Paivi |
Paivi World Chat Champion
Posted: 17:50 - 04 Jan 2007 Post subject: Lights: bayonet to screw cap? |
All my light fittings are for bayonet bulbs. Can they be changed to screw caps? If so, can I give it a go myself or is it a job for an electrician? Also, what kind of shop would have the fittings, B&Q?
Thanks! ____________________ My other bike's a Monster... |
Resurrection |
Resurrection Ballast Boy
Visitor Q |
Visitor Q $25 whore
Posted: 18:14 - 04 Jan 2007 Post subject: |
Why would you prefer screw caps, might i ask?
Light bulbs are about a quid each, so i can see the offer of freebys working out cheaper then the cost of converting them all... ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
Pte1643 |
Pte1643 Nearly there...
tatters |
tatters Exxon Valdez
Posted: 18:17 - 04 Jan 2007 Post subject: |
Depends on what fittings you have in your house that you want to change, then again why bother changing ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
Paivi |
Posted: 18:47 - 04 Jan 2007 Post subject: |
I want to change them because I'm struggling to change bayonet bulbs with just one hand (without breaking them in my hand when I squeeze too hard; yes, that hurt and caused a trip to the A&E). I'm used to screw tops and can change those with just one hand.
I have ridiculously high ceilings and the lampshades (big round snowballs) don't allow easy (or any) access from the top, especially when combined with high ceilings, short person and no ceiling clearance.
Because of the electrics in this house, I keep having to replace them fairly often, and it's just a bit dangerous for me. ____________________ My other bike's a Monster... |
Visitor Q |
Visitor Q $25 whore
Sparks! |
Sparks! Sir Tart-a-lot
Posted: 19:32 - 04 Jan 2007 Post subject: |
I don't know the full story, but why are you only using 1 hand? cna't you use both? as i say, if theres a reason why you can't I apologise as I didn't know and didn't notice you say anything about it in your post here... ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Paivi |
Posted: 19:43 - 04 Jan 2007 Post subject: |
Because I can't get both hands into the snowball to change the bulb due to a narrow opening, nor can I get there from the above, as there's no access and/or it's too high, so I need to do it blind and with just one hand. ____________________ My other bike's a Monster... |
scoota bk |
scoota bk Scooby Slapper
Sparks! |
tatters |
Posted: 23:01 - 04 Jan 2007 Post subject: |
stinkwheel wrote: | I suggest you get some energy savers, then you wont have to keep replacing them.
there also easyer to fit than normal buld type lamps as there long and squareish. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
Syx |
Syx World Chat Champion
tatters |
Posted: 04:34 - 05 Jan 2007 Post subject: |
Syx wrote: | To answer the original question, it's a simple task. Don't bother with an electrician - it'll cost you the earth for something you can do yourself.
The white (usually) connector is what needs changing. Get down to a DIY place and buy the screw-cap type. Then come home, and get a ladder out.
Remove the shade. Unscrew (by hand) the white (again, usually) cover where the cable comes down from the ceiling and meets the connector. Note: I don't mean the bit ON the ceiling, I mean the bit on the end of the wire! Inside are two wires, live and neutral. Unscrew the clamps and remove them. Take the old fitting and put it aside. Look at the connections for the new fitting, and attach accordingly. Refit shade.
Repeat for other lights.
When done, stick the lot of the old connections on eBay - you might make some money back. |
FFS, SAFE ISOLATION OF THE SUPPLY BEFORE YOU TOUCH ANYTHING!!!! if you,re going to give advice on electrics know what your taking about and include in the first sentence the proper method of isolation or you are going to get people killed. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
Pte1643 |
feef |
feef Energiser Bunny
Paivi |
Posted: 13:59 - 05 Jan 2007 Post subject: |
OK, you're scaring me now, guys! The landlord is sending his sparkie today to replace all my bulbs with energy saving ones, so hopefully I won't have to do it again in the near future.
When they're energy saving, does it also mean that they use less electricity, so I might not have to keep running to the fuse box to flick the switches up as often as I do now? I think I keep overloading the fuses, as every so often when I turn something on, one of the four switches goes 'off'. ____________________ My other bike's a Monster... |
feef |
Paivi |
Posted: 14:07 - 05 Jan 2007 Post subject: |
Sparks! |
Posted: 19:38 - 05 Jan 2007 Post subject: |
holy fuck dude, if someone tried that without reading the rest of this thread don't touch anything till you known its dead... im over 2 years into my apprenticeship now, worked 7 days a week all summer, every aspect of work, private jobs and work at home but I've NEVER had a shock, not even a small one... always isolate and test before touching anything! ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
tatters |
Posted: 20:15 - 05 Jan 2007 Post subject: |
Sparks! wrote: |
holy fuck dude, if someone tried that without reading the rest of this thread don't touch anything till you known its dead... im over 2 years into my apprenticeship now, worked 7 days a week all summer, every aspect of work, private jobs and work at home but I've NEVER had a shock, not even a small one... always isolate and test before touching anything! |
Your going to get a whack at some point we all do
During my apprenticeship l,ve had shocks from a 3 phase motor and a single phase led temp display, the motor was because the casing wasn,t earthed and a phase was in contact with it inside the termnial box and the display was my finger sliping and touching the exposed PCB on the back when trying to push it back to place.
Extreme pins and needles feeling all over the body while being thrown across the floor plus it hurts like hell and you hear a "nananananana" sound going right through the head. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
Sparks! |
Visitor Q |
Visitor Q $25 whore
Posted: 01:41 - 06 Jan 2007 Post subject: |
I got done by a pressure washer whilst standing barefeet in a plastic tank. Just very glad i hadnt sprayed everywhere first.
Still... woke me up a bit.
I doubt highly it will kill you though, its just unpleasant. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
The last post was made 17 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
