hopoffbaby |
hopoffbaby Spanner Monkey
Demonic69 |
Demonic69 The Pink Rhino
G |
G The Voice of Reason
Posted: 10:24 - 16 Sep 2002 Post subject: |
/me goes to look for rubber band
err... sorry, my very limited knowledge of engines doesn't extend anywhere near scooters |
Demonic69 |
Scotty |
Scotty Scooter Boi
TiN |
TiN Pocket Tin
Posted: 11:00 - 16 Sep 2002 Post subject: |
I assume that you are referring to your scoot?...unless you've got yourself a proper bike recently ____________________ TiN
dotgems.net |
JimboJ |
JimboJ Manc Pikey
hopoffbaby |
Scotty |
Scotty Scooter Boi
Dylan |
Dylan Trackday Trickster
hopoffbaby |
Robby |
Robby Dirty Old Man
Scooby |
Scooby Scrappy Doo
Posted: 20:11 - 16 Sep 2002 Post subject: |
Full throttle for 30 mins dude, that's bad. I would expect the worst. Peds aren't very complicated so whip all the plastics off and find a baked bean can size cylinder.... that's where your piston will be
The cylinder head will be held on by bolts, so undo these and your piston will be in there. See if it moves up and down, if it does, it might be the piston rings siezing to the piston like Scotty said. ____________________ A big enough hammer fixes anything! |
Ropehead |
Ropehead Could Be A Chat Bot
Posted: 23:49 - 16 Sep 2002 Post subject: |
My old tzr was totaly Nacked up (scored siezed spitting out bit of metal) but it still got me home.. had 2 rebore 2mm of it.
Its probably going to need
re-bore
piston kit
gaskets
£80+
Plus labour (i did it myself saves £££)
then uv got running it time a Good 700miles
U might get £250 scrap i got that for a sized up Kreg (crap) AR80 |
Kickstart |
Kickstart The Oracle
Posted: 09:45 - 17 Sep 2002 Post subject: |
HI
I agree with Ropehead. When you kick the engine over is it very easy to do compared to normal? If so then it is probably down on compression. Likely cause of that is a hole burnt in the piston (unlikely, normally caused by using too low a grade of fuel which isnt really an option any more with only a single grade in most places) or snapped rings. If the rings have snapped (can easily happen if the engine nips up) then you may well have damaged the bore. If the bike has a steel bore you can rebore it to a slightly larger size and put an oversize piston in it (a rebore is cheap, £20 tops really). If it has a plated bore then you will either need to get it repaired and replated (~£100) or replace it with a new / 2nd hand one. You will also need a new piston with rings, and new gaskets to reassemble it.
All in all, depending on spares prices, likely best case scenario is about £60 (doing it yourself), worst case about £400 (paying dealer).
However, it could be other problems. Is it sparking? Main bearings could have failed and left you with knackered seals, leading to it drawing air in. However, the piston / rings are the most likely problem
Scotty |
Scotty Scooter Boi
Ropehead |
The last post was made 21 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
