| Smudge |
 Smudge Two Stroke Sniffer
 Posted: 17:30 - 09 Jun 2002 Post subject: Any experts on RK's??! |
Hello again all!
Firstly, how do I know exactly which model of NSR I have? I think it's an RK but what are the differences between that and an RL for instance? (the bike is '91/'92)
Next... me piggin forks, I changed the seals last night for a new set of gen Honda ones from David Silver Spares (good guys!) and the ones that came out had metal cup things as part of the seal... the new ones didn't, but I thought "hey, it's probably just a change they made," unfortunately when I dropped the bike off the stand today and pumped the forks the (nice new) fork oil started pumping out past the seals
So HELP!! have I got the wrong seals? is there a right way up / wrong way up??
Finally, are the forks supposed to make a "clunk" noise on being bounced up and down...? or is it ANOTHER thing bu66ered
Hope somebody can help!
Cheers, Smudge ____________________ "I feel the need..." |
| Hunter |
 Hunter Nitrous Nuisance
| G |
 G The Voice of Reason
 Posted: 20:21 - 09 Jun 2002 Post subject: Re: Any experts on RK's??! |
AFAIK there's very little difference between the different RL etc models... different fairing/headlight configuration possibly.
I had to have the forks on my bike re-sealed unfortunatley as I absolutley *had* to have it to get to work at the time I got it done at a garage, just incase I messed something up.
The clunk could be the forks bottoming out due to lack of oil, or it could suggest slightly bent forks, or even possiblt some missing bearings in the yoke. It's definatley worth checking to see if the fork stanchions are straight... these could have caused the seals to leak and thus mean the problems gonna happen again anyway.
As for the seals I'd take 'em back to your dealer and make a fuss.
Btw. the manual says the oil should be 'ATF'... I've got the manual on my site (click on the G at the bottom) if you want it.
If you need any advice for doing it you could try asking Annabella (nicely )... I think she's succesfully done it on a Rk model. |
| Hunter |
 Posted: 19:16 - 10 Jun 2002 Post subject: |
DOES ANYONE KNOW HOW DIFFICULT IT IS TO CHANGE FORK SEALS IN AN NSR?? ALSO, WHAT DOES 'ATF' STAND FOR?  |
| Smudge |
 Posted: 19:57 - 10 Jun 2002 Post subject: |
Hi Again!
Story so far...
The 10w oil is I reckon FAR too thin, it was a guess based on my GPz and XBR both of which weigh (lots) more and use 10w...
SO, I'll try again with ATF (Automatic Transmission Fluid, Hunter), that may also remove the "clunk" which I think is the damper cartridge moving too freely due to the thin oil (I hope!).
Having done a search of the RK/RL/RM part no's they all use the same fork seals and NS ones are totally different so we reckon I've got the right seals. (David Silver Spares are very helpfull when you ask them awkward questions ) The fische does however list a "washer" to go between the seal and the retaining circlip so I have that on order Hopefully the change of oil and the addition of the missing "washer" will do the trick, I'll keep you posted!
In answer to Hunters question, stripping and building the forks is pretty straightforward, as long as a halfwit hasn't been in before you and left out some of the parts (why is it always me!)
Just take your time, do one leg at a time, clean EVERYTHING, be gentle with all the parts you intend using again and keep track of what goes where... easy huh
G, thanks for the advice... I downloaded the bit of the manual I need... now I just need to work out how to unzip it Ta anyway,
Oh and I refrained from asking Annabella how she successfully "did it" on an RK as I think the answer might make me blush
Take it easy out there,
| G |
 Posted: 20:41 - 10 Jun 2002 Post subject: |
To unzip it you just need winzip (the evaluation version). |
| Annabella |
 Annabella Like a person, only smaller
| Smudge |
 Posted: 22:19 - 10 Jun 2002 Post subject: |
Hi Annabella!
Yes it's a dead simple job, (or it should be ) I've just hit a couple of probs because it's an unfamiliar bike and the gen Honda seals are different from the ones that were in there! Oh and a previous "mechanic" managed to do the fave trick of re-assembly with parts "left over"...
The bushes are ok, I habitually check these whenever I have a set of forks apart... so I won't give you any conclusions until I'm more sure of tha prob
The reason I didn't say "the jobs easy" is that for all I know someone reading this can't even change a plug... and I don't want them stuck with a set of stripped forks blaming me 'cos they can't put them back together again....
As I think I mentioned, the seals that came out have a thin metal cup on one side, are black rubber and have one metal tensioning spring in them, the replacements are normal black rubber with two tensioner springs... weird huh
Cheers Anyway
| Annabella |
| Smudge |
 Posted: 22:39 - 10 Jun 2002 Post subject: |
Yeah I thought it was a bit weird, old ones seemed an ok fit... had been fitted by an ape with a hammer but ignoring that ok.
New ones look right for the stanchion but a bit loose in the top of the fork leg. I'm hoping the washers when they arrive will snuggle down the seals (good tech expression huh ), enough to get a good seal!
As I say I'm pretty sure the replacements are right, and the forks look standard (as far as I can tell)... Maybe the ape force fitted non stock seals?? ____________________ "I feel the need..." |
| Hunter |
| Smudge |
 Posted: 19:41 - 11 Jun 2002 Post subject: |
ATF generally doesn't give you a choice of grade If there is then go for normal "car" ATF
and yes you will easily replace and compress the spring enough by hand
Good luck, Smudge
Oh and if you take it apart and the old seals match my description then please tell me!! Ta, S ____________________ "I feel the need..." |
| Annabella |
| Smudge |
 Posted: 23:37 - 12 Jun 2002 Post subject: |
Hi Annabella!
I think it was youthfull exuberance and complete incompetence that led to him hammering the seals... they weren't too tight at all, I guess I'm just good at buying bikes from people whose toolkits consist of a range of different sized hammers
I guess I should change my signature... how about (delivered through a megaphone) "We've got you covered, put the spanner down and step away from the toolkit"  ____________________ "I feel the need..." |
The last post was made 24 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
