| FLASH |
 FLASH Nova Slayer
 Posted: 15:35 - 13 May 2002 Post subject: tuning tips !! |
has any 1 got any tips how to make my nsr125 rk go faster it is an import and it is on a g plate would a racing pipe and can help ? ive been told k+n filterwould make alot of difference plz help  |
| G |
 G The Voice of Reason
| James |
 James Spanner Monkey
| Dylan |
 Dylan Trackday Trickster
| James |
| Danny |
 Danny Guest
| James |
 Posted: 18:37 - 15 May 2002 Post subject: . |
Yeah youll need to remove all the airbox and pipes. Bolt your K&N directly to the Carb inlet.
I went up exactly 20 sizes on the main jet and didn't touch the pilot jet for a while.
By the way Danny mate, if i was you when ive fitted all stuff i wouldn't put any plastics back on your bike cos youll only be taking them off every five minutes as itll take a ew attempts to get your jetting right. Engines love cold air, sadly when you fit your K&N, in summer it gets loads of air but the induction temperature is slightly higher. Id like to explain in more detail but im ina bit of a rush fella.
I had a web-site with some tuning stuff on there, but ive took it off to redo it. I writ a jetting article but never got round to finishing it.
The following should help you a little, the only way to really know how the bike is jetted is how it feels with different jets. Trial and error kind of thing. Anyway heres my jetting milarky:
Jetting: The jetting of a carburettor is the most important aspect of any engines performance. You can have your jetting in three different variants:
Lean Jetting: This is where the mixture of fuel to oxygen contains too much oxygen in relation to petrol. When jetting is like this it can make the engine run either very well, clean and crisp. Or it makes the engine gasp at full throttle and pull badly when under load. I prefer having an engine jetted the leaner side of perfect. The bike revs extremely cleanly without any bogging down and more importantly doesn’t have any flat spots at mid-rpm’s. Be very careful not to jet too lean as this will eat the engine and can cause a top-end seizure on any two-stroke. Its also worth noting that a leaner engine will run hotter.
Perfect Jetting: This is how most bikes come out of show room. However with 2-strokes manufacturers predominantly jet their bikes slightly rich, this slims the chance of a seizure and prolongs engine life and reliability. To determine how your bike is jetted you need to examine the spark plug. Most 2-stroke tuners will tell you to go flat out in top gear up a slight hill, pull clutch in and let engine stop. Then pull over and look at spark plug. This method is good, but it only tells you how the bike is running when flat out and will only tell you how the Main Jet is working. Instead of that procedure just ride the bike as usual and look at the plug occasionally. If the plug is black this is caused by soot fouling, and this is caused by having a mixture that is too rich. Eventually this mixture will lead to a weak spark and a misfire. A plug that is a light tan or brown colour is pretty much perfect. A plug that is a grey colour or has a blistered electrode usually indicates too lean carb jetting.
Rich jetting: If your engine doesn’t pull very well and makes an engine like a machine gun firing at mid-rpm’s then its very likely the carb jetting is too rich on the main jet.
I never got round to finishing the articel in greater detail. I really wanted to go about the feel of the bike etc but my many years of tuning since an early age have made me slightly tired of the subject. I prefer messing with my Rover 200
Good luck,
be careful though, cos its so easy to bash barrels with lean jetting. ____________________ Like shit off a stick |
| Danny |
 Danny Guest
| Arne |
 Arne Guest
 Posted: 12:03 - 27 May 2002 Post subject: |
Anser for fuck sake!  |
| tanner18 |
 tanner18 Traffic Copper
 Posted: 12:09 - 27 May 2002 Post subject: whoa |
chill out arne  ____________________ inline 4's rule |
| James |
The last post was made 24 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
