Dan |
 Dan Brolly Dolly
Stew |
 Stew If it's good enough for top race teams...
 Posted: 23:33 - 22 Aug 2002 Post subject: |
From what I remember they were the dogs danglies in their day!
Very fast (for a 250 2stroke at least) but not the most reliable bike in the world (did I say 2stroke ). When I was 16 ( a long time ago) it was the bike I wanted when I turned 17, unfortunatley I never had the money.
Think top speed was something like 130 mph, probably not far off the performance of a RS250 really, perhaps not so good in the handling department though.
It would be getting on a bit now , make sure the engine is sweet before you buy it. ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
McJamweasel |
 McJamweasel BCF Junkie
Doddmaster |
 Doddmaster World Chat Champion
McJamweasel |
Kickstart |
 Kickstart The Oracle
 Posted: 17:38 - 23 Aug 2002 Post subject: |
They are very quick, but quite high geared. OK with a tail wind! One magazine managed to get one to 143mph I think (from dim and distant memory). Most have been slung down the road by now and I havent seen a nice one for ages.
As to reliability the problem was that the locating pin for the piston rings (ie the pin to stop the rings rotating round the piston) was not well secured and would come off, wrecking the barrels. Think that Kawasaki fixed that problem one later pistons, so fitting a new set to it should solve the problem. Otherwise I think they were fairly reliable, probably better than an RGV250
All thebest
Dan |
 Dan Brolly Dolly
EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
 Posted: 00:08 - 24 Aug 2002 Post subject: |
yo mate! the kr1s is a smart bike and when it first came out was the fastest production 250 ever at 140mph, 10mph faster than the rgv250 at the time. However it had longer gearing and the standing quarter times were well down on the rgv, which wouldnt be a bad buy itself (guess what i would go for ). I read somewhere that many racers fitted tz racing pistons instead of the kr1s pistons because of the peg popping out problems, so if your using it as a track bike this could be worth considering.
If you're thinking of gettin an rgv250 bear in mind that the engine is fairly reliable if properly warmed, hasnt any inherrent piston/ring/peg/whatever problems unlike the kr1s. The big thing to watch out for is one of the powervalves dropping into the cylinder if the pin becomes worn and elongated, however they can easily be modified to avoid this, and if you are buying a cheapish earlier model like mine they are a lot less likely to fail anyway, the 91-93 models were the main culprits. There are also a lot more rgvs about than kr1s's, so you wont have any trouble finding spares.
good luck!
ps: rings every 1 thousand miles!? what are you on! |
The last post was made 23 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
