tanner18 |
tanner18 Traffic Copper
TiN |
TiN Pocket Tin
Posted: 09:36 - 20 Sep 2002 Post subject: |
I think that either Castrol (GPS) or Silkolene (?) 10w40 will be sufficient...they're only semi-synth, but they should be good enough for road bikes. ____________________ TiN
dotgems.net |
tanner18 |
TiN |
TiN Pocket Tin
Posted: 10:53 - 20 Sep 2002 Post subject: |
Some users of fully synth have reported clutch slipping after a while, unless you change the oil often (every 1500 miles)...but some ppl haven't experienced any problems at all...
...if you can source some 10W40 fully synth, then go for that...but most of the stuff that is available tends to be 5W40...(such as Castrol R4) ____________________ TiN
dotgems.net |
tanner18 |
G |
G The Voice of Reason
Posted: 11:00 - 20 Sep 2002 Post subject: |
In last month's bike/Ride (I forget which) they had a review of a race fully-synth oil that added about 8hp over standard oil to some 600.
However it would need very regular changing and possibly a race clutch with stronger springs (, which I have... hmmmm /me considers )
I've been told that using fully synth in the zx6 can cause clutch slip when the engine heats up, however many miles it's done with the oil. |
TiN |
TiN Pocket Tin
Posted: 11:05 - 20 Sep 2002 Post subject: |
lol...did you see the cost of that oil though? £75! ...it may add 8HP, but it don't last forever...at £75 a pop, you're probably better off saving up for a race system.
The 'W' stands for Winter, which refers to the viscosity of the oil, and, I guess, the suitability of the oil for all-year use (dunno, though) ____________________ TiN
dotgems.net |
Kickstart |
Kickstart The Oracle
craigT19 |
craigT19 Jolly Green Giant
Annabella |
Annabella Like a person, only smaller
Posted: 22:31 - 20 Sep 2002 Post subject: |
Get GPS....semi synth - so you can mix it with fully synth when you decide to top up...AND it's PINK!!!!! (thanks to Tin and G for their recommendation!!)
I must say, having changed from standard 10W40 to the semi-synth the gear change feels smoother than ever. ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
The last post was made 21 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
