Overheating help needed!!!
Helen
Guest
PostPosted: 12:06 - 11 Apr 2002    Post subject: Overheating help needed!!! Reply with quote
I bought a second-hand NSR125RK 1990 twin headlight model in October.
But now the warm weather is here it overheats like hell!!!!
My boyfriend (he rides a Firelade) has taken off the the radiator, cleaned out the fins, run water through the radiator, replaced the rad cap with a new one. OK we bought it from Halfords for £4 - it has 15 psi printed on the top - because I can't afford £23 for the Honda cap, what a rip-off.
What a pain to refill the rad!!!!
But is still boils over when I go for a ride of more than 5 miles.
Is this usual for a 125RK?
Please, Please can anyone help me!!!
Hex
Party Boy
PostPosted: 12:38 - 11 Apr 2002    Post subject: Reply with quote
not familier with the system sorry but basics to check:
thermostat is opening
water pump is working
brakes aint binding!!
hope these help a bit
Gav
spencer
Guest
PostPosted: 16:10 - 11 Apr 2002    Post subject: Reply with quote
1 Did u bleed the system after filling rad with coolent.
2 Take the thermostate out and take the bike for a run if it dont overheat it is that, if it dose it could be head gasket or as hex said waterpump.
3 Sounds to me like the thermosate . hope this helps good luck
Milo
PostPosted: 18:46 - 11 Apr 2002    Post subject: Reply with quote
to me it sounds like the water pump. check everything though. or take it to a garage and get a quote for repairs, ask what's wrong and do it yourself Smile
Shaft drives rule. Razz
Dylan
PostPosted: 19:26 - 11 Apr 2002    Post subject: Reply with quote
That aint normal, my bike only started to overheat once in thick traffic in the summer and a quick blast up to 50mph and it cooled down again. Could be a
Faulty temp gauge or gauge sensor
Thermostat syuck closed
Passages blocked in radiator, hoses or water jacket
Faulty water pump
Air in system
Hope this helps
Dylan
PostPosted: 23:11 - 11 Apr 2002    Post subject: Reply with quote
Only had 2 strokes overheat a few time. First off was the MBX125 which blew its head gasket (then ate its piston rings!). The Gilera we have is a TOTAL pig to bleed the cooling system on, and will easily overheat. Get the systsem bled through and it works fine though (just takes about a dozen attempts). On the RS125 I have had overheating once, and this was due to using too strong a mix of antifreeze. Antifreeze is quite thick and difficult to pump, so the not much got moved round the engine and the engine would run hot (but the radiator would be cold). Draining off some of the antifreeze and adding some water fixed this
The last post was made 24 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.37 - MySQL Queries: 13 - Page Size: 46.04 Kb
