Gear Box Woes.....
phil_DT
PostPosted: 15:38 - 16 Mar 2007    Post subject: Gear Box Woes..... Reply with quote
hi all,
As i was riding home today, the bike started to drop out of gear and into a false neutral under acceleration?? The gearbox oil has been leaking slighty over the past few days due to a worn gasket and I have checked the dipstick but it seems to only have a minimal amount left in the bottom. So is my gearbox gone or is it the lack of oil that is causing this? Thankyou in advance for any advice.
1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres.....
phil_DT
PostPosted: 17:33 - 16 Mar 2007    Post subject: Reply with quote
Update: just went out to pick up some gearbox oil off my mate. As I was riding the bike down, a car braked heavily to avoid a dog. I slammed on and the back wheel locked causing me to slide into the back of this car. Anyways I was fine and as there was only a tire mark on the back of the car we both agreed to leave it. As i was getting ready to leave i noticed oil was leaking out of the bike and it was all over the back wheel. Its strange because its leaking out around the gear lever?? And to top off this fine day the bike will now not find neautal. I suppose the gearbox is Funked?
Timmeh
PostPosted: 11:01 - 17 Mar 2007    Post subject: Reply with quote
Your first job is to replace the leaking oil seal. Glad your near miss was exactly that, near. Give your rear a damn good scrub as well.
phil_DT
PostPosted: 14:34 - 17 Mar 2007    Post subject: Reply with quote
wel, i just drained the gearbox oil and i found lots of little bits of rubber? I presume that a seal has gone in the gearbox? would this cause it to be jumping out of gear? thanks
timjim
PostPosted: 19:21 - 17 Mar 2007    Post subject: gearbox leak Reply with quote
it sound as if the selector shaft seal has faied,id change the seal and run it round and see if it cures it or improves it..id definately sort the oil leak first.tim
phil_DT
PostPosted: 22:00 - 17 Mar 2007    Post subject: Reply with quote
yeah well thats my first job tommorow then. Then i have to change an engine in a scoot for my mate. oh wat joy Rolling Eyes
phil_DT
PostPosted: 17:29 - 19 Mar 2007    Post subject: Reply with quote
Well I have removed the Gearbox cover and had a poke around. I think the gear selector fork is worn. Would this cause the bike to jump out of gear?? thanks.
The last post was made 18 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 53.48 Kb
