Exhausts and Oil
Crestfallen
PostPosted: 21:42 - 30 Jun 2002    Post subject: Exhausts and Oil Reply with quote
Hi All
I've noticed that my exhaust has oil coming out of the end over the past few days. The bike is a Aprilia RS125 and is only like 9 days old. The oil started off a brown colour but is now black (due to the exhaust carbons polluting it?)
I first noticed this when my bike was parked and i saw a small drop on the ground below where the end of the exhaust is. Is this normal for 2 strokes?
I know that they aren't very efficient at burning the 2 stroke oil properly and part of the exhaust fumes are unburnt oil along with the proper petrol fumes.
Regards
Doddmaster
PostPosted: 21:44 - 30 Jun 2002    Post subject: Reply with quote
Dunno if its bad or not, but it happens on my nextdoor neighbour's RS too! (it is 5 days old)
Robby
Dirty Old Man
PostPosted: 22:05 - 30 Jun 2002    Post subject: Reply with quote
this is only my reasoning and keith will probably prove it wrong, but with a brand new, ie not run in engine, the piston is much tighter fit in the barrel, so the oil cannot coat the barrel, it just gets scratched off by the piston and only some of it is combusted, leaving the rest of it to leave the engine with the exhaust gases.
also the oil is often turned up on bikes that are running in new engines to ensure it all goes smoothly, so the combination of these two should mean you get some pissing out the back.
as for it turning black that will just be the coke in the exhaust mixing with it.
you start getting worried when lots of petrol come out the back of your exhaust, my 50 did that when i left the tap on.
PostPosted: 00:02 - 01 Jul 2002    Post subject: Reply with quote
Fairly normal. 2 strokes dont manage to burn all the oil (or petrol), and you would be in deep trouble if the piston scraped all the oil off the bore
batman
PostPosted: 01:37 - 01 Jul 2002    Post subject: ya Reply with quote
ive had my rs since october and the oil will never go!
theres a filthy black mark on the cobble stone at my door from it and my cover is buried in oil-it will stay, the rs seems to piss out a lot more of its unburned oil and petrol than the nsr
PostPosted: 07:56 - 01 Jul 2002    Post subject: Reply with quote
I suppose it is worth noting that the RS exhaust is meant to be sealed to the engine using a high temperature silicone sealant, which is meant to stay soft. Never managed to find any to use, but that would stop the leak from the engine / exhaust joint
The last post was made 23 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.15 - MySQL Queries: 14 - Page Size: 47.08 Kb
