Rear Shock Problem? Sucking Noise on Rebound!
c058y
PostPosted: 21:33 - 07 May 2007    Post subject: Rear Shock Problem? Sucking Noise on Rebound! Reply with quote
Hi All,
Just wanted to know your thoughts. The rear shock on my KWAK ZX6R F1 makes a sucking noise on rebound. I'm assuming this is not normal. Any thoughts on what the problem is?
The reason I ask is I fitted this today after buying from ebay and would like to use some technical terminology when contacting the seller.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=005&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=150113778109&rd=1&rd=1
Thanks for looking
Paddy Blake
PostPosted: 22:27 - 07 May 2007    Post subject: Reply with quote
Did you grease the bolts before you put them in.
Was it a tight fit at the top or bottom when you were fitting it.
Check if you can find out which part the sound is coming from.
Is it where the rod is or the hose or canister.
Just be sure it is the shock before you blame anyone.
Paddy.
willi
PostPosted: 23:43 - 07 May 2007    Post subject: Reply with quote
its normal its the oil inside. most shocks do it.
wat goes around comes around.
c058y
PostPosted: 13:10 - 08 May 2007    Post subject: Reply with quote
I'm not saying that there is a problem. When I purchased the bike the shock didn't make this noise. I then found out that shock had lost its damping.
If this sound is normal, then fine, there isn't a problem although I thought I would ask before mentioning this to the seller.
All seems fine riding the bike to work today.
feef
Energiser Bunny
PostPosted: 14:15 - 08 May 2007    Post subject: Reply with quote
Sounds like the shock has lost some oil and has got some air in there.. the sucking noise are the air bubbles in the oil passing thru the damping apertures. Normally, with no bubbles in the oil, it's silent.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
The last post was made 19 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.71 - MySQL Queries: 14 - Page Size: 45.17 Kb
