Warming up...
TiN
Pocket Tin
PostPosted: 09:59 - 07 May 2002    Post subject: Warming up... Reply with quote
Ok, so we all know that it would be best to warm up 2-strokes before riding them, but does the same apply to 4-strokes?
Cheers,
Tin
minesweeper
Whoah there!
PostPosted: 12:08 - 07 May 2002    Post subject: Reply with quote
I'd recommend warming up a four stroke bike through you wouldnt require anywhere as long as a two stroker. A minute tops should be enough depending on the bike, my zzr250 runs fine after about 45 seconds on 1/2 choke
matt
McJamweasel
BCF Junkie
PostPosted: 13:18 - 07 May 2002    Post subject: Reply with quote
Minesweeper - whats the zzr like? Im kinda half considering one.
minesweeper
Whoah there!
PostPosted: 13:39 - 07 May 2002    Post subject: Reply with quote
If your after a large performace hike from the nsr look somewhere else, if your looking for a good next step with cheap insurance and stable performance try one out. Id recommend the zzr400 not much larger but will perform alot like the 600 just cheaper allround
max speed around 110mph ish havnt realy pushed it myself. Very comfortable and extremely smooth ride. The looks not for everyone but i think it looks like a much larger bike with its dual cans and nicely built in indicators. Fuel capacity is 20 litres which should get you around 200miles to the tank! oil costs are off course non exsistent incomparison to the nsr
This is my exact bike
https://www.bikepics.com/pictures/09798/
anything else you want to know ask
matt
Keen
PostPosted: 15:25 - 07 May 2002    Post subject: Reply with quote
How long are you supposed to warm a 2 stroke up for before riding it?
minesweeper
Whoah there!
PostPosted: 15:42 - 07 May 2002    Post subject: Reply with quote
id give it around 2 mins minimum realy depending on the conditions outside as well, keith can give you exact times to the second Smile
matt
Keen
PostPosted: 18:41 - 07 May 2002    Post subject: Reply with quote
thanks- I'll probably try and give it 3-4 minutes then just to be sure Smile
TiN
Pocket Tin
PostPosted: 20:04 - 07 May 2002    Post subject: Reply with quote
I usually leave it for about 10 mins before I move off!...that's why I decided to post the original question...
Tin
PostPosted: 20:06 - 07 May 2002    Post subject: Reply with quote
Personally I would ride off ASAP, as long as the engine is warm enough to be safe. Once riding it will warm up more quickly. When cold the clearances are all over the place, and that is why wear is occuring. Also, if you have the choke on then the extra petrol will was alot of the oil from the cylinder bores, again increasing wear
Personally I normall get everything on, sit on bike start engine and put it in gear and go, and doing this I can ( on the BAndit and the RS) normally get away without using the choke
MultiSync
i have a 100cc Sym Jet (Scooter) at the moment, ive never warmed that up, runs ok - should i be warming it up?
Also when you mention warming are you talking about being stationary and letting the engine idle or just driving steady away for a few mins? When i get my shiny new NSR i wanna know exactly how to treat it
McJamweasel
BCF Junkie
PostPosted: 20:08 - 07 May 2002    Post subject: Reply with quote
I do similar to keith. I fire it up, choke for a few seconds if it needs it, put my hat and gloves on then go.
PostPosted: 20:36 - 07 May 2002    Post subject: Reply with quote
The important thing is to not thrash the engine until it is warm
The last post was made 23 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.6 - MySQL Queries: 13 - Page Size: 71.29 Kb
