my arrow exhaust!!!!!!!!!!!!!!!!!!!
tanner18
PostPosted: 14:04 - 27 May 2002    Post subject: my arrow exhaust!!!!!!!!!!!!!!!!!!! Reply with quote
the cans very loos on the chamber pipe the bracket keeps it in place but a little oil leaks from this point surely this is reducing my performance back pressure and all that stuff what should i do get it welded or will an exhaust paste do keith ure good with bikes please help !!! Crying or Very sad
inline 4's rule
James
PostPosted: 14:46 - 27 May 2002    Post subject: . Reply with quote
If its just the can thats loose you wont lose any power. The back pressure is determined by the stinger pipe. That is the narrowest part of the exhaust and is located just before the can.
You're best off getting it welded. Exhaust pastes will do as a temporary repair providing whatever your putting it onto is rigid. The paste dries very brittal and the slightest movement causes it to deteriorate.
Im not familiar with the Arrow pipe for the NSR. Im presuming the silencer is an integral part of the exhaust and cannot be unbolted. If im correct the following applys.
The exhaust is made from very thin steel so a little 80 amp mig welder will make a neat job of sealing it up.
Like shit off a stick
Nige
PostPosted: 20:30 - 28 May 2002    Post subject: Reply with quote
I have used the exhuast pastes on mine, but it just gets blown out after a few runs. So i wouldnt waste money on that. For mine i need a proper wire mesh gasket, that fits between the two overlapping pipes, but i cant seem to get one??????. U might have better luck, but welding is very permanent, and should only be done as a last resort ( if welding it on, make sure the battery on the bike is totally disconected to avoid seeing ur wiring go up in smoke ).
Make sure u have a decent exhaust clamp ( stainless steel, no more than £5 ) and tighten it up as near to the end of the ajoining pipes as possible. Using some strips of old cole cans between the slip joint may help a little too, thats wot i did, and all is ok for now, but i want that mesh gasket really.
Ok, try that and see how u get on.
Nige
The last post was made 24 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 14 - Page Size: 36.39 Kb
