stoppies....
JimboJ
Manc Pikey
PostPosted: 20:08 - 03 Sep 2002    Post subject: stoppies.... Reply with quote
i tried doing a stoppie this mornin(as there were some friends round) and all wat happened was thet my front slid. Embarassed jimboj looks a fool! i just said that i had rubbish brake pads and they beleived me!ha. altho i need to know how to do em proper like
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
Scotty
Scooter Boi
PostPosted: 20:11 - 03 Sep 2002    Post subject: Reply with quote
i can only stoppie from about 30mph. I'm sure G would love to explain how to do them.
I must try to learn to wheelie though, but i a little scared as last time i did one on a scoot and it went terribly wrong...lol.
Scott
Regards
Scott
Wingchunal
PostPosted: 20:16 - 03 Sep 2002    Post subject: Reply with quote
I want an old bike to practise on Very Happy
TiN
Pocket Tin
PostPosted: 20:20 - 03 Sep 2002    Post subject: Reply with quote
You obviously locked the wheel, mate...you need to progressively add the front brake, not grab it...I know the theory, but haven't attempted the practice yet...
TiN
dotgems.net
JimboJ
Manc Pikey
PostPosted: 20:22 - 03 Sep 2002    Post subject: Reply with quote
well ill try that, but as you've not done that ill wait to see you try it first Laughing
MIKEY B
PostPosted: 20:35 - 03 Sep 2002    Post subject: Reply with quote
Are you part of the box hill user group?
GSXR 1000 K3 "Silver Bullet"
Yamaha XS 650 Hardtail bobber
Stew
If it's good enough for top race teams...
PostPosted: 20:42 - 03 Sep 2002    Post subject: Reply with quote
and make sure your front tyre is warm (warm=more sticky) Laughing
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
PostPosted: 21:12 - 03 Sep 2002    Post subject: Reply with quote
[Excert from Zimm&G's Stunt training manual] Smile
Make sure you have warm tyres.... They can be done on cold tyres but you need to puit all your weight over the front and there's no quarentees it wont slide... so it's best avoided.
First start coming to a stop quite quickly a few times (emergency stop style... but harder braking and leave the rear alone).... notice how the back kinda bumps up as you stop.
Now start increasing the pressure on the brake just as you are about to stop... the back should jump up a bit more.
Repeat untill the back starts to come off the ground a little. Once you are happy with that start increasing the pressure more so you're getting it about a foot or two up.
You can now do a 'basic' stoppie
Now try riding along quite slowly <20mph and do the hard braking like before... but now suddenly increase the pressure a second after you've started breaking. This should unweight the back significantly, if it doesn't lift it up. Release the pressure immediatley.
Repeat until you can reliable get the back off the ground for an instant.
Remember that you should allways start braking progressivly to weight the front wheel. If you don't there won't be enough force pushing down to give the front wheel grip, so the front will just slide.
Now start holding the brake on for longer. It takes a while to get used to the 'feel' of the brakes.
Try and keep the back wheel at a specific level (just a coupla feet is fine to start with)... don't just let it come up then dump it straight down again when it get's too high.
You can now do the proper 'rolling' stoppie
Start to increase your height... Once you are getting high one's you will find you need to 'modulate' teh front brake by releasing and reapplying pressure to keep it a the desired height.
But be carefull it's quite hard to judge the 'balance' point was you've overcome the general fear. Once you have pased this point there is nothing you can do (throwing your weight back is your only opiton.. but unlikely to work).
In theory if you got a stoppie in the balance point it could be held for the length of the road you've got (assuming a very slight downhill to overcome friction). However unlike wheelies once you've gone past it a quick dap on the back brake won't help so it's not an area you want to be explroing.
Voice of Reason section:
Doing stoppies makes you a better rider because you can accuratley judge the right braking force to come to a stop as quickly as possible. To get the most effiecent braking you need to be at the point the rear wheel is *just* about to lift off the ground. By sustaining stoppies at a set height you gain the control not only to know when the rear wheel is leaving the ground but to keep it at that point and thus ensure maximum braking.
