kawashima |
kawashima World Chat Champion
Posted: 11:21 - 15 Nov 2006 Post subject: Aprilia mana 850 automatic bike |
Aprilia mana850 automatic bike with lid-in tank. Looks a bit like MV agusuta Brutale but seems Interesting. I can't find clutch lever.
Automatic called USP has 4 modes in total.i.e. sequencial 7 manual(with no clutch), automatic(sport, touring, rain)
V twin SOHC 850cc.
https://www.motoblog.it/post/4988/2007-aprilia-mana-850
italy
There seems to be also 750 which has manual gear box.
https://static.blogo.it/motoblog/ApriliaMana3.jpghttps://static.blogo.it/motoblog/ApriliaMana4.jpg
https://static.blogo.it/motoblog/ApriliaMana1_01.jpg
Aprilia NA 850 Mana - Technical specifications
Engine
Aprilia Four stroke longitudinal 90° V twin. Liquid cooling. Single overhead cam with chain drive, four valves per cylinder.
Fuel: Unleaded petrol.
Bore x stroke: 88 x 69 mm
Total displacement: 839.3 cc
Compression ratio: 10-11 : 1
Maximum power at the crank: 55.1 kW (75 HP) at 7250 rpm.
Maximum torque at the crank: 7.79 kgm (76.5 Nm) at 8000 rpm.
Fuel system: Integrated engine management system. Weber Marelli electronic fuel injection with one 38 mm throttle body
Ignition: Digital electronic ignition, with two spark plugs per cylinder, integrated with fuel injection system.
Starting: Electric
Exhaust: Two in one system in 100% stainless steel with three-way catalytic converter and Lambda probe
Generator: 450 W at 6000 rpm.
Lubrication: Dry sump with separate oil reservoir.
Gearbox
Sequential with manual or automatic mode selectable by the user.
- 7 ratios in manual mode
- 3 mappings (Touring, Sport, Rain) in automatic mode.
- Gear change by pedal or handlebar command.
The user can switch from automatic to sequential mode at any moment.
Clutch: Automatic
Primary drive: Belt
Final drive: Chain
Frame: High strength steel trellis
Front suspension: 43 mm upside-down fork Wheel travel: 120 mm.
Rear suspension: Aluminium alloy single-piece swingarm
Hydraulic shock absorber adjustable in spring preload and rebound damping. Wheel travel: 125 mm.
Brakes
Front: double stainless steel floating disc ( 320 mm). Radial calipers with four pistons.
Rear: steel disk ( 240 mm). Single piston caliper.
Wheels
In aluminium alloy
Front: 3.50 X 17" Rear: 6.00 X 17"
Tyres
Radial tubeless;
front: 120/70 ZR 17
rear: 180/55 ZR 17
TheShaggyDA |
TheShaggyDA Repost Police
Posted: 17:41 - 15 Nov 2006 Post subject: |
Well, the headlamp assembly looks ugly - why are manufacturers going for the hunchback look nowadays? Other than that, could be a nice ride. Would like to see a touring version, with fairing and shaft drive. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
Reppyboyo |
Reppyboyo Nearly there...
ncrn |
ncrn World Chat Champion
Keen |
Keen World Chat Champion
Posted: 09:13 - 16 Nov 2006 Post subject: |
Interesting I struggle to see who might buy one though... maybe on continental europe where big scooters are popular, this would make a stylish alternative.
I remember hearing about a similar bike being developed (I think by derbi?) that looked alot cooler... ____________________ "he who makes a beast of himself gets rid of the pain of being a man"- Dr. Johnson |
Whosthedaddy |
Whosthedaddy Super Spammer
mchaggis |
mchaggis World Chat Champion
Posted: 14:01 - 16 Nov 2006 Post subject: |
Why are they putting all these sharp edges all over the place? Is it supposed to make it look fresh, cutting and funky?
They look too complicated and frankly, a mess.
Of course, beauty is in the eye of the beholder. In my eyes, this sort of style looks gash. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
MarkJ |
MarkJ World Chat Champion
Posted: 02:05 - 27 Nov 2006 Post subject: |
This is probably a really stupid question, but if your helmet is in the petrol tank where does the petrol go?
I like the looks of it though, would be great as a manual |
Chr!S |
Chr!S Nitrous Nuisance
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
