Nath |
Nath World Chat Champion
Posted: 22:10 - 29 Nov 2006 Post subject: Rat engineering: Homemade "clip-on" handlebar |
A few days ago I crashed one of my bikes, a 1988 Honda Bros400, going over a speed bump a little too fast (60mph ). I lost control and got thrown off the bike before it proceeded to slide 50yards up the hill on its side, luckily avoiding hitting anything. Whilst I was lucky, the bike still sustained a little damage including a snapped handlebar which prevented me from riding or pushing it home. Today I made a replacement handlebar from some scrap steel.
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar1.jpg
My raw materials. A bit of scaffolding, a length of 7/8ths steel tube I'd found at the back of the garage, and an old homemade shelf bracket - Basically a length of 6mm flat bent at a rightangle.
Spent a few hours working away in the garage and managed to weld something together pretty much the same as I'd had planned in my head. Used a 10mm thread as I was a bit worried about the thickness of the scaffolding requiring a fair force to clamp it round the stanchion. Welded a nut onto my steel flat rather than messing around with a tap. Had the anglegrinders out a little bit, but also used a hacksaw and file for half of the work to save getting grind dust all over the garage.
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar2.jpg
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar3.jpg
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar4.jpg
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar5.jpg
The finished product! Not bad eh?
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar6.jpg
You can see that the homemade clipon points down at a slightly different angle to the 'proper' bar, but I couldn't feel the difference sat on the bike.
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar7.jpg
There ya go, not bad for an afternoons work starting with a few bits of scrap steel. Still need to cut it to length once I've got all the controls on, and possibly weld up the ends to stop water getting in. I may try and attach the bar end weight off the original clipon which I found in the middle of the road after my crash. Then just paint it to stop it rusting up.
Should look pretty tidy once all the control are on, and I dare say this bar will not snap in half as easily as the other one did! ____________________ Hard livin', hard luck. |
Gazdaman |
Gazdaman I did a trackday!!!
Posted: 23:19 - 29 Nov 2006 Post subject: |
When I read the title I thought "oh god, this is going to be shoddy".
Saw the first pic, thought, "wow, this is REALLY going to be shoddy".
But it's fucking quality mate! Seriously well done. I'd keep that on there, looks fine.
Nice one
Gaz |
Klause |
Klause World Chat Champion
Posted: 00:40 - 30 Nov 2006 Post subject: |
I remember our rat conversations at Portugal faro. You certainly live up to your conversation ideas.
Planning on more trips at all? Believe im doing France and Italy with R4nger next summer.
____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
colin1 |
colin1 Captain Safety
quacker_boy |
quacker_boy Cuddle Bitch
Posted: 09:24 - 30 Nov 2006 Post subject: |
Those welds look really done Nath, so i'd actually say ignore Colin that'll hold up for a long time.
For a bodge job, that is FUCKING impressive mate
I'm sure one's longer than the other though ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
G |
G The Voice of Reason
jon_nsr |
jon_nsr Nitrous Nuisance
Posted: 11:39 - 30 Nov 2006 Post subject: |
just go buy one ____________________ 1999 GSXR750 |
mr.z |
mr.z World Chat Champion
Posted: 22:05 - 30 Nov 2006 Post subject: |
I did wonder what you ended up doing tom will be pleased to hear your makeing use of the scaffold
Looks like a damn fine job though there..
follwing from what g said, one thing might be worth doing is drilling a hole through the end closest to the clamp, that way if it hits the deck it'll snap and not fark your forks? you've allready proved you can make a new clipon but new forks would be a beearch.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Nath |
G |
mr.z |
Posted: 01:00 - 01 Dec 2006 Post subject: |
I had a go mig welding once, it was like a pidgeon had been fed laxative and slowy pressed in a vice..
The two pieces of flat bar welded end on end took 2TONS of force before it went and it wasn't the weld that went!.. and this was an abismal mess of a weld, not a pretty one.. pretty amazeing..
The breaking.. i dunno, the only thing i was thinking is the force being transfered through the yokes, could potentially crack them maybe.. dunno.. much like your pannier/wall incident probably not gonna be a problem though..
Alternatively just stop bloody crashing (allthough i'm amazed its not a weekly thing in notts) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
palmer |
palmer Fiddled Kiddy
kawashima |
kawashima World Chat Champion
gixerboy |
gixerboy Borekit Bruiser
Posted: 21:42 - 01 Dec 2006 Post subject: |
colin1 |
Posted: 01:59 - 02 Dec 2006 Post subject: |
Nath wrote: |
Colin, I think you need to understand a little bit about metalology. If you cut a steel bar in half then weld it back together, the weld will be the strongest part of the bar. Everyone always talks about welds "failing", but how often do you see this? The last two broken frames I've seen posted on this forum from serious crashes did not snap at any welded joins (Gaz's Bandit and Andy's SV650). |
there is a difference between a good weld and a bad weld.
good welds are strong, bad welds are not
home made welds are not always as good as welds made by manufacturers using skilled professional welders
funnily enough i do actually know about metallurgy including how to spell it.
when you heat metals their properties change and can remain changed, for example they can become very brittle
if you want to learn more, look up 'phase diagrams', and words like austenite, martensite etc
https://en.wikipedia.org/wiki/Austenite
all sorts of things affect the quality of the weld. in particular, if you weld something small to something big, the big thing may not heat up much when welded compared to the small thing which may get very hot. this may mean the weld sticks well to the small thing but not the big thing
a bit like when soldering, the difference between a wet joint and a dry joint
loads of other factors such as weld porosity, surface preparation (or lack of) etc
i dont know about welding, but i do know a bit about metallurgy. i sell steel for a living.
its possible your welds are great, but i dont think you can know that
gixerboys look imacculate and professionally done, but for all i know they are weaker |
palmer |
Posted: 10:42 - 02 Dec 2006 Post subject: |
colin you anorack |
Cillit-BANG |
Cillit-BANG World Chat Champion
colin1 |
Nath |
colin1 |
Posted: 20:32 - 05 Dec 2006 Post subject: |
Nath |
Posted: 21:43 - 13 Dec 2006 Post subject: |
Two weeks later, and I finally found the time to finish off my handlebar and get it on the bike.
I decided to use the old bar-end weight thinking that this would be the key detail that would determine whether the bar looked like a bodge or like a professional replacement. So I welded up the top end, then cut the bar to length and welded a nut inside for the bar-end weight to screw into. Sprayed the exposed part of the bar, stuck my controls onto it, and jobs a good'un.
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar8.jpg
https://homepage.ntlworld.com/steven.coy/images/handlebar/handlebar9.jpg
Total cost of handlebar: £0.00
Had to buy replacement switchgear and brakelever off eBay for almost £30, and need to spend another fiver on a replacement lid for the brakefluid resevoir. But all in all not too bad a cost to sort out the consequences of quite a bad crash. Unfortunately there are now too many things "wrong" with the bike for it to ever be a good condition standard bike again, so I suspect it will probably get the full-on rat treatment at some point next year ____________________ Hard livin', hard luck. |
Jenks |
Jenks World Chat Champion
colin1 |
palmer |
Posted: 09:47 - 14 Dec 2006 Post subject: |
I agree colin.
Even if i could weld realy well, id still rather have a 'professional' do the work. Then if it fails you can have a go at him |
feef |
feef Energiser Bunny
The last post was made 17 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