Next weeks lesson: One handed stoppies Smile
One last bit of advice... if someone's showing you how to do them... make sure they don't go over the top... it probably won't help your confidence. Crying or Very sad Razz[/i]
TiN
Pocket Tin
PostPosted: 21:47 - 03 Sep 2002    Post subject: Reply with quote
/me expects to see that report soon...Very Happy
TiN
dotgems.net
JimboJ
Manc Pikey
PostPosted: 21:54 - 03 Sep 2002    Post subject: Reply with quote
how about a no-handed stoppie? i would get down and kiss your boots if you could pull that one off
PostPosted: 21:58 - 03 Sep 2002    Post subject: Reply with quote
Actually.....I do have a plan to make that possible Laughing
zaknafien
PostPosted: 05:58 - 04 Sep 2002    Post subject: Reply with quote
front brake lever type setup attached to your foot maybe?
02 Firestorm.
Demonic69
The Pink Rhino
PostPosted: 09:28 - 04 Sep 2002    Post subject: Reply with quote
My 1st 2 stoppies ever were cool, and easy to do. Got the back relatively high (ask Stew) but I managed to bring it down a little softer than expected (released the brake a bit on the way down. Now to practice rolling stoppies Twisted Evil though I may wait for braidied hoses.
Kris
PostPosted: 11:36 - 04 Sep 2002    Post subject: Reply with quote
what, like this?
https://www.stunters.com/images/pics-PBR5.jpg
www.prisonplanet.com
PostPosted: 11:53 - 04 Sep 2002    Post subject: Reply with quote
yep, Smile ... though I usually stay in the seat a bit more and grip the tank *very* hard with my knees Smile
Kris
PostPosted: 11:59 - 04 Sep 2002    Post subject: Reply with quote
This is cool....
https://www.stunters.com/images/pics-mop1.jpg
That'd be a sweet trick to pull off at BoxHill
PostPosted: 12:17 - 04 Sep 2002    Post subject: Reply with quote
I'll see what I can do Very Happy .... though the last time I did a stoppie without my jacket it all went a little wrong Confused Confused
It's actually not that hard to do... The hardest bit is convinceing your mind that you're *not* gonna veer off to one side Smile
JimboJ
Manc Pikey
PostPosted: 17:07 - 04 Sep 2002    Post subject: Reply with quote
looks easy Embarassed
TiN
Pocket Tin
PostPosted: 18:56 - 04 Sep 2002    Post subject: Reply with quote
lol...that guy's going "ooh, my balls!" Laughing
TiN
dotgems.net
Ropehead
PostPosted: 19:04 - 04 Sep 2002    Post subject: Reply with quote
id Laugh SO SO SO much if he had a falled over Smile
Viper
Get off my bloody bike!
PostPosted: 23:30 - 04 Sep 2002    Post subject: Reply with quote
Laughing .....
hmmmmm....also note on that ^^^ picture, that the tank *has* been replaced at some point in the past!!! .....Rolling Eyes ...cant think why!!! Laughing
/me is glad to be female! Very Happy
Vx
Korn
Admin
PostPosted: 00:07 - 05 Sep 2002    Post subject: Reply with quote
The bloke on the gixxer looks like he's in the process of crashing into a small invisible wall Very Happy
Demonic69
The Pink Rhino
PostPosted: 08:48 - 05 Sep 2002    Post subject: Reply with quote
Look at the 2nd guys lid!! Yeah that'll save him
TiN
Pocket Tin
PostPosted: 11:23 - 05 Sep 2002    Post subject: Reply with quote
Just for Jimbo:
https://www.tin3d.com/images/stoppie.jpg
TiN
dotgems.net
PostPosted: 11:43 - 05 Sep 2002    Post subject: Reply with quote
lol @ tin.... who needs to go and get a job instead of sitting around photoshopping all day Very Happy
The last post was made 23 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 129.19 Kb
