Buggered handling
McJamweasel
BCF Junkie
PostPosted: 00:41 - 18 Apr 2002    Post subject: Buggered handling Reply with quote
Have just put new head bearings in on my '92 nsr and now the handling has gone to shit!!
Ive got a very definate weave at slower speeds, ie 40 and lower, and the cornering is fucked.
It tips in too fast but then if i try to pick it up a bit top change my line then it comes up too quick as well.
The weave is horrendous when im slowing(but not when heavy braking), I struggle to keep it under half the lane! Shocked
The forks are level according to the marks that are by the top yoke but there is slightly different amount showing over the bars. Is that cuz of the bars??
Any suggestions would be much appreciated.
PostPosted: 22:22 - 18 Apr 2002    Post subject: Reply with quote
Not sure how you can get a different level at the yoke and on top of the clip on. The manual says to install to the grove on the fork with the top yoke.
However, my guess would be that you have overtightened the steering head bearings. The manual specifies to torque them up to 1.4ft-lb, moev the bars lock to lock 5 times then slacken off and retorque.
McJamweasel
BCF Junkie
PostPosted: 23:31 - 18 Apr 2002    Post subject: Reply with quote
The different level confused me as well.
I spose it must just be a difference in the bars.
Ill try loosening them off, see if that helps.
Cheers Keith.
PostPosted: 23:44 - 18 Apr 2002    Post subject: Reply with quote
I think what happens when you overtighten steering head bearings is that you loose smoothness, and so you tend to overcompensate with any steering input. So you head in one direction, overcompensate and head off in a second direction, try again and back in the first direction.......
retrofly
PostPosted: 08:45 - 19 Apr 2002    Post subject: Reply with quote
How much does it cost to fit new steering head bearings, cause my steerings gone shit too. There seems to be exsesive vibrations comming from the handle bars and they wobble when i brake hard and going roundf corners, so is it the steering head or sumfin else
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
McJamweasel
BCF Junkie
PostPosted: 12:12 - 19 Apr 2002    Post subject: Reply with quote
Hi there, sounds like it could be head bearings, I sure keithll tell ya tho Laughing
They cost me £35 and a coupla hours in the garage with a mate.
Its probably an hours labour from a garage.
PostPosted: 18:17 - 19 Apr 2002    Post subject: Reply with quote
Steering head bearings going will normally go slack and you will land up with a clonking noise. Other ones to check are the wheel bearings, swinging arm bearings and the suspension linkages (and a knackered shock), as all can cause odd handling.
Bearings normally are not difficult to do (once had a pig of a job removing some non standard tapered roller bearings from an FZ750). Couple of hours work, but be careful not to damage the threads on the steering "stem" when you try and knock the bottom yoke out
retrofly
PostPosted: 09:10 - 22 Apr 2002    Post subject: Reply with quote
Yeah every now and again there will be these cluncking noises comming from the front end, like goin over small bumps.
Thanx
LUke
The last post was made 24 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2 - MySQL Queries: 14 - Page Size: 58.39 Kb
