Sidestand Engine Kill
Scooby
Scrappy Doo
PostPosted: 18:13 - 11 Apr 2002    Post subject: Sidestand Engine Kill Reply with quote
Alright guys,
Just wondered if any of you have found a solution to the sidestand engine auto kill. Basically meaning when you put the sidestand down it kills the endine, and when the bike is on the stand you can't start it. It really pisses me off because with it being a 2 choke (yes 2 choke, you'll understand if you followed my mates RS50 Laughing) you need to let it warm up so it gives me 3 options......sit on the bike for 10 mins letting it warm up.......buy a rear paddock stand.......or 3.....get the thing to stop auto killing the engine!!!
Plz help guys, I need to know how to stop this happening.....
Viper
Get off my bloody bike!
PostPosted: 18:24 - 11 Apr 2002    Post subject: Reply with quote
Have you tried putting it into neutral??
My bike quite happily sits on my side stand and warms up.
I thinks there is a problem somewhere?!?! ...or i am just not understanding you correctly?!?!? Confused
minesweeper
Whoah there!
you can warm it up by reving it in netrual or just ride it cold gently, the feature is meant to stop you driving off with it down trying to take a turn and ending up cartwheeling
Scooby
Scrappy Doo
PostPosted: 18:29 - 11 Apr 2002    Post subject: hmmm Reply with quote
I know you can rev it in neutral, but that's not my point. I wanna be able to start the bike up, leave it to warm up while I go and get my leathers on, then go and jump on it.
It says in the manual there is a sidestand cut out, but what I am saying is, how do I remove it so this doesn't happen.
minesweeper
Whoah there!
PostPosted: 18:32 - 11 Apr 2002    Post subject: Reply with quote
mate, you dont understand, you turn the bike on leave it in neutral with the sidestand down with the choke on if it needs it, that will warm up the bike, now you go get in your leathers and come back to a warmed up machine... leaving it ticking over in 1st with no sidestand while you got put the leathers on would be funny Smile come back to a bike on its side about 2 meters infront of where you left it
matt
Scooby
Scrappy Doo
PostPosted: 18:33 - 11 Apr 2002    Post subject: hmmm Reply with quote
Right so when my stand is down I can't start the bike AS CIT SAYS IN THE MANUAL, when you put the stand down if the engine is running it cuts out AS IT SAYS IN THE MANUAL, so come on the mr know it all how do you get the bike to keep ticking over on the stand.....
TiN
Pocket Tin
PostPosted: 18:34 - 11 Apr 2002    Post subject: Reply with quote
Err...the sidestand feature is actually a safety feature...you're supposed to make that it works, not disable it!
What stops you from doing that now?...once you've jumped on it, kick the sidestand up, kick into first and off you go!...you surely can't be that lazy?
...actually, I'm starting to get confused now...you can't keep the bike idling in first gear unless you have the clutch in anyway!...unless you're gonna gaffa tape it...
Tin
Mole
PostPosted: 18:35 - 11 Apr 2002    Post subject: Reply with quote
Scoob,
Have you got it right mate?
The side stand engine kill is there to prevent you activating the stand when the bike is in gear!
Ie: With the bike in neutral and the neutral light on (not just in neutral, cos sometimes the light wont come on if you are just on the edge) the bike should start with the stand down.
With the engine running the bike will stop if you are still in gear! If you aint and you are in neutral with the neutral light on, it will let put the stand down!
Mole
V4's R Us!!!
Mole, the oldest 18year old on the block !
PostPosted: 18:35 - 11 Apr 2002    Post subject: hmmm Reply with quote
You should be able to leave it wariming up in neautral... with the choke on it shouldn't die.
If you really want to stop the auto-kill there should be a switch/cable going to the frame end of the stand. (Sorry can't be bothered to go downstirs and check exactly where) You just need to disconnect/cut this and it should disable it.
minesweeper
Whoah there!
PostPosted: 18:36 - 11 Apr 2002    Post subject: Reply with quote
sorry how long have you owned abike your cracking me up Smile
LEAVE IT IN NEUTRAL! the sidestand wont cut the engine if the bikes in neutral, it only cuts out if your in gear
go out side try it now mate
matt
Scooby
Scrappy Doo
PostPosted: 18:38 - 11 Apr 2002    Post subject: hmmm Reply with quote
No in my manual it says with the sidestand down you cannot start the bike. It has to be up to be able to start it. This is all in neutral by the way. If I start the bike with the stand up (whilst in neutral yet again, obviously) then put the stand down the engine cuts out. This is exactly what it says in the manual, so I dunno why mines different.
minesweeper
Whoah there!
