 Noggin Traffic Copper
 Chriss World Chat Champion
 Posted: 10:21 - 30 Apr 2007 Post subject: |
What difference would I see (if any) by replacing the standard yamaha items with Hyperpro/Hagon/K-tech/Ohlins springs? And what sort of cost are they going to be? Also, what's the difference between progressive springs and non-progressive?
It's difficult to describe handling, as it can't realisticly be measured. I'd go for Ohlins springs, and my local place sells them for about £100 a pair. Progressive the spring gets stiffer the more you push it, and non-progressive, the spring keeps the same tension regardless how much you push it.
HTH. ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
 fuzz World Chat Champion
 Posted: 11:08 - 30 Apr 2007 Post subject: |
Progressive springs - good for road use, more plush ride as it's softer over small travel.
Linear springs - good for track use as the spring rate is constant
The main thing with replacing fork springs is to match them with your weight. Standard springs are obviously set for general joe public, but the advantage of using Harris/Ohlins etc is you can custmise it to you personally.
https://www.sonicsprings.com/catalog/calculate_spring_rate.php ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
