Klause |
Klause World Chat Champion
Posted: 01:15 - 19 Dec 2006 Post subject: 900 engine project (ducati 2v of course)*Update with pics* |
Found a guy selling a 1992 900 lump for £50, trouble was he was in Yorkshire area. Was looking like I couldn’t get it because of the distance. Went to meet my biker mates at a pub as it was Joe’s birthday. R4nger was there and he mentioned he was going up Yorkshire way in the van to collect some wheels that he had won on ebay. So the trip began, 6am with a storm of a hangover we left to go up north. Was a rather nice chap, confirmed that the noise sounded like main bearings, and told me about the top end rebuild he had done but gave up on the engine when it made noises soon after.
https://www.bikechatforums.com/files/1_190.jpg
Pulling it apart began…
Whipped the cam belt covers off to find rust everywhere! Luckily it doesn’t seem to be major rust and the rollers still move lovely. Just surface rust where it’s been sitting in a garage for ages, seems to clean off with a bit of WD40 and rag.
Ran my compressor up and blew all the crap (Inc paint and spiders) off it with the air gun. Just cut the cam belts off as they felt like boot soles.
https://www.bikechatforums.com/files/2_148.jpg
Barrels…
Started to work on the cylinder stud nuts, easy no problem. No need to worry about taking cams apart like your normal jap bike, found it quite fun to watch the valves work when you turn the top cam belt sprocket. Had a quick peak, of the valve gear and took the inspection cover off on one head, all looks fresh and new maybe the guy did get the top end rebuilt (thought he was chatting shit). With a bit of rubber mallet molesting the barrels came off. Can still see the honing marks, in fact looks like the guy got them honed too. Also noted that the studs had been changed to 851 ones (I think) because the originals were prone to breaking.
https://www.bikechatforums.com/files/3_932.jpg
https://www.bikechatforums.com/files/4_142.jpg
Table time…
Was getting pissed off working on the floor, my dads triumph was taking up the bike lift/ramp. Decided to make a bench… Found an old bed we were throwing out and made something out of nothing. Carried on removing the 2nd cylinder, same again looks fresh and rebuilt.
https://www.bikechatforums.com/files/5_842.jpg
https://www.bikechatforums.com/files/6_190.jpg
Side bits…
Now all I need to do is remove all the stuff in the side cases. Made a tool to pull off the alternator/cover out of bits of scrap. Grabbed the alternator hub, tonnes of play, main bearing very gone! Removed all the timing gizmos and gears now just a plan case left.
Started to work on pulling the clutch side off but got carried away with a chain failure that happened on the way back from work. Needed to express anger on forum…
https://www.bikechatforums.com/files/8_190.jpg
My aim hopefully will be to get new main bearings (doing) then vapour blast it, paint it, buy some high compression pistons and slap it in the monster. ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Zimbo |
Zimbo World Chat Champion
Posted: 01:19 - 19 Dec 2006 Post subject: |
Should be an interesting one Klause, keep up the reports!
Have you got an oil cooler fitted currently?
Pistons - JE 11.1:1 complete sets are currently very good value from Chris at California Cycleworks, pistons rings and wrist pins for both cylinders for around £150 plus postage. Should give you 5 - 6 bhp right through the range |
Nath |
Nath World Chat Champion
Posted: 01:26 - 19 Dec 2006 Post subject: |
Vertically split cases? Looking forward to splittin them I bet What happens if the crank itself is knackered? ____________________ Hard livin', hard luck. |
Klause |
Posted: 01:27 - 19 Dec 2006 Post subject: |
Zimbo wrote: | Should be an interesting one Klause, keep up the reports!
No I dont run an oil cooler at the moment. But for the 900 engine I shall need to source one.
Thats what im thinking but import tax is a bitch. Seen some in the EU aswel. Will have to see closer to the engine going back together. Need to order main bearings soon, don't know the sizes do you?
Nath wrote: | Vertically split cases? Looking forward to splittin them I bet What happens if the crank itself is knackered? |
Seems to be a piece if piss so far, very easy engine to work on as normal. I'm hoping the crank has held it's ground but I can allways get it repaired/rebuilt/reground if need be. ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
quacker_boy |
quacker_boy Cuddle Bitch
Posted: 09:40 - 19 Dec 2006 Post subject: |
Klause, you get the engine working again and looking relatively tidy, i'll respect you forever more...and send you my engine if i ever buy a ducati ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
garth |
garth World Chat Champion
Posted: 10:40 - 19 Dec 2006 Post subject: |
Hi.
Looks fairly simple to work on. Did it come with carbs etc?
How big is the oil cooler you need? I have a small (10" ish) one here that you can have, but the holes for the unions will have to be re-tapped.
Good luck ____________________ You ain't a has been if you never was |
palmer |
palmer Fiddled Kiddy
Klause |
Posted: 11:17 - 19 Dec 2006 Post subject: |
garth wrote: | Hi.
Good luck |
Sounds good to me, does it take normal banjo bolt type lines? Other makes seem to use massive pipes and stuff. ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
Klause |
palmer |
Klause |
satans_BIG_helper |
satans_BIG_helper Nearly there...
Posted: 12:35 - 19 Dec 2006 Post subject: |
palmer |
Posted: 18:47 - 19 Dec 2006 Post subject: |
oh im sorry for asking |
Zimbo |
Klause |
Zimbo |
palmer |
Posted: 11:18 - 20 Dec 2006 Post subject: |
djr |
djr World Chat Champion
garth |
Posted: 15:59 - 21 Dec 2006 Post subject: |
what, to throw it in? ____________________ You ain't a has been if you never was |
palmer |
djr |
Posted: 17:26 - 21 Dec 2006 Post subject: |
Zimbo |
Posted: 22:34 - 21 Dec 2006 Post subject: |
That's the one, they come in two different fittings for the oil connections, BSP or metric, make sure you get the right one, although it probably won't matter if he's having hoses made up! |
Klause |
Posted: 13:41 - 23 Dec 2006 Post subject: |
Zimbo do the normal banjo type bolts fit that oil cooler then?
Just bought a puller to get a gear off a tapered shaft. Was so tight I had to put the impact gun on the puller! Should be splitting the cases today. Will update with pictures soon ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
Zimbo |
Klause |
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