PostPosted: 18:40 - 11 Apr 2002    Post subject: Reply with quote
very very strange, the bike should run with the stand down in neutral fine, give us the details of your bike mate
Milo
Oh, man. This guy's funny!
when it's not in gear (neautal-clever Smile ) and the bike's sitting there on it's stand the bike will start.
when it's in gear and sitting there on it's stand it will not start.
when not running with that stand up but in gear it will only start if you pull the clutch in.
how about you go read that precious manual of yours again? then again, it's probably one of the many bits in the manual that have been VERY badly translated!
Shaft drives rule. Razz
minesweeper
Whoah there!
PostPosted: 18:44 - 11 Apr 2002    Post subject: Reply with quote
ok test this
put the bike in neutral on the sidestand, shown with a green light, try to start it, it should work fine.
now try putting up the sidestand keeping the bike in neutral at all times, then put the sidestand down again without changing gear be very careful with this, it should stay on if not somethings wrong.
matt
Scooby
Scrappy Doo
PostPosted: 18:44 - 11 Apr 2002    Post subject: righto jo Reply with quote
Its a 2001 Y reg UK bike.
Ok I am not totally stupid you know I don't try and start the bike when it's in gear you inbread (milo). Ok listen one more time......bike in neutral, stand down, bike won't start. Bike in neutral, stand up, bike starts.
Don't come back with your lame comments about how I don't know how to start a bike, this is not what I am saying, I am asking why the bike is doing this. =
minesweeper
Whoah there!
PostPosted: 18:47 - 11 Apr 2002    Post subject: Reply with quote
ok your saying milo is surrounded by bread Smile inbred is the correct term mate.
if its 2001 y model same as mine it should stay on with the stand down in neutral, if it doesnt something is wrong mate
matt
Scooby
Scrappy Doo
PostPosted: 18:50 - 11 Apr 2002    Post subject: ok cheers Reply with quote
Ok cheers mate, I'll have to go have a close look at it.
P.s. Ok I'll change my 'inbread' comment, to saying he is a muppet, which I know damn right it spelt right Laughing
Viper
PostPosted: 18:50 - 11 Apr 2002    Post subject: Reply with quote
Please stop. This is getting too funny!!
I'm the library, people think i'm laughing to myself!!!
Milo
PostPosted: 18:52 - 11 Apr 2002    Post subject: Reply with quote
lol
if you've had the bike under 3 months then the chances are you can take it back to your dealer (if that's where you got it) and get them to sort it out. otherwise there's a problem. if the neutral light shows then there's not a problem with the sensor and it should be fine. if it doesn't then you know there's a problem
PostPosted: 18:53 - 11 Apr 2002    Post subject: ok cheers Reply with quote
Does your neutral light work?.. There's probably a broken connection so that the 'kill' circuit can't tell if the bike's in neutral or not.
If it's a 2001 model it should be covered by the warranty.
minesweeper
Whoah there!
PostPosted: 18:54 - 11 Apr 2002    Post subject: Reply with quote
trying to work out what could be wrong, check that the neutral light stays on all the time when you put the stand down even slightly clicking out could cut the engine, also try just having the bike sitting in neutral with the sidestand down and attempt to start it with choke on
if both of them dont work then im not sure what it could be sorry.
matt
Scooby
Scrappy Doo
PostPosted: 18:56 - 11 Apr 2002    Post subject: hmmm Reply with quote
Neutral light is fine. Just one question, I bought the bike from a dealer who had bought it damaged off the previous keeper. Does the warranty automatically shift to me??? I have no warranty documents???
minesweeper
Whoah there!
PostPosted: 18:58 - 11 Apr 2002    Post subject: Reply with quote
If he sold it to you as fully working and didnt tell you about the fault, he lawfully has to fix it, what warrenty documents do you have? the original owners or the ones from the dealer?
matt
Milo
PostPosted: 18:59 - 11 Apr 2002    Post subject: Reply with quote
i think the standard warranty for all UK honda bikes is 2 years unlimited mileage. take it to a honda dealer, they won't worry about how you got it cos they'll get paid by honda in the end
The last post was made 24 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 3.93 - MySQL Queries: 13 - Page Size: 119.54 Kb
