WildGoose |
WildGoose White Van Man
G |
G The Voice of Reason
Posted: 19:01 - 12 Sep 2002 Post subject: Re: Clutchless Shifting |
Me, generally.
Because it's quicker.
Put slight upwards pressure on the gear lever, then dip the throttle off a bit then on again. The gear lever should come up by itself from the slight pressure when you dip the throttle.
Not only does it mean that power is applied for a few micro-secs longer but it will save on clutch wear (not that that's ever bothered me ) Done properly it should also help reduce wear on the gear box because it will change when it can rather than when you want it to. |
TiN |
TiN Pocket Tin
Posted: 19:19 - 12 Sep 2002 Post subject: |
It can save time and make the gear change smoother, if done properly...it also means that you won't pull in the clutch with a handful of revs, which can be embaressing
I can't seem to change from 1st into 2nd particularly smoothly anymore, so I usually clutch it...but I usually change into the other gears without the clutch. Once you're used to it, you don't really think about it...you can keep putting pressure on the gear change lever whilst you've got the throttle open 'cos it won't do anything, but once you close the throttle, it should pop into the next gear... ____________________ TiN
dotgems.net |
Hex |
Hex Party Boy
Posted: 20:00 - 12 Sep 2002 Post subject: |
1st to 2nd Tin I would suggest using the clutch as you say its harder to do/clunkier...
thats because its a bigger gate (may not be the right word) for it to travel through (ie 1st into second via neautral!)
from second on though I do most of the time
Hex ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
Phoenix |
Phoenix Twisted Firestarter
Posted: 20:09 - 12 Sep 2002 Post subject: |
I never do clutchless shifting, it DAMAGES your gearbox AND your clutch, because your clutch is engaged all the time.
Read this detailed article on the technicalities of clutchless shifting on modern bikes. If you can't upshift smoothly whilst using the clutch, then you need to practice.
https://www.vf750fd.com/blurbs/shifting.html |
Robby |
Robby Dirty Old Man
G |
WildGoose |
Demonic69 |
Demonic69 The Pink Rhino
TiN |
TiN Pocket Tin
Posted: 09:08 - 13 Sep 2002 Post subject: |
Nah...*poor* clutchless gear changes damage your gearbox...well executed ones don't... ____________________ TiN
dotgems.net |
G |
Demonic69 |
TiN |
TiN Pocket Tin
Posted: 09:13 - 13 Sep 2002 Post subject: |
The gears are still spinning, even if you use the clutch ...unless you stop conpletely between each gear change ____________________ TiN
dotgems.net |
G |
Demonic69 |
TiN |
TiN Pocket Tin
Annabella |
Annabella Like a person, only smaller
Posted: 09:34 - 13 Sep 2002 Post subject: |
OK, this is my interpretation of that article:-
To change gear the engine wants to be in a free coasting state. (i.e. when the back wheel is driving the engine rather than vice versa).
So there are two choices, - when the clutch is disengaged,
OR when you roll off the throttle
Either is as good as the other. So clutchless gear shifts are OK
PROVIDED ~ you change gear firmly, at the correct time - ie when you have reached the lowest throttle point.
Likewise, changing gear with the clutch - if you don't chnage gear when the clutch is completely disengaged and then you dump the clutch as you yank on the power you're going to do damage as much as if not more.
BASICALLY - if you are competant and smooth, you won't do any damage with either method. ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
G |
Posted: 09:35 - 13 Sep 2002 Post subject: |
\o/... /me hands over [Voice of Reason] to Anna |
Annabella |
Demonic69 |
Annabella |
Posted: 09:42 - 13 Sep 2002 Post subject: |
Unfortunately my dear Dean, there is a moment when the engine is being driven by the back wheel....momentum and all that!!! good try though Dean. But Clutches *do slip!!!! ____________________ Avast! Pirates ahoy!
I did Cadwell!
Demonic69 |
Annabella |
Posted: 09:47 - 13 Sep 2002 Post subject: |
No, you do reach that point - there are many all the way down the speeds.... there will always be a point at which the back wheel is moving faster than the engine - if you dip the throttle enough. This is the point at which the gear pops in....it'll do it itself if you just let it!!! So it's not like you have to "find" it !![/u] ____________________ Avast! Pirates ahoy!
I did Cadwell!
Demonic69 |
G |
The last post was made 21 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
