| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| syl |
 syl World Chat Champion
 Posted: 13:04 - 17 Dec 2006 Post subject: |
Look at the manual and see what torque ranges you'll need. The Halfords Professional ones are good:
Halfords Professional Torque Wrench 8-60Nm £49.99
Halfords Professional Torque Wrench 40-200Nm £49.99
Halfords Professional Torque Wrench 60-300Nm £59.99
Unfortunately, I expect you'll need two to cover everything. I've got the 8-60 and the 60-300Nm ones.
You'll also find a good selection at tooledup.com ____________________ Current bike: Kawasaki Z750S |
| stinkwheel |
| 5v3d3b0 |
| stinkwheel |
| Kickstart |
 Kickstart The Oracle
| syl |
 Posted: 17:50 - 17 Dec 2006 Post subject: |
How flush are your parents feeling?
Halfords Professional 150 piece Socket/Ratchet Set £99.99 (WAS £149.99)
You need a metric set, it's doubtful you'll need imperial sockets unless you're working on American or old British stuff.
Again, tooledup.com have got loads available. You'll want, in the main, 3/8" square drive sockets and wrench. 1/2" drive for bigger stuff and 1/4" drive for smaller stuff may be of use too, but if you're wanting to spend the least possible stick with 3/8" (which is probably what your toque wrench will bee too). You can get a metric socket set in 3/8" covering 6-22mm from as little as £23 or even less (£8) if you are happy with a slightly smaller range. ____________________ Current bike: Kawasaki Z750S |
| MattEMulsion |
 MattEMulsion World Chat Champion
 Posted: 18:49 - 17 Dec 2006 Post subject: |
Don't go and spend too much money on a torque wrench as you won't get that much use out it. Unless you are using them often then they sit there and gather dust.
I have had one for ten years or so and mine came from Argos if I remember rightly. They still do one, which looks about the same as mine, it goes from 28-210Nm, and is only £14.99. It will be calibrated as well and will do pretty much everything you need it to. When I bought mine they were a damn sight more than £14.99 so this represents a good deal.
I wouldn't worry about getting one that will go right down to the really low settings like 7Nm, you can judge these things quite easily with a normal ratchet, it is going to be things like head bolts that are more critical and what you need a torque wrench for. Often as well the small torque figures are for bolts where you are only able to use spanners rather than sockets, so the use of a torque wrench isn't always applicable to every torque figure.
In the ideal world you should have a torque wrench recalibrated every year or two anyway, but very few people bother, unless they are using them in a professional environment and who is to say that in a few years your torque wrench will still be anywhere near accurate.
For these reasons I wouldn't spend a fortune on a torque wrench, you might as well have a cheap version rather than an expensive one. The Halfords Professional one that is listed in this thread is £49.99 that does 40-200Nm, whereas the Argos one is £14.99 and that does a slightly wider range of 28-210Nm. It is less than 1/3 of the price and it does exactly the same job. ____________________ Yamaha YZF-R6 |
| 5v3d3b0 |
| Kickstart |
| gavin |
 gavin World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
 Posted: 20:22 - 17 Dec 2006 Post subject: |
For the nuts/bolts that are undone on a regular basis I use impact sockets on a normal ratchet or torque wrench, as they are a very good fit on the fixing and will not round it off.
https://www.mytoolstore.com/sk/85621.jpg ____________________ Andy Sez....
F.Y.Y.F.F. |
| irving |
 irving Traffic Copper
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 12:19 - 18 Dec 2006 Post subject: |
With the Torque wrench purchasing i only spent £22 on one from argos it does the job for everything i will ever need on a bike and didnt set me back £50 its been invalueable, I really rate halfords tools but with something im not going to use too often i buy a cheaper one as its not as if im gonna wear it out only needing it once a month at most
And impact sockets are worth their weight in gold (and they weigh a fair bit too ) |
| loply |
 loply World Chat Champion
 Posted: 23:09 - 18 Dec 2006 Post subject: |
I'll take this opportunity to point out an important but often overlooked point:
Once you get the torque wrench, always store it with the wrench set to 0nm or below. Storing it under pressure will quickly decalibrate it, and then you may as well be guessing. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| sickpup |
 sickpup Old Timer
| Ichy |
 Ichy World Chat Champion
The last post was made 19 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
