Moving brake unit to new handlebar
Arfdog
PostPosted: 17:12 - 07 Feb 2007    Post subject: Moving brake unit to new handlebar Reply with quote
When I remove the brake lever + reservoir unit from the bike's bars, in irder that I can replace the bars with a new set, do I need to bleed them, or keep them upright, or take any such precautions, or are they a completely sealed unit and I need not worry about that?
Thanks.
I'm a lover, not a fighter.
Bishbash
PostPosted: 17:51 - 07 Feb 2007    Post subject: Reply with quote
Yes it is a completely sealed unit, so it should not leak. Just be careful when the cables and wires are loose as this could cause stress and wear to the cables and stuff.
What bike you running?
PostPosted: 18:55 - 07 Feb 2007    Post subject: Reply with quote
If you were to turn the master cylinder upside down and pull the lever, you'd draw a nice air bubble into the line.
As long as you don't pull the lever with it upside down, it'll be fine. Just swap over and use as normal.
The last post was made 19 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.34 - MySQL Queries: 14 - Page Size: 34.83 Kb
