Keith w.........
craigT19
Jolly Green Giant
PostPosted: 20:31 - 16 Apr 2002    Post subject: Keith w......... Reply with quote
hi keith can you help??
after takeing a de-tailed look as to why my bike is slowing down i noticed the power valve was'nt opening fully?
i got to the motor thingy and took off both cabels the cabel with out the nut on it is coming out a bit then it seems to hit a snag??? and then it carrys on coming out? obviously the little electric motor cant pull the cable past the "snag" so im not getting optimum power as my exhaust outlet dosnt open fully.
have you got any suggestions on what i can do??? its really slow it took my 9 secs to hit 60 today on a de-ristricted nsr??
thx
Current bike : - 2016 MT-10
PostPosted: 20:35 - 16 Apr 2002    Post subject: Reply with quote
Take the valve out of the engine (you have the manual?) and clean it up thoroughly. Carefull use some fine wet and dry paper. On the softer alloy bits be very careful, and try using some carb cleaner on them instead. Lube it with some oil (dont use grease, and dont use copper slip as although it takes the heat well it is slightly abrasive) and put it back together
craigT19
Jolly Green Giant
PostPosted: 20:39 - 16 Apr 2002    Post subject: .. Reply with quote
k thx keith when you say take the valve out, is that the bit behide the radiator or just the bit under the tank??
Mad
PostPosted: 13:02 - 17 Apr 2002    Post subject: Reply with quote
I mean the actual valve in the engine. Looking at the manual I think you need to remove the actual valves through the cylinder (ie, take the head off), and that may not be the easiest thing to do. It looks like you pull the RC valve shaft out of the side of the barrel, and then the actual valves slide into the barrel. Of course doing this means you will need to replace the head gasket, so it may be best to try and avoid doing the job fully until the top end has to come apart for another reason, such as replacing the rings
As a short term measure, disconnect the valve as you already have and operate it by hand repeatedly. This should free it off a fair bit, hopefully enough to allow the motor to turn it
craigT19
Jolly Green Giant
PostPosted: 18:36 - 17 Apr 2002    Post subject: ... Reply with quote
thx keith i found the problem, it was the nut that haolds the power valve together, it had vibrated loose and jamed in place stopping the valve open fully.
thx
PostPosted: 19:48 - 17 Apr 2002    Post subject: Reply with quote
Thats a novel one. Time for some Loctite
Dylan
PostPosted: 21:16 - 17 Apr 2002    Post subject: Reply with quote
Is it better now Ctyson??? Back to normal speeds??? All i get is a very last bit of top end rush on my bike so i think ill check mines working too. Might be stuck in the open position.
Dyl
craigT19
Jolly Green Giant
PostPosted: 21:18 - 17 Apr 2002    Post subject: ... Reply with quote
yeah its much better thx dylan the speed is bake to normal now evan though my bike is still abit slower than usual but it is due a service, i think the air filter is dirty.
The last post was made 24 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 57.31 Kb
