Removing Speedo/Tacho needles...
TiN
Pocket Tin
PostPosted: 17:48 - 14 Aug 2002    Post subject: Removing Speedo/Tacho needles... Reply with quote
Has anyone ever dismantled their clocks?...I took mine apart today, aiming to remove/replace the backing on the dials, but got a little stuck when I couldn't take the needles off the clock faces Confused
Do they pull straight off?...'cos I've tried that (ish), and they don't seem to want to budge, and I really don't want to break them unnecessarily...
Cheers,
TiN
dotgems.net
chunkielad
PostPosted: 19:06 - 14 Aug 2002    Post subject: Reply with quote
I don't think they come off - if you put water with a bit of fairy liquid on the new sticker, it should slide around enough to pass it over the needle and then stick down after that - squeegy the water out with a credit card after you get the right position.
The last post was made 24 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.52 - MySQL Queries: 14 - Page Size: 31.81 Kb
