matmanmarsh |
matmanmarsh Two Stroke Sniffer
carvell |
carvell Scuttler
lukamon |
lukamon World Chat Champion
Posted: 16:30 - 07 Jul 2007 Post subject: |
take the right hand underseat panel off, and hold the starter button in so the relay clicks. jiggle the wires around the relay (i.e. push, pull, move in circles ect) if you get a ping from the engine, the wires needs stripping and re-connecting. it happened on mine ____________________ killa wrote: Im an ass man myself |
matmanmarsh |
truslack |
truslack World Chat Champion
matmanmarsh |
Teaman |
Teaman World Chat Champion
Posted: 17:16 - 11 Jul 2007 Post subject: |
bridge your relay block connector and see if that whips it over (use a thick wire and only do it for a short time, it gets hot)(bypassing the starter solonoid and the bar switch) this might work.
If not it could be a case of not enough amps in the battery, forget volts for now
if it doesnt start when you bridge the starter you should then check the motor, it could be either siezed or the bushes could be gone.
if it is siezed just nock it with a hammer whilst sticking some volts through it, if it doesnt work its dead and there about £60 retail ish for a new one, ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
The last post was made 16 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
