Manky Chain Problem
MattEMulsion
PostPosted: 21:38 - 29 Mar 2007    Post subject: Manky Chain Problem Reply with quote
Right then guys, I'm after a bit of advice. I've just spent the last couple of evenings cleaning up the chain on my R6. Its gone a bit rusty mainly because I left it too long at the end of last year when I parked my bike up for the winter and didn't get round to cleaning it up quick enough.
Anyway I have managed to get it looking reasonable by using copious amounts of elbow grease and scotchbrite but it is still pitted on the surface of the side plates. Now I realise it has gone past the point of no return but what do you reckon is best to lube the chain with now in order to A: keep the rust at bay and B: if the rust does return, something that won't allow it to be seen so easily.
This is the second time I have had to clean the chain up like this, this year. Last time I just sprayed it well with my Motul chain lube, but the rust seems to have reformed underneath the lube itself. I'm keen to avoid playing this scrubbing and cleaning game all of the while. So anyone any ideas???
Yamaha YZF-R6
Dazbo666
PostPosted: 21:47 - 29 Mar 2007    Post subject: Reply with quote
WD40 to deal with the remaining rust, then a generous dose of chain lube right after a ride has always done the job for me. Thumbs Up
Word of the day : DILLIGAF
finpos
PostPosted: 21:49 - 29 Mar 2007    Post subject: Reply with quote
Used engine oil. It's veh cheap Smile
finpos.
GixerCol
PostPosted: 00:21 - 30 Mar 2007    Post subject: Reply with quote
Because the chain is pitted the rust will just keep building up the only thing you can do is slow the rust down,
ie take the chain off (if poss)clean it with a good chain cleaner and treat it with rust remover (Jenolite), be careful cos its prob an O-ring chain use a small panit brush,
Once treated, give it another clean and wipe off
Put it back on the bike and keep it really coated with a good chain WAX not OIL as it sticks more
This should give you the rest of the year without any probs as long as you keep putting the wax on Very Happy
Hope this is of help Smile
The last post was made 18 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.64 - MySQL Queries: 14 - Page Size: 40.58 Kb
