Coil / CDI whats the deal, are they bike specific?
Yoshi
PostPosted: 20:33 - 29 Apr 2007    Post subject: Coil / CDI whats the deal, are they bike specific? Reply with quote
First of all, is the coil and the cdi the same thing, as I have heard and seen people using both words for the same thing, but also using cdi for something else.
I thought the coil was the component which the HT leads come from to the sparkplug. But I have seen these referred to as the cdi. I thought the cdi was the electrical box which controlled when the plugs sparked.
OK so on my old suzuki TS250 when I unwrapped the insulating tape covering the coil (the thing connected directly to spark plug via HT lead) I was a bit surprised to find that where the original connection to the HT lead was, some numbskull has screwed a big screw into it, and wrapped the end of the HT lead around that as a connection. It does work though, the bike has been running like that, when i put the bike back together I'll probably leave it until it breaks.
But are they like reg/recs, where they are easily interchangeable between bikes or are they bike specific (ie I can only replace it with another TS250 one)
Thanks
Matt
Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250
Paddy Blake
PostPosted: 22:01 - 29 Apr 2007    Post subject: Reply with quote
You are right,that is the coil.They can have ane or two wires and the
connections can be different.You should be able to get one to suit it in the
breakers.
There are many different reg/recs so post a picture and someone might
know what other bike has the same one.
PostPosted: 22:02 - 29 Apr 2007    Post subject: Re: Coil / CDI whats the deal, are they bike specific? Reply with quote
CDI unit is a generic term people use for the ignition control unit (rather than what it directly stands for, Capacitor Discharge Ignition). They can be built into the coil, but they are not the same as the coil.
A coil is just 2 coils, one inside the other. Running a current through one induces a build up of current in the other. Interrupting the current through the first causing the build up in the other one to discharge, hopefully through the spark plug to generate a spark.
Marci
PostPosted: 14:16 - 30 Apr 2007    Post subject: Reply with quote
If you MUST leave it like that when you rebuild (which I don't advise due to the hefty current that the HT lead kicks out) then do it as follows...
Cut the head off that screw. File the stump into a point. SCREW a new HT lead onto that so that it meets up with the original part. Heatshrink over the join as best possible, then cover it with PlastiDip to seal it all up. I'd also spooge some dielectric grease over the joint before heatshrinking just to keep it watertight.
BUT a generic coil should only cost you £20 if not less and be fine for your bike... usually comes complete with integrated HT lead and plug-cap... most highstreet bike shops have em on the shelves...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
PostPosted: 14:21 - 30 Apr 2007    Post subject: Reply with quote
Coils are usually classified by their resistance (in ohms). Get the correct "ohms" coil and you should be okay. Put the wrong one in and you might kill the ignition module. Also be aware that some coils have "resistance leads" so the spark plug lead needs to be the proper value too.
Yoshi
PostPosted: 17:45 - 30 Apr 2007    Post subject: Reply with quote
Thanks for all the replies.
It'll be sometime before I get this bike back to the point of putting it back together. When I do i'll decide then about putting a new coil on it.
Matt
bish777
PostPosted: 20:33 - 03 May 2007    Post subject: Reply with quote
most electronic ignition systems use 3 ohm primary coils, if that helps.
GSXR1100J
The last post was made 19 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.69 - MySQL Queries: 14 - Page Size: 54.38 Kb
