 - 24 Sep 2026 Post subject: |
Started connecting up the final bits of the loom. The left switch cluster is again shared amongst loads of Royal Enfield models, lights and brakes work. The indicators were weird, wouldn't flash but had a dim always on look to them. I thought maybe some earthing issue as the loom wasn't fully connected but I tried a spare 2-pin flasher unit first and it worked fine. Funny how the old one was working up until now.
I have the test circuits for "fixing" the tachometer signal laid out on breadboard. Just in case anything gets knocked out of place, I knocked up a schematic in KiCad:
https://i.ibb.co/7dMg9Zf3/Screenshot-20260924-232630.png
(click to enlarge)
Starting on the TCI-unit side, there's 12V running from the kill switch and switchable negative from the TCI. Power goes through coil, TCI flips the switch, field collapses, high voltage pulse generated by the coil - standard stuff. The 2.2K resistor is so the LED in the optocoupler isn't overwhelmed by 12V and the diodes are there in case there's any back EMF.
The optocoupler output feeds GPIO8 with a pull-up resistor and a capacitor for noise. Magic happens in the RP2040 (micropython script) and re-timed pulses emerge from GPIO14. The I/O pins only spit out a lightweight DC signal so there's a BC547 transistor beefing up the 3.3V to 5V. Then a tantalum capacitor for DC blocking and hopefully 3V AC should emerge for the tacho. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 14:02 - 26 Sep 2026 Post subject: |
Tried my test circuit that generates 400Hz, 800Hz, 1200Hz, etc. but no reaction from the tacho Thinking on my previous test, it was 3V AC at idle in circuit. Running 5V DC from the RP2040 is resulting in a little less than 3V AC when connected up. I'll redesign the circuit to use 12V from the loom, hopefully the little bump will get a reaction.
Other than toying with the tacho, everything else is pretty much done. I made little adapters and extensions inside the headlamp bowl to join the new loom to the GT gauges. I also bypassed the ammeter, as it seemed redundant (eek! foreshadowing...). Seemed like a lot in there but the headlamp went back in okay.
Missing from the new loom is fuel level and tacho. I had a bit of 4-core I think is meant for caravans or trailers so ran a little sub-loom. (Click to enlarge images)
https://i.ibb.co/N6LXn9fy/20260926-131924.jpg
Tapping into the spare twin-spark coil connector.
https://i.ibb.co/xKNTJCMK/20260926-131930.jpg
And near the carb/battery end, a 2 pin connector for the fuel level sensor and a 6 pin connector with: +12V ignition switched power, chassis ground, TCI switched ground and 2 lines for tacho AC.
https://i.ibb.co/21GkyK2t/20260926-133930.jpg
I can get to the connectors quite easily with the tank bolted back.
https://i.ibb.co/YT8mf6sB/20260926-132753.jpg
Another view with the new connectors up in the top-left. Everything else has tucked in quite nicely.
https://i.ibb.co/JR0RMRd9/20260926-132800.jpg
The TCI-unit is lurking down the side of the battery.
So I shouldn't need to unbolt the tank or open up the headlamp again, right? Right guys?! And he rode off into the sunset, never to be seen again...
Well the good news is, I can't really see any difference in performance between the ECU running the timing and spark and the blue TCI-unit. TBH swapping over to the Amal carb did more. The real "upgrade" is the bike having a very simple loom, 2 fuses, no relays (unless you count the flasher) and almost everything works. Almost everything
Obviously the tacho fix is still in progress but one other thing is the battery light staying on. There's no explicit wire for the battery LED so I'm guessing it's set to light up when there's some voltage present from the loom and go out when the loom power hits 14V (regulator charging). The 3 yellow wires from the stator go straight to the regulator at the back of the bike on the GT, so I got a little creative re-routing regulated power to the front of the bike.
Hopefully it's only a connector in the headlamp bowl that's popped out when I jammed everything back together. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 17:07 - 29 Sep 2026 Post subject: |
Damn, it's the reg/rec blown
Fired up the bike today and the battery voltage remained unchanged, 13.3V. Revving the engine made no odds. Disconnecting the reg/rec from the loom, no voltage coming out. Disconnected the stator from the reg/rec, ~15VAC between phases at idle, as one would expect.
Running this problem past the AIs, Gemini speculated this was always bound to happen. Royal Enfield's reg/rec is only a simple sausage and probably expects an easy-going lead-acid battery rather than a LiFePO4 with a veracious appetite for current.
