91y, nsr15
themaku
PostPosted: 21:39 - 26 Jul 2002    Post subject: 91y, nsr15 Reply with quote
what should i do that my top speed would be around 110mph? right now my nsr top speed is only 75mph!! there are no restrictors in the exhaust or intake housing. i just changed piston and piston rings, cilinder. what else should i do. by the way, nsr -s year is 1991. and what combination of sprockets do you recommend?
keep up the good work!
greetings, maku!
Ropehead
PostPosted: 21:59 - 26 Jul 2002    Post subject: Reply with quote
is your top speed when your RED LINEING in 6th gear?
Guest
PostPosted: 21:50 - 27 Jul 2002    Post subject: Re: 91y, nsr15 Reply with quote
You should buy nsr, which has made in 99
Scooby
Scrappy Doo
PostPosted: 21:52 - 27 Jul 2002    Post subject: Reply with quote
Erm... why you say he should buy a '99 NSR... methinks the engines are the same... just different cosmetics... and btw the nsr has been unchanged from its current design since '94.
Maybe your bike is an import, restricted somewhere else, maybe CDI unit???
themaku
PostPosted: 08:14 - 28 Jul 2002    Post subject: mhh Reply with quote
cdi unit? what is it? one more thing, rear sprocket is 35 and front is 13 i dont think thats normal? and how should i connect Exhaust power valve cables right so it will open and close at the right time(actually theres two ways, im gonna find it out which is the right way)!
greetings, maku!
ML--gerhard
PostPosted: 08:29 - 28 Jul 2002    Post subject: Reply with quote
In Germany is the typical rear sprocket 35 and front 14. Perhaps you should test that
PostPosted: 12:52 - 28 Jul 2002    Post subject: Reply with quote
If the bike is a 91 model import then it is unlikely to have been restricted when new (Italian market bikes certainly werent restricted at that time). My guess would be that the power valve isnt opening, as 75mph sounds rather too close to the speed at which it would open in top gear. However, that is just a guess and it could easily be loads of other things
Guest
PostPosted: 13:25 - 28 Jul 2002    Post subject: Reply with quote
My nsr goes usually 100 mph. Sprockets are 14/36, but i live in Finland. In here our nsr can give over 30 hv power..
I just came first time in here and I speak bad english.. Wink Embarassed
You can check my homesite, https://iridium2002.host.sk
Tell then to me, what you think about my homesite!! Wink
I should registeration in this site. Do you understand what I tell to you? I am really worse to speak english, but.. Rolling Eyes Smile
themaku
PostPosted: 20:38 - 28 Jul 2002    Post subject: sprocket Reply with quote
how much the front sprocket will effect my top speed if i change my 13 to 14. how many kph?
greetings, maku!
The last post was made 22 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.42 - MySQL Queries: 13 - Page Size: 56.57 Kb
