HELP please
lewisone
PostPosted: 11:40 - 05 Aug 2007    Post subject: HELP please Reply with quote
the fuel tap on my suzuki 100 has rust etc blocking it what is the best way to unblock it? as its just a field bike i don,t want to buy a new one the tank has been sitting in the rain for 6 months without the petrol cap on it,i,ve removed the tap from the tank???
rzren
PostPosted: 16:00 - 05 Aug 2007    Post subject: Reply with quote
Blow on it perhaps? Neutral Maybe some compressed air will do the trick unless it's really jammed in there. Try removing the catch bowl on the tap. Give the tank a thorough petrol rinse if you do remove the tank.
AbiJ
PostPosted: 18:46 - 05 Aug 2007    Post subject: Reply with quote
Pull the tank, fill with a litre or so of fuel, block off the filler and outlet, shake it around and drain, do it a couple of times to rinse out the crud from the tank.
For the petcock, put it in PRI and blow through the outlet (backflushing it) to try and blow the crap out, if blowing with your lungs doesn't clear it, gently try compressed air.
Abi.
'81 Yammi XJ750 Seca, oldie but a goodie.
The last post was made 19 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.3 - MySQL Queries: 13 - Page Size: 34.96 Kb
