| x1160 |
 x1160 L Plate Warrior
 Posted: 15:14 - 02 Jul 2007 Post subject: NSR wont start! |
okey my 2003 nsr doesnt start help , basically i was on holiday for 2 weeks down south and left keys with cousin, came back and it wont start, initially thought it was a battery problem so charged the battery for 1 hour and a half but still wont start, neutral light work etc although once i started the ignition it buzzes, if i hold on then after a bit u can hear a bit of a ticking sound as well as the buzzing, my cousin has admitted that he did infact rev it when the bike was not on (satistfy his lust for not having a license, i dont no ) anyways could it be that its flooded? and if so how do i go about correcting this problem? also where can i get a spark plug tool? or what your guys use to remove spark plug, spanner? sorry if i sound it bit off, i am not exactly a mechanical person. |
| ncrn |
 ncrn World Chat Champion
 Posted: 15:23 - 02 Jul 2007 Post subject: |
I had that, basically your battery is flat and if you can't charge it there is a good chance you need a new one. They are only about £15-£20. But first I would try charging the battery over night.
Holding the throttle open while the bike is off won't do much, if it does you just need to leave the bike for a few minutes and the fuel will evaporate or something. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| x1160 |
 Posted: 15:32 - 02 Jul 2007 Post subject: |
sorry about the confusion, what i meant to say is after charging the battery, the battery is all good, neutral light, side stand light, even lights are bright and in full working order, its the starting am hearing noises of ticking and buzzez? need to figure how to take that spark plug out and i thought reving without the engine on causes severe flooding and perhaps engine seizure? |
| baldy |
 baldy World Chat Champion
| x1160 |
 Posted: 15:52 - 02 Jul 2007 Post subject: |
Thanks for info so far boys appreciate help, how long do you think i should charge it for? any ideas? |
| ncrn |
| Grubby |
 Grubby Spanner Monkey
| alains |
 alains World Chat Champion
| lukamon |
 lukamon World Chat Champion
| alains |
| roach_101 |
 roach_101 Borekit Bruiser
| Cigaro |
 Cigaro World Chat Champion
| x1160 |
 Posted: 11:34 - 03 Jul 2007 Post subject: |
sorry guys but bump starting is a no no, 1stly i live on a main road, and 2ndly how the bike( most likly me ) may react to such methods, have had the bike just under a month, and did my cbt on a scooter (thinking that at the time am going to buy a scooter, but that went down the drain )
i left the charge on all night (12v), just tried starting it now and no more ticking, however am hearing a 'clang' sort of noise, its sort like a chain spinning, although its still not starting up, and about the spark plug, i need to buy a wrench, would this set do? and what website do the best deals on iridium spark plug, i herd they the best to use.
https://cgi.ebay.co.uk/10-PCE-PLANE-BOX-SPANNERS-SPARK-PLUG-OIL-PLUGS-WRENCH_W0QQitemZ120136998912QQihZ002QQcategoryZ2983QQssPageNameZWDVWQQrdZ1QQcmdZViewItem.
oh by the way thanks for the help so far guys  |
| Cigaro |
| alains |
 Posted: 13:05 - 03 Jul 2007 Post subject: |
if you hear the starter spinning and not the engine turning it's because the pinion doesnot engage the flywheel . could be 2 possibilities :
- battery is worn (not enough power even full charged) easy to test : if you have not 12,8V .........
- starter needs maintenance : download my file https://www.geneva-racing.com/~alains/NSRtips.doc and look the starter repair ____________________ the worst day fishing is better than the best day working |
| x1160 |
 Posted: 16:06 - 03 Jul 2007 Post subject: |
thanks alot guys for the help so far, i have sorted the problem, although it does sound a bit unsual as in more rattling noise than usual, although 1st thing am doing is topping up on all essential fluids to see if theres any difference. |
The last post was made 18 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
