Screammmmmmm
PostPosted: 12:49 - 14 Feb 2002    Post subject: Screammmmmmm Reply with quote
Just needed to get that out of my system.
Last night I filled the Bandit with petrol and rode home in the rain. Came off the M6 at junction 13 and the bike was running badly (misfiring) so got home and dowsed everything with WD40.
Got up this morning and tried to start it. Not a hope so got some jump leads out and tried. Got it running but it was really bad. Noticed the fuel gauge barely registered.
Took the Aprilia out, but flat battery from not having been run for a while. Bump started it but no joy with lghts etc. Rode a few miles down the road and still no joy so took it home and rang in to take the morning off.
Found problem with the RS is not much time. A connector into the regulator had corroded so it wasnt charging the battery (it could try as hard as it liked, but it would only get the electrons about 15cm from the regulator).
So time to fiddle with the Bandit. Discovered that another couple of tags on the bodywork had snapped off (the ones holding the seat surround onto the fuel tank), so not best pleased. Took the tank off and took the airbox lid off and the bike dumped a load of petrol on the ground. Took the airfilter out and it is soaking wet with petrol. The airbox was litterally half full with petrol. Seems I have a sticking float. Managed to get the carbs off, but cant get the float bowls off to look inside (the bolts holding the float bowls on are very tight, and they are stupid little cross heads), so any more investigation will have to wait until tonight.
I had left the bike on prime and it had litterally emptied the fuel tank through one of the carbs, most of it landing up in the airbox. Given the pathatic amount of fuel left and that it had only done 29 miles from filling up I think it has managed to loose about 3 gallons of petrol (well, under 10mpg is not a record I want to improve on)
Hex
Party Boy
PostPosted: 14:44 - 14 Feb 2002    Post subject: Reply with quote
For a sticking float I was told to take the petrol hose of the tank side and blow into it hard! while doing this knock the float bowl with a screwdriver (handle side Wink ) and then try!
worked for me may be worth a try rather than dismanteling the full thing?
HTH
Hex
Korn
Admin
PostPosted: 16:06 - 14 Feb 2002    Post subject: Reply with quote
Very nice morning you must have had. I know when you've just got out of bed the last thing you want to be doing is getting covered in grease, muck and petrol Crying or Very sad
retrofly
PostPosted: 17:09 - 14 Feb 2002    Post subject: Reply with quote
Even more trouble with the bandit ,ive said it once ond ill say it again put the bandit to rest and get something more reliable like a CBR or soumthin
Luke
PostPosted: 17:15 - 14 Feb 2002    Post subject: Screammmmmmm Reply with quote
life sucks Confused
PostPosted: 20:32 - 14 Feb 2002    Post subject: Reply with quote
Thanks for all that, makes me feel better.
Tapping the float bowls can work, but it depends on why the float is sticking. A bit of grit you are unlikely to dislodge. Add to that there are 4 float bowls to choose from. The carbs are now off, and externally cleaned up a bit. I will get the float bowls off at the weekend and may even have a chance to refit them.
Fortunatly there was little oil and grease to get covered in. The petrol (must be at least 3 gallons / 13 litres lost) washed it all off!
As to more reliable, look at the pictures in MCN of the CBR600 being used through winter. My brakes, etc are in better condition than that after 5 years of use, plenty of it in winter.
Occasionally (well, quite often) get tempted to buy another bike for commuting (probably a GPZ500, faired, cheap on petrol and tyres and 10 a penny 2nd hand), and then buy something else for use with a pillion. The Bandit does well with a pillion and is overall fairly reliable. Trouble is what would I get, as I have got quite used to the torque. A VFR750 / 800 would probably be the most likely, but a Triumph Trophy 900 or 1200 (early ones) is also possible, or a Sprint.
TJ NSR
PostPosted: 21:05 - 14 Feb 2002    Post subject: Bandit Reply with quote
i didnt think they were soooo unreliable
hows the hornet
PostPosted: 21:38 - 14 Feb 2002    Post subject: Bandit Reply with quote
hows the hornet
Most people dont ride them all year round, and I doubt there are that many up to 28000 miles
What Hornet? Or do you mean to buy one?
The last post was made 24 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.45 - MySQL Queries: 16 - Page Size: 60.81 Kb
