bike wont start (starter problems *grumble*)
element
PostPosted: 20:34 - 07 Apr 2007    Post subject: bike wont start (starter problems *grumble*) Reply with quote
Originally posted here but I guess I should make my own thread..
https://www.bikechatforums.com/viewtopic.php?t=111698
My bike (DT125RE) has been running without problems since july until one morning after I had been to shops....
I went to pull off and stalled Rolling Eyes anyways I put the bike back into neutral and tried the starter button as u do but nothing.. You could hear the solenoid clicking and that was it. I quickly found out that by putting it in first then rocking the bike and putting it back into neutral allowed me to start the bike. Anyhow a few weeks of pretty much starting first time I only occasionally had to do all the messing around to get it to start..
Now its got to the point where it hardly ever starts (apart from today when it started first time!! Shocked ) Most of the time now the solenoid just clicks and if I try put it gear then back to neutral, it'll try and turn for a second and then you'll hear a servo sort of noise for maybe 2 seconds and then nothing although its not often it'll do that. It will bump start without fail though but I dont like doing it.
Anyways Ive charged the battery (tried another too and still no luck). The reading after charging was 13v. With with the ignition on its 12.7v and then when I press the starter it drops to 12.5v. Ive checked the voltages after the relay (which I have also cleaned) is also 12.5v when pressing the starter. I also checked the voltages while the bike is running and it was 14.4v.
So if im not jumping ahead too fast I can pretty much rule out the battery(s) and the starter relay? So off I go and see how to remove the starter motor BUT (always something to stop you) I can only find one screw (fecking posidrive one at that Rolling Eyes ) and I can feel its a soft screw. I tried mildly with and impact driver but I can feel it just beginning to make a mess of the head so Ive left it incase I decide to take it into the dealership Shocked Shocked (feck it let them have the bother with it Mr. Green )
So before I do that is there anything I have missed? (Ive tried tapping the starter motor aswell)..
cheers
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
thefallenange...
PostPosted: 20:47 - 07 Apr 2007    Post subject: Reply with quote
simplest way to check a battery with a meter i find is to drop the lights on full because it's the highest drain on the battery. If it drops by more than a volt be worried but it sounds like the battery is ok.
Check the wiring in general because all auto electronics are crap basically. Something so simple you may have missed.
I'm saying the above with my bike in a million pieces becuase of an electrical fault.
Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
r.bridge1988@gmail.com
element
PostPosted: 21:18 - 07 Apr 2007    Post subject: Reply with quote
Had the tank and seat off today and checked everything. All seems good. Most of the main connectors and wiring are still shiny and new. The bike is only 3 yr old and was imaculate when I got it last year. Im starting to think now that its the actual starter motor (which I cannot remove. farking typical Rolling Eyes) but on a bike so young? Its only done just short of 10k miles Sad
thefallenange...
PostPosted: 21:28 - 07 Apr 2007    Post subject: Reply with quote
Age means bugger all. Have you checked for known faults on the DT125's on a dedicated site?
try this https://www.125ccsportsbikes.com/forums//lofiversion/index.php?t38247.html
element
PostPosted: 21:44 - 07 Apr 2007    Post subject: Reply with quote
Ive not heard of any probs with DT starter motors. Ive a friend who's has 3 DT's all older ones so he uses the kickstart and ive also got another friend who has the same year as mine and has hammered his offroad (without a bashguard aswell Shocked. The starter motor is quite exposed)
Also my bike runs as normal once bumped.. its just starting it Sad
Have looked around the net for DT starter probs aswell and found nothing and I also spoke to the mechs at the yammy dealership and they said its prob the battery or the relay....
gilbert7
PostPosted: 16:23 - 08 Apr 2007    Post subject: Reply with quote
if the screw is that bad then corrosion has probably got to the starter motor.
also you'll want to follow the wires from the starter motor and check the connections. don't just look at the connections take them apart and look in them because if dirt or corrosion has got in them this could stop them working.
MattEMulsion
PostPosted: 08:10 - 09 Apr 2007    Post subject: Reply with quote
From what you have described it does sound like your starter motor is sticking. If you can sometimes rock it into action then it starts fine, my guess is that all of your problems are starter motor related and not battery or wiring.
If you can't get it off without butchering it then may I suggest that you take it to a professional, to be sorted out before its fittings get too damaged.
Yamaha YZF-R6
rik220
PostPosted: 10:37 - 11 Apr 2007    Post subject: Reply with quote
I had the same problem with my scooter. Turned out my starter had seized, and i mean locked solid.
Honda x8r. Aprilia Rs50
Honda CR85
Renault Clio 1.2
element
PostPosted: 15:59 - 11 Apr 2007    Post subject: Reply with quote
ive pretty much exhausted any other options. The only thing left is to try a brand new battery but im sceptical since according to my battery charger both of my batteries are fully charged.. Both read 13v when charged and read at 12.5v when pushing the starter. Not only that £30 wasted on a battery I dont need could be spent on an hours labour.. You know it actually makes me want to cry at the thought of having to actually get someone to take my starter motor off. If I could get it off, Id fix the bugger myself..
I did a quick check though to see the voltage when it does occasionally try and turn and the voltage drops to 10v..
I am almost 90% sure its the starter motor but I wanted to try everything else before I bend over for the dealer Crying or Very sad
The only time it rarely fires up off the button is after its been riden for a while but even then you got to prat about putting it in gear, rocking the bike and then back in neutral.
Thanks to all for the advice so far..
edit... And i hate to think the price of a new starter. Was reading about the tt250 starter problems.. £200 for a starter?! oh boy.. Luckily my bike shares its engine with the newer tzr's and tdr's so it'll make the hunt for a second hand one that little bit easier..
MattEMulsion
PostPosted: 16:22 - 11 Apr 2007    Post subject: Reply with quote
element wrote:
ive pretty much exhausted any other options. The only thing left is to try a brand new battery but im sceptical...
I am almost 90% sure its the starter motor but I wanted to try everything else before I bend over for the dealer...
There is little point in keep trying this and that, its a starter motor fault and nothing short of having the starter motor repaired/replaced is going to fix it. The sooner you get the starter off or take it somewhere to have it taken off for you the sooner you will have a working bike once again.
Yamaha YZF-R6
The last post was made 18 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 16 - Page Size: 74.05 Kb