Thinking about it, I normally kept the battery topped up with a trickle charger; most of the time it wouldn't be asking much of the reg/rec. As it's been apart and stop/starting loads, the LiFePO4 probably been demanding a lot more of the reg/rec. Bear in mind the battery warning light was one of the last things wired up, the reg/rec could have blown at any time during the loom swap over. And I suspect it took the previous flasher unit with it. If Gemini is right, this could have happened at any time and potentially fried the ECU as well
A generic MOSFET regulator is the ideal replacement. Unfortunately Amazon, eBay, etc. are awash with copies of dubious quality. Gemini suggests I monitor the charge voltage and if it goes over 14.5V, rip the thing out. It just so happens I have a volt meter with a handlebar mount in my drawer of spares, much more useful than the ammeter it's effectively replacing. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 17:20 - 03 Oct 2026 Post subject: |
The original regulator is in an awkward spot, took me a while to wrestle it out. The new one is much bigger
There aren't any big voids to drop it into, not even the tool box area. F*ck it...
https://i.ibb.co/B5FjxWxQ/20261003-170023.jpg
At least it'll get plenty of airflow! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 17:27 - 03 Oct 2026 Post subject: |
| Easy-X wrote: |
At least it'll get plenty of airflow! |
hmm, good but ther might also be ' waterflow' around those connectors when it rains.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Back to top |
| Easy-X |
| Back to top |
| Easy-X |
| Back to top |
| Easy-X |
 Posted: 19:10 - 10 Oct 2026 Post subject: |
Tacho project update.
I fired up the ignition pickup side today and it does work... sort of. The initial script assumed 4-stroke therefore 1 spark per 2 revolutions. However, the TCI-unit is doing wasted spark, 1 spark per revolution. Not particularly surprising as it runs from a crank sensor rather than a cam sensor. An easy fix though, calculate on half the pulses.
More difficult is there's some jittery movements due to noise from the spark. It's not all the time but it gets worse as the rpms increase. The question is whether to filter such noise on the electrical side or in software  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
| Back to top |
| Easy-X |
 Posted: 18:34 - 31 Oct 2026 Post subject: |
Surface mount, 0.5mm legs... I wouldn't recommend it
https://i.ibb.co/W444w56q/20261031-182737.jpg
It looks a bit wonky but I tested all the leg-to-track connections and nothing's missing or bridged.
What's needed for SMD work is sticky flux (comes out like glue) and a clean, wedge shaped tip (stop sniggering at the back). You only need the tiniest bit of solder, even so I still bridged a couple of pins. I dare say I'll find I've cooked the chip but that's why I bought spares  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 03:24 - 01 Nov 2026 Post subject: |
Reworked the original circuit diagram.
https://i.ibb.co/k2PwjBZz/Screenshot-20261101-025245.png
Using an ATtiny85 in place of the previous RP2040. According to Gemini, old 5V tech is more resilient than the current 3.3V stuff. It is actually tiny too, only 8 pins. I only need two anyway - input and output.
The opto-coupler is dropped in favour of the MAX9924. This is a dedicated "Variable Reluctance" chip. Fancy! Apparently it was commonly used for old cam and crank pickups, before Hall-effect sensors took over. It converts the noisy and variable AC from the pickup into a clean 5V DC square wave.
The transistor output stage remains unchanged and there's now a proper DC converter board instead of the hacked USB cigarette adapter. As a bonus, I've added a NeoPixel. It'll flash on startup, glow red for <1000rpm, orange for 1000~2000, green for 2000~3000, blue for 3000~4000 and purple for >4000rpm. Anything past that is a bit unnecessary on this engine It represents a handy "test point" in the middle of the circuit.
If I have enough capacitors left, might test it tomorrow. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 16:45 - 14 Nov 2026 Post subject: |
Success! I crammed everything onto a tiny breadboard:
https://i.ibb.co/qYGKHL02/20261104-234146.jpg
Given I have two ATtiny85 chips, I programmed one to do a 1000, 2000, 3000, etc. test sweep and the other to pick up the square wave from the MAX9924. The test code ran fine and the converter code did as well... after a few attempts (but down to coding issues, not the electronics). The NeoPixel boards turned up after I got it running
Next step: create a stripboard prototype, box it up, and see how it fares on the road  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 87.13 Kb
