demoNSR |
demoNSR Scooby Slapper
Posted: 00:49 - 12 Apr 2007 Post subject: NSR 125 Won't start??? |
Hi guys , just a new member, joined a few days ago.
Went out for a ride tonight, started the bike as normal, with choke out for a minute or two. Then when i put the choke back in the bike cut out. Checked the petrol and found it was nearly dry, but still had about a cup full in the tank. So, off i went to the garage, petrol can in hand. Got back, put petrol in tank, and now bike wont start at all.
Was too dark to start checking fuel line for blockage, spark plug etc.
I dont think it could be a blockage in the line, because the inside of the tank is still really clean, like new (03 model)
So now i am wondering if it could be the spark plug, or maybe the carb is flooded.
Any ideas???
Will try starting it again in the morning, have turned the fuel tap off, so if it is the carb, hopefully it will have a chance to dry out.
Cheers. |
CRAZY_BIKER |
CRAZY_BIKER Guest
demoNSR |
Posted: 01:23 - 12 Apr 2007 Post subject: |
I was thinking along those lines, and was going to buy a new plug. But now i will have to go to the bike spares shop on the bus (groan ) if it doesn't work. Will give it a go though.
Cheers |
spike_Alike |
spike_Alike Spanner Monkey
Posted: 01:33 - 12 Apr 2007 Post subject: |
Try cleaning it first before you go and buy a new one! Should be obvious whether or not its damaged or just filthy.
You sure its not flooded? Battery has life still right ? |
demoNSR |
spike_Alike |
demoNSR |
Posted: 01:50 - 12 Apr 2007 Post subject: |
I think you are prob right fella. Will deff give that a go. Thing is, i have booked it in for new tyres tomorro too, and it is always the way when you need to do something, always something to bugger your plans eh.
Cheers mate |
spike_Alike |
Posted: 01:54 - 12 Apr 2007 Post subject: |
Sods law in action.
Best of luck with her, I'm sure she'll be ok, even if you gotta do a bit of fiddling first ____________________ Bandit 600 |
demoNSR |
Posted: 02:13 - 12 Apr 2007 Post subject: |
Cheers fella, i'll let you know how i get on |
alains |
alains World Chat Champion
demoNSR |
Posted: 10:40 - 12 Apr 2007 Post subject: |
Cheers Alains, i took the plug out this morning, and it badly needed cleaning, and gap reset. This seems to have sorted the problem. Cheers also to spike_Alike for your helpful advice. Replaced the plug after cleaning, and setting the gap, and she burst into life |
demoNSR |
Posted: 10:43 - 12 Apr 2007 Post subject: |
Cheers also to Crazy biker |
alains |
demoNSR |
Posted: 11:42 - 12 Apr 2007 Post subject: |
I know the BR9ECS is the standard plug, and the manual says you can also use a BR10ECS aswell, and i was thinking of that one too maybe. Will it make much of a difference, and if so, what difference can i expect?
Marci |
Marci Brolly Dolly
Posted: 15:31 - 12 Apr 2007 Post subject: |
Cleaner running... less carbon deposits left on cylinder and piston = increased performance longevity and a bit more response from the engine (widely debated) ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
demoNSR |
Posted: 23:06 - 12 Apr 2007 Post subject: |
Cheers mate, got a new plug, but the dealer only had the standard NGK BR9ECS. But it was only £2, bargain. And she is running sweet now. Will maybe still try the optional plug to see if there is a difference. |
alains |
Posted: 18:58 - 13 Apr 2007 Post subject: |
https://www.sparkplugs.co.uk buy a couple (one on , one spare under your seat) ____________________ the worst day fishing is better than the best day working |
demoNSR |
Posted: 19:37 - 13 Apr 2007 Post subject: |
Hi Alain. I have ordered a box of 4, from the guy who fitted my tyres yesterday, only £10, which is a bargain i think.
Thanks fella |
demoNSR |
Posted: 19:39 - 13 Apr 2007 Post subject: |
P.S. Your De-Restriction guide is also most useful |
CRAZY_BIKER |
CRAZY_BIKER Guest
demoNSR |
CRAZY_BIKER |
CRAZY_BIKER Guest
alains |
Posted: 08:59 - 14 Apr 2007 Post subject: |
you are a bit hard ! i told you to throw the genuine BR9ECS which are bull shit ! and you bought 4 of non suitable (for this bike) plugs
the BR9ECS can be swapped with a BR8ES (not BR10ES) , but they about the same . trust me buy BR9EIX or denso IW27 . they worth even they cost 4 times the genuine . optimised sparking , much longer life time , you'll spare about 1/2 L to 3/4 L by full tank , engine run far more smoothly , try it once , you wont be disappointed ____________________ the worst day fishing is better than the best day working |
demoNSR |
Posted: 09:24 - 14 Apr 2007 Post subject: |
Hi Alain. i was told that the BR10 EIX would be better for the summer, especially if i ride fast. As they can handle higher heat. But i will buy the BR9EIX too, and see which one works best, that was my plan. At the moment, i have a new BR9 (ES) installed, as that is all that was available at the dealers. But he is ordering the BR9 EIX, and BR10 EIX just for me |
alains |
Posted: 14:36 - 14 Apr 2007 Post subject: |
https://www.sparkplugs.co.uk shipped within 3 days ____________________ the worst day fishing is better than the best day working |
The last post was made 17 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
