cr80 engine trouble
rik220
PostPosted: 22:02 - 13 Aug 2007    Post subject: cr80 engine trouble Reply with quote
My 2000 honda cr80 seized recently due to being ridden without water, not by me though. However i'v came to getting a new piston but iv realised that, sometimes the bottom end will turn freely as it should but sometimes will stick and proves hard to move. What could the problem be?
Rik
Honda x8r. Aprilia Rs50
Honda CR85
Renault Clio 1.2
baldy
PostPosted: 22:18 - 13 Aug 2007    Post subject: Reply with quote
the big ends gone, time for a rebuild.
One day i will rule the world, just not today.
rik220
PostPosted: 22:25 - 13 Aug 2007    Post subject: Reply with quote
O cock. When you turn the fly wheel the engine will turn 3/4 of a full revolution but the remainder is VERY hard to turn, does that help? Also if it is the big end how hard is it to do? I have average mechanical knowledge and would have a go at fixing it.
Rik
Honda CR85
Renault Clio 1.2
rik220
PostPosted: 23:12 - 13 Aug 2007    Post subject: Reply with quote
Iv just bought a piston kit today, before i realised this Sad
Honda CR85
Renault Clio 1.2
baldy
PostPosted: 10:41 - 14 Aug 2007    Post subject: Reply with quote
you will have to split the crank case halves, a bit fiddly and easy to lose bits. You might be able to get a new bearing fitted but will probably be easier to buy a new crank. While your in there, you might as well replace the main bearings and check the gearbox over. Also, make shure you get all the bits of metal out from the bearings, otherwise it will screw up very quickly, and replace the gaskets and oil.
rik220
PostPosted: 11:17 - 14 Aug 2007    Post subject: Reply with quote
Ok. To split the engine is there anything i should be aware of that could go wrong or watch out for? Even though it is electronic ignition could it be put off if i remove the flywheel?
Rik
Honda CR85
Renault Clio 1.2
The last post was made 18 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 47.66 Kb
